Home » Eclipse Projects » Sirius » Keep tool selection (The "Select" tool is selected after using any other tool. )
Keep tool selection [message #1708426] Wed, 16 September 2015 08:14 Go to next message
If I do have multiple tools and the user chooses one (e.g. Edge creation tool) and uses it by creating a connection between to edges, the "Select" tool is selected after using it. So creating more than one connection without re-seleting the "Connection" tool is not possible.
Is there a way to specify it in the Specification Editor that the tool selection is kept?
Thanks!
Re: Keep tool selection [message #1708428 is a reply to message #1708426] Wed, 16 September 2015 08:35 Go to previous message
Hi Martin,
Le 16/09/2015 14:14, Martin Schreiber a écrit :
> The "Select" tool is selected after using any other tool. If I do have
As documented in [1]: if you want to apply the same tool several times
in a row, simply hold the Ctrl key pressed while using it; it will stay
«armed» until you release the Ctrl key or select another tool.
This also works for Edge creation tools.
Note that on Mac OS, you have to use Cmd and not Ctrl.
> selection is kept?
The keybord shortcut is here for all tools in the palette of any Sirius
designers, there is no corresponding parameter in the specification model.
> Thanks!
Maxime - Obeo
[1]
https://www.eclipse.org/sirius/doc/user/diagrams/Diagrams.html#UsingTheToolsFromThePalette
Previous Topic:can we have an elements for the main diagram elemnt
Next Topic:java extension
Current Time: Wed Jul 23 23:33:25 EDT 2025
Powered by FUDForum. Page generated in 0.03793 seconds
