Home » Eclipse Projects » e(fx)clipse » How to create a simple custom window with efx.window.root.fxml
How to create a simple custom window with efx.window.root.fxml [message #1708431] |
Wed, 16 September 2015 08:51  |
Hi Tom,
I would like to create an e4 Application with 2 menu bars that are placed on top of one another. The top menu bar (Main menu) will be populated by the menus and menu items defined in the application model. The lower (secondary) menu bar will be populated by code (legacy stuff).
My first approach to this was to use a tool control in a window trim to load the secondary menu bar. That looks pretty good but doesn't get me very far, because I need this slot for the tool bar (adding a second window trim - top for the tool bar will overwrite the first one).
My second approach was to use efx.window.root.fxml to get control over the window. I looked at the compensator example and was able to copy this approach using DefaultTrimmedWindowPane. Unfortunately (at least for me ) DefaultTrimmedWindowPane is styled to look very different from a standard JavaFX frame. This is cool, but my customers would rather have a "normal" stage which just has a second MenuBar below the first.
I guess I need to implement my own Frame (or TrimmedWindow). What I don't understand here is what to do with all the methods in Frame (except setClientArea). setTitle, setResizable, etc. are methods I would typically forward to the stage, or not? If so, can I inject the stage or do I need to create it?
What do I gain from having to use a Frame or TrimmedWindow? Since efx.window.root.fxml accepts an fxml, I would probably be perfectly happy with something like this:
<BorderPane xmlns="http://javafx.com/javafx/8.0.40" xmlns:fx="http://javafx.com/fxml/1">
<top>
<VBox maxWidth="1.7976931348623157E308">
<children>
<Pane id="menu-bar-area" maxWidth="1.7976931348623157E308" />
<Pane fx:id="secondaryMenuBar" maxWidth="1.7976931348623157E308" />
</children>
</VBox>
</top>
<center>
<FillLayoutPane id="client-area"/>
</center>
</BorderPane> If I could use a BorderPane directly, I would not have to create a new class to add some more ui elements to my window.
I will explore further. In the meantime any help/hints are very welcome!
Christoph
Re: How to create a simple custom window with efx.window.root.fxml [message #1708433 is a reply to message #1708431] |
Wed, 16 September 2015 09:09   |
Use NativeDecoratedTrimmedWindow instead of DefaultTrimmedWindowPane
this should have native window but still allows you to customize the
window content?
Tom
On 16.09.15 14:51, Christoph Keimel wrote:
> Hi Tom,
> for me ;)) DefaultTrimmedWindowPane is styled to look very different
> first.
> <top>
> <children>
> </children>
> </VBox>
> </top>
> <center>
> <FillLayoutPane id="client-area"/> </center>
> Christoph
Re: How to create a simple custom window with efx.window.root.fxml [message #1708437 is a reply to message #1708433] |
Wed, 16 September 2015 09:17   |
To keep the native window decorations you need to set an explicit
"efx.window.stagestyle"
Tom
> window content?
> Tom
>> Hi Tom,
>> first.
>> <top>
>> <children>
>> </children>
>> </VBox>
>> </top>
>> <center>
>> Thanks,
>> Christoph
Re: How to create a simple custom window with efx.window.root.fxml [message #1708438 is a reply to message #1708433] |
Wed, 16 September 2015 09:25   |
Ok the NativeDecoratedTrimmedWindow is not as flexible as the
DefaultTrimmedWindowPane, we'd have to make it a bit clever so I guess
rolling you custom implementation of TrimmedWindow is the easiest
solution for now. Please file a feature request so that we can make the
NativeDecoratedTrimmedWindow more customizable.
Tom
> window content?
> Tom
>> Hi Tom,
>> first.
>> <top>
>> <children>
>> </children>
>> </VBox>
>> </top>
>> <center>
>> Thanks,
>> Christoph
Re: How to create a simple custom window with efx.window.root.fxml [message #1708663 is a reply to message #1708550] |
Fri, 18 September 2015 09:20   |
The simpler the better - the look up you describe is similar to the how
the TrimmedWindows work.
Tom
On 17.09.15 14:06, Christoph Keimel wrote:
> Hi Tom
> Yeah, with this solution you can only determine the location of the
> client-area. The trims will always be at the borders of this
> client-area. In my case I only want to fiddle with the menu, so that is
> ok. But let's consider this use case: You want your client-area to be
> deep in the scene graph and you have created lots of stuff around it.
> You would now probably want your trims to be at the outside of the whole
> construct and not just on the outside of the client-area. So I think you
> are correct with your assumption.
> We could enable trim-location-flexibility by doing the id lookups
> directly in WWindowImpl, much like I proposed to do it in
> WWindowImpl#setMainMenu (i.e. rootPane.lookup("#top-trim-area") in
> WWindowImpl#setTopTrim). An advantage of this approach is that I think
> it would be easier to understand, because all you need to know when you
> create the FXML are the ids you need to set. The rest of the magic
> happens in the FXML controller and is up to the developer. You don't
> need to know about Frame, TrimmedWindow, DefaultTrimmedWindow, etc. If
> you want you can do the layout in SceneBuilder without being forced to
> import any libraries, which is nice if you have separated FXML designers
> and ui coders.
> Or am I missing something?
> Christoph
Current Time: Mon Jul 21 07:49:23 EDT 2025
Powered by FUDForum. Page generated in 0.05890 seconds
