Home » Modeling » EMF » [CDO] No credentials provider configured
[CDO] No credentials provider configured [message #1710699] Thu, 08 October 2015 09:41 Go to next message
I added an authenticator to my CDO server:
<securityManager type="default" description="/security:annotation:home(/home)"/>
<authenticator type="myauth"/>
after starting the server, it tries to create a jvm-connection with the CDO_SYSTEM user. Fails with this exteption:
java.lang.IllegalStateException: No credentials provider configured
at org.eclipse.net4j.signal.security.AuthenticationIndication.responding(AuthenticationIndication.java:85)
at org.eclipse.net4j.signal.IndicationWithMonitoring.responding(IndicationWithMonitoring.java:105)
at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:106)
at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:338)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:75)
at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:67)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:275)
at org.eclipse.net4j.signal.Signal.run(Signal.java:154)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Am i doing something wrong?
Re: [CDO] No credentials provider configured [message #1710704 is a reply to message #1710699] Thu, 08 October 2015 10:15 Go to previous messageGo to next message
Am 08.10.2015 um 15:41 schrieb Samuel Leisering:
> Hi
The security manager includes an internal implementation of an authenticator which is backed by the security model in
the realm /security. You don't need to (and probably should not) register a separate authenticator.
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] No credentials provider configured [message #1710705 is a reply to message #1710704] Thu, 08 October 2015 10:16 Go to previous messageGo to next message
Am 08.10.2015 um 16:15 schrieb Eike Stepper:
>> Hi
I.e., org.eclipse.emf.cdo.server.internal.security.SecurityManager.Authenticator
Cheers
/Eike
Re: [CDO] No credentials provider configured [message #1710769 is a reply to message #1710705] Fri, 09 October 2015 03:20 Go to previous messageGo to next message
Ah, i understand. There is still an issue with this however:
I want to use the default Usermanager for organization of the users and, most importantly, the organization of permissions.
Instead of the default authorization mechanism (with the passwords stored in the model) i want to connect to an ldap system.
In this case I would argue that it is neccessary to use my own authenticator.
Re: [CDO] No credentials provider configured [message #1710773 is a reply to message #1710769] Fri, 09 October 2015 03:49 Go to previous message
Am 09.10.2015 um 09:20 schrieb Samuel Leisering:
> permissions.
> system.
The SecurityManager implementation does currently not support authenticators other than SecurityManager.Authenticator.
When I implemented it I had no clear idea how other authenticators would play with the security manager model,
especially I have not much experience with LDAP.
Maybe you want to play with the sources, e.g., change SecurityManager.Authenticator such that it works well for your
LDAP case. I'd be happy to review a respective patch (ideally via Gerrit).
Cheers
/Eike
Previous Topic:[CDO] Simple Model Evolution
Next Topic:[CDO] User auth with JVM connectors
Current Time: Sat Jul 26 08:49:47 EDT 2025
Powered by FUDForum. Page generated in 0.05617 seconds
