Home » Modeling » TMF (Xtext) » Control Variable Assignments
Control Variable Assignments [message #1708165] Mon, 14 September 2015 06:25 Go to next message
Hi everyone,
I have a problem to control the values of variables. In my DSL I have a Declarationpart ("VAR"), where a variable can be declared and also assigned. In the StatementBlock of the "BEGIN" part the value of a variable can be changed or assigned. How can I recognize or control the values of the variables in such a way that the last assignment should be the current/desired one?
My first idea was to store them in a hashmap. But I was not sure how to handle it if a statement gets deleted.
Thank you in advance!
PROGRAM test;
VAR
    int : a := 3;
    int : b ;
    ARRAY [1..4] OF int = tempArray;
BEGIN
    a := 4;
    b := 0;
    tempArray[a] := 1;
ENDPROGRAM
Re: Control Variable Assignments [message #1708175 is a reply to message #1708165] Mon, 14 September 2015 07:40 Go to previous messageGo to next message
hi,
i dont understand this question. can you please explain?
Re: Control Variable Assignments [message #1708178 is a reply to message #1708175] Mon, 14 September 2015 07:48 Go to previous messageGo to next message
I am sorry for the bad explanation.
My problem in general is: How can I detect the current value of a variable?
If I have an assignment in my StatementBlock ("BEGIN") .. the Value should be adapted.
Re: Control Variable Assignments [message #1708179 is a reply to message #1708178] Mon, 14 September 2015 07:53 Go to previous messageGo to next message
what do you mean by detect? ast and generation/interpretation are 2 different things. so what you you actually try to do?
Re: Control Variable Assignments [message #1708182 is a reply to message #1708179] Mon, 14 September 2015 08:12 Go to previous messageGo to next message
it is more an interpretation problem. I want to interpret the value of a variable. If there is a new assignment the value should be updated.
[Updated on: Thu, 01 October 2015 04:52] by Moderator
Re: Control Variable Assignments [message #1708183 is a reply to message #1708182] Mon, 14 September 2015 08:15 Go to previous messageGo to next message
this should work fine with a map
Re: Control Variable Assignments [message #1708184 is a reply to message #1708183] Mon, 14 September 2015 08:16 Go to previous messageGo to next message
Ok thanks. I'll try it out
Re: Control Variable Assignments [message #1708186 is a reply to message #1708184] Mon, 14 September 2015 08:29 Go to previous messageGo to next message
(p.s. depending on your lang the values of the map might be stacks)
or you have maps covering each other.
you may have a look at the EvaluationContext of xbase as well
[Updated on: Mon, 14 September 2015 08:30] by Moderator
Re: Control Variable Assignments [message #1708882 is a reply to message #1708186] Tue, 22 September 2015 04:29 Go to previous messageGo to next message
Hi Christian,
do you know how I can get the current line number of a hover object?
Re: Control Variable Assignments [message #1708899 is a reply to message #1708882] Tue, 22 September 2015 06:49 Go to previous messageGo to next message
org.eclipse.xtext.nodemodel.INode.getStartLine() ??? (NodeModelUtil should give you the node)
Re: Control Variable Assignments [message #1708901 is a reply to message #1708899] Tue, 22 September 2015 07:27 Go to previous messageGo to next message
I want to interpret the value of a variable. For that I override getHoverInfoAsHtml(EObject o). When I have an assignment I try to get the CURRENT position of that variable...But I get the position where the variable was declared:
VAR
   int : a;
BEGIN
    a := 4;
Thats why I wanted to know how to get the current position of the cursor.
[Updated on: Tue, 22 September 2015 07:28] by Moderator
Re: Control Variable Assignments [message #1708903 is a reply to message #1708901] Tue, 22 September 2015 07:30 Go to previous messageGo to next message
go for it
Re: Control Variable Assignments [message #1708905 is a reply to message #1708903] Tue, 22 September 2015 07:32 Go to previous messageGo to next message
The question is HOW to get the current position of the cursor Smile
Re: Control Variable Assignments [message #1708909 is a reply to message #1708905] Tue, 22 September 2015 08:10 Go to previous messageGo to next message
as i said: use nodemodelutils to get the node of the object. and the node for its position
Re: Control Variable Assignments [message #1708911 is a reply to message #1708909] Tue, 22 September 2015 08:18 Go to previous messageGo to next message
I tried that. It doesn't work when I try to hover. As I said: instead of the current variable position I get the position where the variable was declared, which I don't want.
That is why I would like to have the current cursor position; NOT the object position. Is that possible?
