Home » Modeling » Epsilon » How to use Epsilon Generation Language to generate DocBook XML file
How to use Epsilon Generation Language to generate DocBook XML file [message #1709915] Thu, 01 October 2015 17:44 Go to next message
Now I am doing some work about using ETL to generate DocBook article XML file. My first step is generating the valid attribute information for the DocBook type "article". I use an original DocBook project file "docbook.xml" from DEP4E as a reference.
The current problems are:
1. How to set the "xml:lang="en" ?
2. How to set the version="5.0" following xmlns="http://docbook.org/ns/docbook" ?
3. How to set the "title" of the article ?
In the attachment, you can find a ETL project (de.itesys.epsilon.docbook.generation.rar) and a reference project from DEP4E (DocBookExample.rar).
Thank you.
Xue Liu
Re: How to use Epsilon Generation Language to generate DocBook XML file [message #1709975 is a reply to message #1709915] Fri, 02 October 2015 06:58 Go to previous message
This seems to work fine:
article.version = '5.0';
article.title.add(new DocBook!TitleType);
article.lang = 'en';
I've attached the project (you were missing the xml.xsd and xlink.xsd files that were imported from docbook.xsd).
You may want to consult some of EMF's official docs regarding the XML Schema --> ECore mapping:
https://www.eclipse.org/modeling/emf/docs/overviews/XMLSchemaToEcoreMapping.pdf
Keep in mind that Epsilon can also produce XML files without an XML Schema:
http://www.eclipse.org/epsilon/doc/articles/plain-xml/
Previous Topic:[ETL] Is there support for multiple metamodels? (ecore)
Next Topic:Strategy for model comparison and transformation
Current Time: Sat Nov 01 19:20:30 EDT 2025
Powered by FUDForum. Page generated in 0.03634 seconds
