Home » Modeling » EMF » static model from xml(generate java class from xml description)
static model from xml [message #1709967] Fri, 02 October 2015 05:52 Go to next message
Hello
I work on xtext based application. Right now we use dynamic implementaion of model. It means : we have xml file that describe object in model and xsd file that is used for verification xml file. Metamodel is loaded from xml file using code like this
metamodel = new XSDMetaModel();
xsdFileName = FileSystem.getTypesXsdPath();
metamodel.addSchemaFile(xsdFileName);
XMLReaderImpl reader = new XMLReaderImpl(new ResourceSetImpl(), etamodel);
xmlFileName = FileSystemRegistry.getAtomFileSystem().getTypesXmlPath();
reader.setUri(xmlFileName);
EObject e = reader.readXML();
return e;
then we create actual object of semantic model via
public static EObject createEObject(final String name, final EPackage metamodel) {
EClass meta = (EClass) metamodel.getEClassifier(name);
if (meta != null) {
return metamodel.getEFactoryInstance().create(meta);
} else {
throw new RuntimeException("Metamodelelement " + name + " cannot be created. Probably a misstyping?");
[/code]
So we use dynamic implmentaion. Are there way to generate Java class from XML descriptionin compile time and used static implementation?
<type name="XXXT" schema="SHEMA" table="TABLE">
		<attribute name="N1" type="String" />
		<attribute name="N2" type="Integer"/>
	</type>
I would like to create ecore file from this descprition like
  <eClassifiers xsi:type="ecore:EClass" name="C1" eSuperTypes="//GENERICTYPE">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="C1">
      <eType xsi:type="ecore:EDataType" href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
    </eStructuralFeatures>
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="C2">
[Updated on: Fri, 02 October 2015 06:57] by Moderator
Re: static model from xml [message #1710091 is a reply to message #1709967] Sun, 04 October 2015 03:43 Go to previous messageGo to next message
Alex,
Comments below.
On 02/10/2015 11:52 AM, Alex Gor wrote:
> Hello
> etamodel);
> return e;
I don't recognize these class names. They're not provided by EMF itself...
> metamodel) {
> if (meta != null) {
> } else {
This old tutorial shows how:
https://www.eclipse.org/modeling/emf/docs/2.x/tutorials/xlibmod/xlibmod_emf2.0.html
Re: static model from xml [message #1710215 is a reply to message #1710091] Mon, 05 October 2015 07:57 Go to previous messageGo to next message
Thanks for the link. I generated corresponded editor. To my regret is unclear how to imported the xml description to generated editor. I can do it programmatically using code
xmlFileName = FileSystemRegistry.getTypesXmlPath();
return e
Can I do it in compile time and then using generated class instead of dynamic implementation?
[Updated on: Mon, 05 October 2015 07:57] by Moderator
Re: static model from xml [message #1710256 is a reply to message #1710215] Mon, 05 October 2015 10:40 Go to previous message
Alex,
As I mentioned, I don't recognize these APIs. If you've followed a
tutorial, you can invoke Generate Test Code and look at the
XyzExample.Java to see to load XML purely with EMF using the generated
model in a stand alone program...
> etamodel);
> return e
Previous Topic:Renaming a Resource opened in Editor
Next Topic:Adding Drop Support To Ecore Editor
Current Time: Sun Jul 27 07:56:58 EDT 2025
Powered by FUDForum. Page generated in 0.03843 seconds
