Home » Language IDEs » ServerTools (WTP) » Extending SSE
Extending SSE [message #170688] Tue, 06 June 2006 03:35 Go to next message
Originally posted by: alban_news.laposte.net
I'm trying to extend SSE in order to have an editor in a language which
the structure is similar to JSP.
My first step is to obtain the syntax highlighting for this language.
I have:
1. extended the SSE extention point TextViewerConfiguration.
2. a parser that parse in regions a structured document.
3. a partitioner and a lineStyleProvider.
What are the next tasks to do in order to color the code?
Is a DOM model essential to obtain the syntax highligting?
I've found very few technical papers about the extension of SSE. Is the
some articles or tutorial about it?
Thanks for any help!
Alban
Re: Extending SSE [message #170740 is a reply to message #170688] Tue, 06 June 2006 14:23 Go to previous messageGo to next message
Hi Alban,
You might like to take a look at the EclipseCon SSE tutorial [1].
[1] http://www.eclipsecon.org/2006/Sub.do?id=186
Lawrence
Re: Extending SSE [message #170838 is a reply to message #170688] Thu, 08 June 2006 10:29 Go to previous messageGo to next message
On Tue, 06 Jun 2006 03:35:33 -0400, Alban <alban_news@laposte.net> wrote:
> What are the next tasks to do in order to color the code? Is a DOM model
No, a DOM Model is not needed. You might need a contentType (for whole
file)
in order to register your lineStyleProvider(s) per partition type.
These LineStyleProviders are not yet API, since we do need to use some
care to "fit in" to the platform's way of doing it ... so your experiences
and the "how to" knowledge to learn would be very interesting and useful.
Re: Extending SSE [message #170963 is a reply to message #170688] Fri, 09 June 2006 12:25 Go to previous messageGo to next message
Thanks a lot for your answers!
Ok, that was I thought. The DOM Model in mainely usefull to content
assist and validation, right?
> You might need a contentType (for whole file)
Where is the link between a ContentType and the LineStyleProvider/partition?
Is the implementation of a content type easy or is it heavy ? (I've
looked at the content type described by the JSP plugin and it appears
quite complex first...)
Ok, I will post remarks about the LineStyleProviders as soon as I have
acquired more experience on the subject.
Alban
Re: Extending SSE [message #171022 is a reply to message #170963] Fri, 09 June 2006 23:00 Go to previous messageGo to next message
Yes, mainly. (technically, it could be useful in syntax highlighting, but
1. our "structuredDocumentRegions" (basically) is already pretty rich
information, and
2. DOM access/precessing tends to be slower, so is not appropriate for
lineStyleProviders,
per se ... would have to move some processing and highlight updating to
another thread.
Not sure off top of my head, I'd have to dig around.
(some part of structuredTextViewerConfiguration and/or
search for "internal" extension points with "lineStyle" in
them).
Can be very light, or very heavy. JSP is not a good one to start with
as an example. To just associate an extension to an existing one
is the easiest to do. To "peek" in the file gets progressively more
complex.
Re: Extending SSE [message #171314 is a reply to message #170963] Thu, 15 June 2006 04:35 Go to previous messageGo to next message
The platform's ContentType determines which text viewer
configuration class is loaded, you'll see examples of associating
the Content Type ID to viewer configuration classes in the
org.eclipse.wst.xml.ui and similar plugins. It's easy to confuse
with the method and argument names "contentType", which in the
SourceViewer and SourceViewerConfiguration hierarchy actually mean
_partition_ types. The structured text viewer configuration uses
the partition type to call the correct line style provider.
- Nitin
Re: Extending SSE [message #171695 is a reply to message #170838] Tue, 20 June 2006 09:25 Go to previous messageGo to next message
Tanks for your help, my syntax highlighting works!
- The hard point (as says Nitin), is to understand the difference
between the content type (of a file, indicated by its extension) and the
content type which is the partition type. It's really easy to get
confused with something which have the same name and a different concept...
- The LineStyleProvider use needs to have assimilated both concepts of
StructuredDocument and partionning. After this step, it's quite easy to
manipulate. The method getAttributefor who defines the mapping between
styles and regions provides a global view of the mapping used by the
Highlighter.
- It could be useful to have the future LineStyleProvider API defined in
the StructuredTextConfiguration extension point instead of declaring
them in the StructuredTextConfiguration class (by adding an element
LineStyleProvider to the StructuredTextconfiguration extension point
schema). The new element could contain the partionning types supported
by the LineStyleProvider and the class who implements the
LineStyleProvider.
This could make the syntax highlighting process more readable.
Alban
Re: Extending SSE [message #171711 is a reply to message #170688] Tue, 20 June 2006 10:27 Go to previous message
I'm now trying to get the content assist for my editor.
I have watched how the XML DOM Model is implemented and some questions
remains:
- Where should I start in order to create a DOM Model?
- What are the Adapters/AdapterFactory for?
- My idea is that the parser parse a document into regions, the adapters
are here to provide a structured region document -> DOM Model
conversion. Am i right?
- What are the different steps in order to provide content assist?
- How does the XML plugin provides a schema based content assist?
Thanks for any help.
Alban
Previous Topic:HTML validation error into the Problems view?
Next Topic:Pulling XML editing features from WTP to eclipse IDE layer
Current Time: Sat Nov 08 01:52:41 EST 2025
Powered by FUDForum. Page generated in 0.04588 seconds
