Home » Eclipse Projects » Oomph » Specify architecture in product setup file
Specify architecture in product setup file [message #1709661] Wed, 30 September 2015 03:22 Go to next message
i am trying to set up an installer for our eclipse based Simulation Framework. Since the application is only available for Windows 32bit I want to predefine this in the setup file. I there a possibility to do this?
When i run my setup file in the simple mode, the installer tries to install a 64bit version, which is not present in the repository.
I do not want to use the advanced mode only for switching to 32 bits...
Thanks for your help.
Philipp
Re: Specify architecture in product setup file [message #1710097 is a reply to message #1709661] Sun, 04 October 2015 04:00 Go to previous message
Philipp,
We not given that case much thought. We've only really considered repos
that support all the combinations. I suppose we could augment a product
definition to specify which architectures (and OSes) are available.
Note that simple mode also lets you specify the bitness on the second page.
On 30/09/2015 3:10 PM, Philipp Simon wrote:
> this? When i run my setup file in the simple mode, the installer tries
> Philipp
Previous Topic:Negating/Evaluating boolean variable
Next Topic:install fails if one update site unreachable, although requirements present in pool
Current Time: Sun Jul 20 20:55:31 EDT 2025
Powered by FUDForum. Page generated in 0.04114 seconds
