Home » Eclipse Projects » NatTable » Cell Text Formatting in Nattable
Cell Text Formatting in Nattable [message #1709254] Fri, 25 September 2015 07:19 Go to next message
I am using CustomLineBorderDecorator with Textpainter for Cells of some Columns to draw line either to left side or top of the Cell in Nattable,
configRegistry.registerConfigAttribute(CellConfigAttributes.CELL_PAINTER, new CustomLineBorderDecorator(new TextPainter(), new BorderStyle(1, GUIHelper.COLOR_BLUE,
                        LineStyleEnum.SOLID)),DisplayMode.NORMAL);
Now the text of cells of one of these Columns whose rows are spanned i have to format like below :
First Line Of Cell
Second Line of Cell
Third Line of Cell
How it can be done ??
I found RichTextCellPainter from latest Nattable SNAPSHOT.
But When I applied it I got two Problems:
- spanned cell border is appearing, and
-after mouse click text of the cell is disappearing
What should I do to fix this and How RichTextCellPainter be used to get above Format???
Re: Cell Text Formatting in Nattable [message #1709260 is a reply to message #1709254] Fri, 25 September 2015 08:07 Go to previous messageGo to next message
I don't understand what you mean with that. What border? Where? How does your labels look like?
Is there an editor involved? Otherwise I don't understand why text should vanish on click. It doesn't in the examples.
The RichTextCellPainter is able to format HTML markup code. So you need to add the necessary tags. This can for example be done via MarkupDisplayConverter.
I think you need to checkout the sources to get the details and have a look at the example in _424_NebulaRichTextIntegrationExample.
Re: Cell Text Formatting in Nattable [message #1709412 is a reply to message #1709260] Mon, 28 September 2015 05:48 Go to previous messageGo to next message
I have attached image showing above Problems
(First Column has Labels LEFT_LINE_BORDER_LABEL and TOP_LINE_BORDER_LABEL as well to get Borders)
                new CustomLineBorderDecorator(new RichTextCellPainter(true), new BorderStyle(1, GUIHelper.COLOR_BLUE,
                DisplayMode.NORMAL, firstColumn);
where do I find This " _424_NebulaRichTextIntegrationExample" ??
  • Attachment: totest.png
    (Size: 10.69KB, Downloaded 274 times)
Re: Cell Text Formatting in Nattable [message #1709422 is a reply to message #1709412] Mon, 28 September 2015 07:05 Go to previous messageGo to next message
I suppose you are talking about the gray lines? You should wrap the RichTextCellPainter in a BackgroundPainter. The current implementation of TextCellPainter is itself a BackgroundPainter (which is IMHO not the best design regarding the painters and might be changed in the future).
Re: Cell Text Formatting in Nattable [message #1709431 is a reply to message #1709422] Mon, 28 September 2015 07:49 Go to previous message
Thank you very much... after wraping with BackgroundPainter everything is working fine.
Previous Topic:Quick Search feature in the Excel like filters
Next Topic:Automated Testing Recorder for NatTable?
Current Time: Tue Jul 22 02:15:41 EDT 2025
Powered by FUDForum. Page generated in 0.08866 seconds
