Home » Newcomers » Newcomers » Problems with GWT demo project(Remote Procedure Call - Failure)
Problems with GWT demo project [message #815983] Thu, 08 March 2012 04:28 Go to next message
I'm trying to run guest book GWT demo project with little success.
I run the project starts but when I try to submit the page I get the following error.
Sending name to the server
GWT User
Server replies
An error occurred while attempting to contact the server.
Please check your network connection and try again.
I'm running the project locally
This is a printout of the console
mar. 08, 2012 9:25:37 AM com.google.apphosting.utils.jetty.JettyLogger warn
WARNING: Error for /guestbook/greet
java.lang.VerifyError: Expecting a stackmap frame at branch target 17 in method guestbook.server.GreetingServiceImpl.greetServer(Ljava/lang/String;)Ljava/lang/String; at offset 4
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.mortbay.jetty.servlet.Holder.newInstance(Holder.java:153)
at org.mortbay.jetty.servlet.ServletHolder.initServlet(ServletHolder.java:428)
at org.mortbay.jetty.servlet.ServletHolder.getServlet(ServletHolder.java:339)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1166)
at com.google.appengine.tools.development.HeaderVerificationFilter.doFilter(HeaderVerificationFilter.java:35)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1157)
at com.google.appengine.api.blobstore.dev.ServeBlobFilter.doFilter(ServeBlobFilter.java:60)
at com.google.apphosting.utils.servlet.TransactionCleanupFilter.doFilter(TransactionCleanupFilter.java:43)
at com.google.appengine.tools.development.StaticFileFilter.doFilter(StaticFileFilter.java:122)
at com.google.appengine.tools.development.BackendServersFilter.doFilter(BackendServersFilter.java:97)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:388)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:182)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:765)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:418)
at com.google.appengine.tools.development.DevAppEngineWebAppContext.handle(DevAppEngineWebAppContext.java:78)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at com.google.appengine.tools.development.JettyContainerService$ApiProxyHandler.handle(JettyContainerService.java:363)
at org.mortbay.jetty.Server.handle(Server.java:326)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:542)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:938)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:755)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:218)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:404)
at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:409)
at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThreadPool.java:582)
Any help would be greatly appreciated.
Re: Problems with GWT demo project [message #835733 is a reply to message #815983] Tue, 03 April 2012 11:55 Go to previous messageGo to next message
I was getting the same error as you. I found a site that had a solution that worked for me: java . dzone . com/articles/javalangverifyerror-expecting
You can either switch to JDK 6 (I haven't tried that one), or you can add a VM argument to your installed JRE. In Eclipse go to:
Window->Preferences->Java->Installed JREs then select the JRE you are using and click Edit. Add this VM argument to the Default VM Arguments text field:
-XX:-UseSplitVerifier
Another user also said there is a patch that fixes this for you, but I'm not familiar enough with Eclipse to know how to apply the patch. Here's the site though:
bugs . eclipse . org/bugs/show_bug.cgi?id=362591
(Sorry for the spaces in the links, apparently you have to post 25 messages before links are enabled in this forum.)
Re: Problems with GWT demo project [message #838196 is a reply to message #835733] Fri, 06 April 2012 14:18 Go to previous messageGo to next message
I'm running JDK 7, Eclipse (Indigo), and GWT 2.4.0. I just wanted to confirm that the above solution worked for me.
I added -XX:-UseSplitVerifier and it's working for me now.
Thanks for the help!
Re: Problems with GWT demo project [message #1708375 is a reply to message #838196] Wed, 16 September 2015 00:58 Go to previous messageGo to next message
Hi I met this error. I use Gwt 2.7 and jdk 1.7. Please help me!
Re: Problems with GWT demo project [message #1708460 is a reply to message #1708375] Wed, 16 September 2015 14:21 Go to previous message
Not sure what, if anything, this has to do with Eclipse. Would you
explain a little more?
Previous Topic:Using the Android MQTT client sample
Next Topic:JVM not suitable
Current Time: Wed Jul 23 06:09:22 EDT 2025
Powered by FUDForum. Page generated in 0.11260 seconds
