Home » Eclipse Projects » RCP Testing Tool » Running Using the Ant file causes BundleException
Running Using the Ant file causes BundleException [message #1709163] Thu, 24 September 2015 10:45 Go to next message
I copied the sample cmd and Ant files to run my tests with my AUT, replacing the variables to point to the same locations. When I run it with my bat file, the test runs beautifully. However, when I run it using Ant, I get a log file full of "BundleException: Could not resolve module" exceptions.
Is this a common problem? How do I fix it?
Re: Running Using the Ant file causes BundleException [message #1709225 is a reply to message #1709163] Fri, 25 September 2015 02:10 Go to previous message
This is not a common problem, in order to investigate it could you please attach log files, both scripts and if it is possible the whole runner results folder.
Please let me know if you have any questions.
[Updated on: Fri, 25 September 2015 02:11] by Moderator
Previous Topic:Timeout error: AUT doesn't respond
Next Topic:Initial button click on AUT start
Current Time: Mon Jul 21 02:04:58 EDT 2025
Powered by FUDForum. Page generated in 0.06001 seconds
