Home » Modeling » EMF » best practice displaying EMF-elements in tables(Looking for the best way to display EMF Elements in UI)
best practice displaying EMF-elements in tables [message #1708195] Mon, 14 September 2015 09:22 Go to next message
I came into a project which uses EMF for modeling and Vaadin for creating the UI. For displaying the data in tables the developers chose GlazedLists. Some of the columns are editable, a change in one of those fields leads to changes in other (non-editable) fields. The values are stored in an vector, which is basically just a List of Doubles.
What I expected is this:
When changing a value in the editable fields there starts a notification chain and all derived values refresh. I already managed to do that. My problem is, that they are not displayed in the table without having refreshRowCache called by any method (.setValue, .set(i,.get(i)) [like recommended in GlazeLists FAQ], ...). But using refreshRowCache makes everything quite slow and I am not sure if that is really necessary for only displaying some changed values (without adding/removing anything).
So what I want to know is, what is Your best practice to display data from Your EMF-models in tables.
Thanks in advance
Patric
Re: best practice displaying EMF-elements in tables [message #1708273 is a reply to message #1708195] Tue, 15 September 2015 03:12 Go to previous message
Patric,
For binding to Eclipse Viewers, notifications are processed by
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvider.notifyChanged(Notification),
i.e., by the content provider that is used to provide content for the
views. It tries to update the Viewer with minimal effort depending the
type Viewer and what kind of updates it support efficiently...
On 14/09/2015 9:01 PM, Patric Bayer wrote:
> Doubles.
> Thanks in advance
> Patric
Previous Topic:When is an eObject's container set?
Next Topic:eContainer in other resource
Current Time: Mon Jul 21 05:58:32 EDT 2025
Powered by FUDForum. Page generated in 0.07933 seconds
