Home » Modeling » Papyrus » SysML full ports (nested ports)
SysML full ports (nested ports) [message #1652001] Thu, 05 March 2015 11:42 Go to next message
How do I model full ports in the ibd diagram - I was hoping I would be able to drag a port on top of a port to model this? is this available? Thanks!
Re: SysML full ports (nested ports) [message #1652043 is a reply to message #1652001] Thu, 05 March 2015 12:07 Go to previous messageGo to next message
Papyrus currently supports SysML 1.1/1.2. FullPorts/ProxyPorts have been introduced in SysML 1.3/1.4
Papyrus 1.1 (In June 2015) will implement SysML 1.4
Camille
Re: SysML full ports (nested ports) [message #1653320 is a reply to message #1652043] Fri, 06 March 2015 02:00 Go to previous messageGo to next message
Thanks!
Re: SysML full ports (nested ports) [message #1696262 is a reply to message #1652043] Sun, 24 May 2015 13:54 Go to previous messageGo to next message
I installed Papyrus 1.1 RC1 (Eclipse 4.5 RC2a) to test the announced SysML 1.4 capability. But I do not discover any SysML features newer than SysML 1.1.
Will SysML 1.4 be part of the final 1.1 release?
Re: SysML full ports (nested ports) [message #1696375 is a reply to message #1696262] Tue, 26 May 2015 03:56 Go to previous messageGo to next message
SysML 1.4 is still under active development in Papyrus. It will not be part of the official release, but "may" be provided as an Extra-plugin in either Mars (June) or Mars SR1 (September), depending on the progress we can make on it
Camille
Re: SysML full ports (nested ports) [message #1696658 is a reply to message #1696375] Wed, 27 May 2015 12:37 Go to previous messageGo to next message
Hi Camille,
thank you for the answer. I will continue to stay tuned.
BTW, if you need a tester for the sysml 1.4 editor, please feel free to contact me.
/Carsten
Re: SysML full ports (nested ports) [message #1708385 is a reply to message #1696375] Wed, 16 September 2015 03:26 Go to previous messageGo to next message
I have installed papyrus 1.1.2 RC3, but Nested Ports feature seems not yet implemented, is itcorrect? Papyrus 1.1.2 (in 25 September 2015) will implement SysML 1.4?
In addition, where can I find an example (or explanation) that shows how to apply a <<ItemFlow>> onto a connector of a IBD diagram?
Nicola
Re: SysML full ports (nested ports) [message #1708498 is a reply to message #1708385] Thu, 17 September 2015 03:48 Go to previous messageGo to next message
Hi Nicola,
Papyrus Mars still officially provides SysML 1.1/1.2. The development of SysML 1.4 is still work-in-progress, and is a separate component (That can be installed in parallel to SysML 1.1/1.2). This extra component can be installed on top of Papyrus 1.1.1/1.1.2 (Mars SR1), but you need to do this manually.
Camille
Re: SysML full ports (nested ports) [message #1708501 is a reply to message #1708498] Thu, 17 September 2015 04:19 Go to previous messageGo to next message
Hi Camille,
how can I get this separate component? Is there any example of model somewhere?
Thanks a lot,
Nicola
Re: SysML full ports (nested ports) [message #1708510 is a reply to message #1708501] Thu, 17 September 2015 05:06 Go to previous messageGo to next message
you can find the Uspdatesite of SysML1.4
https://hudson.eclipse.org/papyrus/view/Sysml/job/papyrus-sysml-nightly-build/
SysML has got is own gerrtit org.eclipse.papyrus-sysml and its a maling list papyrus-sysml-users@eclipse.org.
Re: SysML full ports (nested ports) [message #1708915 is a reply to message #1708510] Tue, 22 September 2015 09:00 Go to previous message
Patrick gave you the link to the nightly build on hudson.
You will find the update site link in the description.
For information, the correct nighlty update site is here : https://hudson.eclipse.org/papyrus/view/Sysml/job/papyrus-sysml-nightly-build/ws/releng/org.eclipse.papyrus.sysml14.p2/target/repository/
I would recommend you to test with the nightly product, you can find the one you need here : https://hudson.eclipse.org/papyrus/view/Sysml/job/papyrus-sysml-nightly-build/ws/releng/org.eclipse.papyrus.sysml14.product/target/products/
If you got any problem you can fill a bug in the tracker.
Do not forget to Specify [SysML 1.4] at the start or the bug title
Benoit
Previous Topic:TimeEvent value setting
Next Topic:Newbie question! I've downloaded Papyrus-Update-1.1.2RC5.zip; now what?
Current Time: Tue Sep 16 17:42:22 EDT 2025
Powered by FUDForum. Page generated in 0.07800 seconds
