Home » Eclipse Projects » DTP » BIRT 2.1.0 distribution missing some plugin metadata?
BIRT 2.1.0 distribution missing some plugin metadata? [message #16390] Mon, 12 June 2006 07:35 Go to next message
I've installed the BIRT 2.1.0 zip (1) for TPTP 4.2.0 (as recommended
at bottom of (2)) to enable reporting from the <tptp:publication> ant
task and I noticed that on startup the Error Log is reporting a number
of errors installing BIRT bundles. For example:
Error
Mon Jun 12 12:09:49 BST 2006
Plugin does not have a valid version:
plugins/org.eclipse.datatools.modelbase.sql_0.9.0.200605101/
Error
plugins/org.eclipse.datatools.modelbase.sql.xml.query_0.9.0. 200605101/
Presumably these plugins are coming from DTP, and looking at the
offending plugin folders, they do seem to be missing Manifest files.
Has anyone else noticed this? Should TPTP be using a revised BIRT/DTP
distribution?
(1)
http://www.eclipse.org/downloads/download.php?file=/birt/dow nloads/drops/N-R1-N20060530-200605300632/birt-report-framewo rk-N20060530.zip
(2)
http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.2.0- 200605251528B.html
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #16869 is a reply to message #16390] Mon, 12 June 2006 15:05 Go to previous messageGo to next message
The DTP modelbase plugins, as included in the BIRT N20060530 build, are
indeed incomplete. The BIRT build should not have included these DTP
modelbase plugins in the first place.
They are no longer included since the BIRT 20060602 build.
A work-around is to manually remove all the DTP modelbase plugins from
your installation, since they are not used by BIRT.
Or, if you want to get the complete DTP plugins, download the version
distributed by DTP download page or the Callisto update site.
Linda
John O'Shea wrote:
> Error
> Error
> distribution?
> (1)
> (2)
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #16895 is a reply to message #16869] Tue, 13 June 2006 05:32 Go to previous messageGo to next message
Linda,
Thanks for the clarification. If the DTP modelbase is not being used
then I'll assume the platform failures to initialize the bundles can be
ignored.
BTW, the versions I am using are all from Callisto RC4. Well nearly -
the TPTP page links to a slightly earlier release of BIRT (N20060530
instead of M-R1-2.1RC4 but both are missing manifests). I can wait
until the next Callisto release to pick up a cleaner build. I presume
the BIRT reporting framework distribution will no longer internally
contain any DTP plugins?
John.
> Linda
> John O'Shea wrote:
>> Hi,
>> recommended at bottom of (2)) to enable reporting from the
>> <tptp:publication> ant task and I noticed that on startup the Error
>> Log is reporting a number of errors installing BIRT bundles. For
>> example:
>> Error
>> Error
>> distribution?
>> (1)
>> (2)
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #16924 is a reply to message #16895] Tue, 13 June 2006 22:57 Go to previous messageGo to next message
John,
>> I presume the BIRT reporting framework distribution will no longer internally
It does contain those DTP plugins that are needed by BIRT. That includes the DTP ODA plugins and a couple other DTP connectivity plugins.
Linda
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #16954 is a reply to message #16924] Wed, 14 June 2006 03:24 Go to previous messageGo to next message
The reason I asked is that we typically combine BIRT distributions with
tothers from Callisto - WTP (and it's dependents), DTP etc. Having a
second (different) DTP distribution inside the BIRT reporting framework
causes two sets of DTP plugins to get dropped into our Eclipse installation.
It's not a big problem, we can manually remove the DTP plugins from the
BIRT zip and re-distribute it, I was just hoping the distro coming from
you guys would be trimmed down (and the download page would have a link
to the compatable DTP runtime...
John.
Linda Chan wrote:
> John,
> Linda
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #17043 is a reply to message #16954] Wed, 14 June 2006 17:09 Go to previous messageGo to next message
Yes, I do see the issue you'd described.
Please submit a Bugzilla entry for the BIRT Build component on this, and
specify which BIRT download package(s) that you use.
It should be ok, though, for the BIRT "all-in-one" package to continue
include its dependent DTP plugins, right?
Linda
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #17100 is a reply to message #17043] Fri, 16 June 2006 05:29 Go to previous message
Done - https://bugs.eclipse.org/bugs/show_bug.cgi?id=147419
It's not quite as big a problem - at least at the moment BIRT is
redistributing the 'correct' version of DTP but it would be good to make
the BIRT distro leaner. (There is also the danger that in the future we
may need to combine a patched version of DTP with BIRT)
Yes, I don't see why not!
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #579498 is a reply to message #16390] Mon, 12 June 2006 15:05 Go to previous message
Linda
John O'Shea wrote:
> Error
> Error
> distribution?
> (1)
> (2)
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #579512 is a reply to message #16869] Tue, 13 June 2006 05:32 Go to previous message
Linda,
ignored.
John.
> Linda
> John O'Shea wrote:
>> Hi,
>> example:
>> Error
>> Error
>> distribution?
>> (1)
>> (2)
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #579519 is a reply to message #16895] Tue, 13 June 2006 22:57 Go to previous message
John,
Linda
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #579534 is a reply to message #16924] Wed, 14 June 2006 03:24 Go to previous message
John.
Linda Chan wrote:
> John,
> Linda
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #579614 is a reply to message #16954] Wed, 14 June 2006 17:09 Go to previous message
Linda
Re: BIRT 2.1.0 distribution missing some plugin metadata? [message #579668 is a reply to message #17043] Fri, 16 June 2006 05:29 Go to previous message
Previous Topic:How to submit SQL queries?
Next Topic:How to get the content of a Table
Current Time: Wed Sep 03 11:11:58 EDT 2025
Powered by FUDForum. Page generated in 0.08435 seconds
