Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Realign ragged-left TableEditor after update(Or: how to re-layout a TableEditor?)
Realign ragged-left TableEditor after update [message #1708612] Fri, 18 September 2015 02:43 Go to next message
Dear list,
I injected a TableEditor inside a SWT Table, with ragged-left alignment (SWT.RIGHT).
Something like:
final TableEditor editor = new TableEditor(table);
editor.horizontalAlignment = SWT.RIGHT;
editor.setEditor(toDisplay, item, 1);
toDisplay is a 2x1 GridLayout composite with two children:
  1. a dynamic Label
  2. a button
My issue is: when the dynamic label updates (gets wider), the toDisplay wrapper composite shifts outside of the table column instead of realigning as a good ragged-left boy [a screenshot of this behaviour is attached].
Layout data for both children is set via:
GridDataFactory.fillDefaults().create()
The button has a SelectionListeners which updates the text, then lays-out the parent composite.
It seems all combinations of .pack() and .layout() do not affect the editor.
Any idea of what might help?
Thanks for the help,
-Piero
[Updated on: Fri, 18 September 2015 02:59] by Moderator
Re: Realign ragged-left TableEditor after update [message #1708649 is a reply to message #1708612] Fri, 18 September 2015 07:48 Go to previous message
Solution is: re-set the minimum width of the TableEditor and re-lay it out:
editor.minimumWidth = composite.computeSize(SWT.DEFAULT, SWT.DEFAULT).x;
editor.layout();
See: http://stackoverflow.com/questions/32645683/re-align-ragged-left-swt-tableeditor-after-content-updated
[Updated on: Fri, 18 September 2015 07:48] by Moderator
Previous Topic:How to set id`s to org.eclipse.swt.widgets.Table items and rows
Next Topic:SWT API only Jar
Current Time: Sun Jul 20 23:30:37 EDT 2025
Powered by FUDForum. Page generated in 0.08052 seconds
