Home » Eclipse Projects » RCP Testing Tool » [SOLVED] Working with Dynamic variables [Get the tab name ](Working with Dynamic variables [Get the tab name ])
[SOLVED] Working with Dynamic variables [Get the tab name ] [message #1707709] Tue, 08 September 2015 12:10 Go to next message
Hi Folks,
in the application under test when I save a 'New Project' the application change the editor name in automatic way .
From editor "New trade" to "Trade XXXX" where XXXX is an autoincrement number variable.
index.php/fa/23180/0/
I need to store this variable because I need to run the test cases more times and with a static variable it is not possible.
I used the following portion of code
with [get-tab-folder -index 1] {
let [val item [get-property activePage]]
show-alert $item
but the data stored it is not what I want.
index.php/fa/23181/0/
Any idea ?
Thank you in advance buddies !
[Updated on: Thu, 08 October 2015 07:23] by Moderator
Re: Working with Dynamic variables [Get the tab name ] [message #1707739 is a reply to message #1707709] Tue, 08 September 2015 22:15 Go to previous messageGo to next message
Hi Angelo,
Please add -raw argument to get-property command:
let [val item [get-property activePage -raw]]
show-alert $item
Kind regards,
Ulyana.
icon14.gif  Re: Working with Dynamic variables [Get the tab name ] [message #1707758 is a reply to message #1707739] Wed, 09 September 2015 03:59 Go to previous messageGo to next message
It works ! Thank you Ulyana ! you rock !
Re: Working with Dynamic variables [Get the tab name ] [message #1709520 is a reply to message #1707758] Tue, 29 September 2015 02:53 Go to previous message
Hi Angelo,
Happy to hear it, you're welcome!
Kind regards,
Ulyana.
Previous Topic:Subject closed : Configuration Maven 3.1.1 and Maven plugin rcptt
Next Topic:Download Archive of RCPTT
Current Time: Mon Jul 21 12:45:29 EDT 2025
Powered by FUDForum. Page generated in 0.08223 seconds
