Home » Modeling » Papyrus » API for creating and accessing uml diagrams(I am looking for a starting point how to programatically create diagrams in my existing model)
API for creating and accessing uml diagrams [message #1708013] |
Fri, 11 September 2015 08:59  |
can anybody point me such a starting point? I do not need much more than
- create new diagram
- insert existing model entities
- automatically layout
=> these steps are possible clicking through the gui, but i could not find out how to do it programmatically from my plugin. There must be an object factory for diagrams or something like that. I would be grateful for any help.
best regards
Hans
Re: API for creating and accessing uml diagrams [message #1708180 is a reply to message #1708013] |
Mon, 14 September 2015 08:10   |
For displaying existing elements in a Diagram, you have two options:
- GMF ViewService: you need to know the semantic element to display, and the target GMF View (e.g. specific compartment when dropping a Property in a Class). You also need the graphical hint to create (Which might be complex to obtain in a generic way)
Example:
EObject objectToDisplay = ...;
View targetView = ...; //May be the diagram or a diagram element (Compartment...)
ViewService viewService = ViewService.getInstance();
String hint = "..."; //e.g. "2008" for a Class in a Class Diagram
PreferencesHint diagramPrefHint = UMLDiagramEditorPlugin.DIAGRAM_PREFERENCES_HINT; //There is one for each kind of diagram
Node newNode = ViewService.createNode(targetView, objectToDisplay, hint, diagramPrefHint);
This approach doesn't require the diagram to be opened (You work directly at the notation model level), but it may be complex to get all the required info (e.g. exact target View and semantic Hint)
- DropObjectsRequest: this one is much simpler to use, as it will behave exactly like it would if you manually dropped an element from the ModelExplorer to the Diagram. You only need to specify the Semantic EObject, the target element (EditPart) and the mouse coordinates (Optional, especially if you rely on the automatic layout later on)
Example:
EditPart targetEditPart = ...;
Element objectToDisplay = ...;
DropObjectsRequest dropObjectsRequest = new DropObjectsRequest();
List<Element> list = Collections.singletonList(elementToShow)
dropObjectsRequest.setObjects(list);
dropObjectsRequest.setLocation(new Point(20, 100 * position));
Command commandDrop = targetEditPart.getCommand(dropObjectsRequest);
This second approach does a little bit more than displaying, as it will go through the entire Drag & Drop mechanism, which is customizable in Papyrus. So in some cases, you may get a graphical popup asking for a choice (When several drop strategies are available). You can disable this popup (and always use the default strategy) by adding a parameter to the drop request:
org.eclipse.papyrus.infra.gmfdiag.common.utils.RequestUtils.setUseGUI(dropObjectsRequest, false)
(Note that all the code given as examples are untested fragments. In any case, you need to wrap execution in a Transaction, using the EditingDomain, CommandStack and Commands)
Regarding the Automatic Layout, we don't provide anything specific in Papyrus. All layout actions are natively provided by either GEF or GMF, or extensions such as Zest or Eclipse Layout Kernel (ELK)
HTH,
Camille
Re: API for creating and accessing uml diagrams [message #1708536 is a reply to message #1708180] |
Thu, 17 September 2015 06:45   |
Thank you for your answers! That helped me much, I got started but still have problems; probably I am not walking on the intended paths. Here I describe my first results, maybe other users can benefit.
Johans post led me to the CreateClassDiagramCommand class that is the starting point for creating a class diagram.
Comment copied from the superclass:
* Command creating a new GMF diagram in Papyrus. This command is intended to be used in eclipse
* extensions.
But: just calling "cmd.createDiagram()" failed. In the debugger I saw that the policyChecker's "applicableViewpoints" contains a Viewport that has icon and name already set:
// just for inspecting:
// ViewPrototype proto = ViewPrototype.get(cmd.getCreatedDiagramType(), myComponent, myComponent);
and this does not match the matching criteria implemented in policyCheckers "matches()" method (bug or wrong usage?).
I finally was able to create a class diagram by taking the prototype from policyCheckers list "getPrototypesFor(myComponent)"; I took that one with "PapyrusUMLClassDiagram" (cmd.getCreatedDiagramType() ) as implementationID, and called
Diagram myDiagram=cmd.createDiagram(modelSet, myComponent, myComponent, proto, name);
that works and creates an inner class diagram within myComponent. For creating and inserting nodes I need, as Camille described above, its (appropriate!?) visual_id, that is what I not yet understand. The code below works for inserting classes in my inner class diagram:
TreeIterator<EObject> objIterator = myComponent.eAllContents();
while (objIterator.hasNext()) {
EObject eachObject = objIterator.next();
int typeHint=XIDLDiagramUtil.getNodeVisualID(myDiagram,eachObject);
TransactionalEditingDomain ted=TransactionUtil.getEditingDomain(myDiagram);
if (typeHint >0 && ted != null){
ted.getCommandStack().execute(new RecordingCommand(ted){
@Override protected void doExecute(){
Node newNode = ViewService.createNode(myDiagram, eachObject,Integer.toString(typeHint), diagramPrefHint);
System.out.println(newNode.getType()+" created and inserted into "+myDiagram.getName());
} ); // end inline override
else
System.out.println(eachObject+" is not represented.");
return myDiagram;
But not for Generalizations. As visual_ID for that I take GeneralizationEditPart.VISUAL_ID, do I need a different target view?
Here is my delegate for retreiving the visual id.
private static int getNodeVisualID(Diagram myDiagram, EObject eObject) {
int hint=org.eclipse.papyrus.uml.diagram.clazz.part.UMLVisualIDRegistry.getNodeVisualID(myDiagram,eObject);
if(hint>0)
return hint;
if (UMLPackage.eINSTANCE.getGeneralization().isSuperTypeOf(eObject.eClass())) {
return GeneralizationEditPart.VISUAL_ID;
return -1;
That is quite complicated and I needed to search a lot around in the code - is there no api-documentation that I can rely on? How could I know about the command classes and the visual_id registry ... more hints would be helpfull.
best
Hans
PS
there seems to be a little bug that in line 336 of AbstractPapyrusGmfCreateDiagramCommandHandler; it does abort on viewPrototype==null but the callee newer answers null but a special "UNAVAILABLE_VIEW" instead.
[Updated on: Thu, 17 September 2015 07:00] by Moderator
Re: API for creating and accessing uml diagrams [message #1708562 is a reply to message #1708546] |
Thu, 17 September 2015 09:09  |
in between I managed to implement the drop-variant of my task and the auto-arrange. Here is the code (also based on post http://stackoverflow.com/questions/11968509 ) that is probably not absolutely clean (maybe it works only because I opened the concerned editPart just before):
Shell myShell=PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShell();
EditPart editPart = OffscreenEditPartFactory.getInstance().createDiagramEditPart(myDiagram, myShell);
//dropObjectsRequest.setLocation(new Point(20, 100 ));
org.eclipse.gef.commands.Command commandDrop = editPart.getCommand(dropObjectsRequest);
if(commandDrop!=null && commandDrop.canExecute())
commandDrop.execute();
List<EditPart> editParts = CollectionUtil.createNewSequence();
editParts.add(editPart);
ArrangeRequest request = new ArrangeRequest(ActionIds.ACTION_ARRANGE_ALL, LayoutType.RADIAL);
request.setPartsToArrange(editParts);
org.eclipse.gef.commands.Command cmdArrange = editPart.getCommand(request);
if (cmdArrange != null)
cmdArrange.execute();
Current Time: Sun Jul 20 22:42:55 EDT 2025
Powered by FUDForum. Page generated in 0.09203 seconds
