Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Forms] custom control apis deprecated?
[EMF Forms] custom control apis deprecated? [message #1708204] Mon, 14 September 2015 11:49 Go to next message
I have tried to use the EMF Forms framework for a simple SWT based UI, but I found the need for some custom controls. I noticed that large parts of the API for custom controls are annotated as @Deprecated, but unfortunately without any message. Is there already a new API I should be using? Or will this remain like it is until the next major release?
Knut
Re: [EMF Forms] custom control apis deprecated? [message #1708277 is a reply to message #1708204] Tue, 15 September 2015 03:19 Go to previous messageGo to next message
Hi Knut,
maybe to make sure that you are looking for the right thing: Do you want
to replace some of the existing controls with your custom ones? In this
case, you should implement a custom renderer for those, there is no need
to use custom controls here.
http://eclipsesource.com/blogs/tutorials/how-to-customize-emf-forms/#customizecontrols
Best regards
Jonas
Am 14.09.2015 um 17:49 schrieb Knut Wannheden:
> Cheers,
> Knut
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: [EMF Forms] custom control apis deprecated? [message #1708294 is a reply to message #1708277] Tue, 15 September 2015 04:21 Go to previous message
Hi Jonas,
Yes, that article looks quite helpful. I had only found this one before: http://eclipsesource.com/blogs/tutorials/emf-forms-custom-control-areas/. It seems like it achieves something very similar in the end.
I will go ahead and implement a custom renderer instead.
Knut
Previous Topic:[ECP] Neon/Mars versions look weird
Next Topic:re
Current Time: Sun Jul 20 23:54:36 EDT 2025
Powered by FUDForum. Page generated in 0.03881 seconds
