| WebSocket network error: The operation couldn't be completed. (OSStatus error -9807.) [message #1709770] |
Wed, 30 September 2015 15:38  |
Hi Im using mqttws31.js in an App created with NSBasic Appstudio. The app connects to a mosquito 1.4 broker using secure websockets on port 9002 just fine from Safari on OS X, and chrome, but when I connect from Safari or the web app on iOS9 mobile devices, I get the -9807 error code as in the subject line and mqtt doesn't connect. Any help in expanding logging on the server or client to help figure this out would be appreciated, thanks in advance.
| Re: WebSocket network error: The operation couldn't be completed. (OSStatus error -9807.) [message #1710291 is a reply to message #1710187] |
Mon, 05 October 2015 13:35   |
All that shows in the javascript console is what I posted for the subject of this issue, the web socket network error OSStatus error -9807
Does anybody else have secure websockets running on iOS from javascript to mosquito 1.4.3?
I enabled detailed websocket logging on mosquito, this is the log of when the iPhone Safari tries and fails to connect
Oct 2 16:35:41 dev mosquitto[1247]: insert_wsi_socket_into_fds: wsi=0x1441130, sock=17, fds pos=2
Oct 2 16:35:41 dev mosquitto[1247]: inserted SSL accept into fds, trying SSL_accept
Oct 2 16:35:41 dev mosquitto[1247]: SSL_accept failed 2 / error:00000002:lib(0):func(0):system lib
Oct 2 16:35:41 dev mosquitto[1247]: SSL_ERROR_WANT_READ
Oct 2 16:35:41 dev mosquitto[1247]: SSL_accept failed 5 / error:00000005:lib(0):func(0):DH lib
Oct 2 16:35:41 dev mosquitto[1247]: SSL_accept failed skt 17: error:00000005:lib(0):func(0):DH lib
Oct 2 16:35:41 dev mosquitto[1247]: close: just_kill_connection
Oct 2 16:35:41 dev mosquitto[1247]: remove_wsi_socket_from_fds: wsi=0x1441130, sock=17, fds pos=2
Oct 2 16:35:41 dev mosquitto[1247]: not calling back closed
Oct 2 16:35:42 dev mosquitto[1247]: insert_wsi_socket_into_fds: wsi=0x1441130, sock=17, fds pos=2
Oct 2 16:35:42 dev mosquitto[1247]: inserted SSL accept into fds, trying SSL_accept
Oct 2 16:35:42 dev mosquitto[1247]: SSL_accept failed 2 / error:00000002:lib(0):func(0):system lib
Oct 2 16:35:42 dev mosquitto[1247]: SSL_ERROR_WANT_READ
Oct 2 16:35:42 dev mosquitto[1247]: SSL_accept failed 5 / error:00000005:lib(0):func(0):DH lib
Oct 2 16:35:42 dev mosquitto[1247]: SSL_accept failed skt 17: error:00000005:lib(0):func(0):DH lib
Oct 2 16:35:42 dev mosquitto[1247]: close: just_kill_connection
Oct 2 16:35:42 dev mosquitto[1247]: remove_wsi_socket_from_fds: wsi=0x1441130, sock=17, fds pos=2
Oct 2 16:35:42 dev mosquitto[1247]: not calling back closed
comparing this with a successful connection from Chrome on OS X
Oct 2 16:33:30 dev mosquitto[1247]: insert_wsi_socket_into_fds: wsi=0x1430190, sock=16, fds pos=1
Oct 2 16:33:30 dev mosquitto[1247]: inserted SSL accept into fds, trying SSL_accept
Oct 2 16:33:30 dev mosquitto[1247]: SSL_accept failed 2 / error:00000002:lib(0):func(0):system lib
Oct 2 16:33:30 dev mosquitto[1247]: SSL_ERROR_WANT_READ
Oct 2 16:33:30 dev mosquitto[1247]: accepted new SSL conn
Oct 2 16:33:30 dev mosquitto[1247]: issuing 547 bytes to parser
Oct 2 16:33:30 dev mosquitto[1247]: WSI_TOKEN_NAME_PART 'G'
Oct 2 16:33:30 dev mosquitto[1247]: WSI_TOKEN_NAME_PART 'E'
Oct 2 16:33:30 dev mosquitto[1247]: WSI_TOKEN_NAME_PART 'T'
Oct 2 16:33:30 dev mosquitto[1247]: WSI_TOKEN_NAME_PART ' '
Oct 2 16:33:30 dev mosquitto[1247]: known hdr 'GET '
Oct 2 16:33:30 dev mosquitto[1247]: WSI_TOK_(0) '/'
Oct 2 16:33:30 dev mosquitto[1247]: WSI_TOK_(0) 'm'
Oct 2 16:33:30 dev mosquitto[1247]: WSI_TOK_(0) 'q'
Oct 2 16:33:30 dev mosquitto[1247]: WSI_TOK_(0) 't'
Oct 2 16:33:30 dev mosquitto[1247]: WSI_TOK_(0) â '
etc etc
i see its failing in DH lib. How do we dig deeper into whats causing it to fail please?
Jon
FUDForum. Page generated in 0.18811 seconds