Re: Control Variable Assignments [message #1708913 is a reply to message #1708911] Tue, 22 September 2015 08:31 Go to previous messageGo to next message
The you have to take the thing that holds the variable (VariableRef) and not the variable
it is a feature that you get the origin of the object by default
[Updated on: Tue, 22 September 2015 08:33] by Moderator
Re: Control Variable Assignments [message #1708914 is a reply to message #1708913] Tue, 22 September 2015 08:33 Go to previous messageGo to next message
(you might hook deeper in the the hover org.eclipse.xtext.ui.editor.hover.AbstractEObjectHover.getXtextElementAt(XtextResource, int)
Re: Control Variable Assignments [message #1709043 is a reply to message #1708914] Wed, 23 September 2015 10:17 Go to previous messageGo to next message
I cant give the VariableRef to the Hover. It is not working. It is not jumping into my switch query.
And unfortunately I was not able to find an example of getXtextElementAt where I can figure out the current cursor position.
Could you please provide me with a simple example.
Thank you very much!
Re: Control Variable Assignments [message #1709057 is a reply to message #1709043] Wed, 23 September 2015 11:40 Go to previous messageGo to next message
Hi i do not get that
Model:
	greetings+=Greeting*;
Greeting:
	'Hello' name=ID ('from' from=[Greeting])? '!';
public class DispatchingEObjectTextHover2 extends DispatchingEObjectTextHover {
	@Inject
	private MyDslGrammarAccess ga;
	protected Pair<EObject, IRegion> getXtextElementAt(XtextResource resource, int offset) {
		if (resource.getParseResult() != null) {
			ICompositeNode rootNode = resource.getParseResult().getRootNode();
			if (rootNode != null) {
				ILeafNode leafNode = NodeModelUtils.findLeafNodeAtOffset(rootNode, offset);
				EObject sem = NodeModelUtils.findActualSemanticObjectFor(leafNode);
				if (leafNode.getGrammarElement() instanceof CrossReference) {
					CrossReference cr = (CrossReference) leafNode.getGrammarElement();
					if (ga.getGreetingAccess().getFromGreetingCrossReference_2_1_0() == cr) {
						ITextRegion leafRegion = leafNode.getTextRegion();
						return Tuples.create(sem, (IRegion) new Region(leafRegion.getOffset(), leafRegion.getLength()));
		return super.getXtextElementAt(resource, offset);
Re: Control Variable Assignments [message #1709117 is a reply to message #1709057] Thu, 24 September 2015 03:53 Go to previous messageGo to next message
Thank you very much. This helped a lot !!!
Re: Control Variable Assignments [message #1709460 is a reply to message #1709117] Mon, 28 September 2015 10:56 Go to previous messageGo to next message
is it possible to (Hyper-)Link the DSL with a generated (C++) file?
After pressing (e.g.) shift+ctrl+ "a DSL object", I want to jump to specific part of the generated file. Is that feasible?
Re: Control Variable Assignments [message #1709465 is a reply to message #1709460] Mon, 28 September 2015 12:00 Go to previous messageGo to next message
yes
have a look at Hyperlink helper
Re: Control Variable Assignments [message #1709549 is a reply to message #1709465] Tue, 29 September 2015 04:46 Go to previous messageGo to next message
I have this code snippet from a former question. With this the Hyperlinking is appearing but it is not jumping to the corresponding place in the generated file. How can I specify this?
class IRLLinkHelper extends HyperlinkHelper {
	override createHyperlinksByOffset (XtextResource resource, int offset, IHyperlinkAcceptor acceptor) {
		var EObjectAtOffsetHelper eObjectAtOffsetHelper = new EObjectAtOffsetHelper();
		var EObject eObject = eObjectAtOffsetHelper.resolveElementAt(resource, offset);
		if (eObject instanceof VariableDeclaration) {
			val variable  = eObject as VariableDeclaration;
			var CompositeNode adapter = NodeModelUtils.getNode(variable) as CompositeNode;
			val Region region = new Region(adapter.getOffset(), adapter.getLength());
			val URIConverter uriConverter = resource.getResourceSet().getURIConverter();
			val String hyperlinkText = "Variable";
			val URI uri = EcoreUtil.getURI(variable);
			val URI normalized = if (uri.platformResource != false)  uri uriConverter.normalize(uri);
			println("URI " + uri)
			println("normalized " + normalized)
			val XtextHyperlink result = getHyperlinkProvider().get()
			result.setHyperlinkRegion(region);
			result.setURI(normalized);
			result.setHyperlinkText(hyperlinkText);
			acceptor.accept(result);
Re: Control Variable Assignments [message #1709555 is a reply to message #1709549] Tue, 29 September 2015 05:43 Go to previous messageGo to next message
sry that is a question for the tool that provides you the editor for. which tool do you use for c++
Re: Control Variable Assignments [message #1709566 is a reply to message #1709555] Tue, 29 September 2015 06:25 Go to previous messageGo to next message
I do everything in eclipse. I provide you the xtext project and the corresponding c++-project to have a look.
Thank you very much!!
[Updated on: Tue, 29 September 2015 06:28] by Moderator
Re: Control Variable Assignments [message #1709567 is a reply to message #1709566] Tue, 29 September 2015 06:26 Go to previous messageGo to next message
sry i cannot do this for you.
my question was: which tool for c++ do you use?
you have to look how that Tools uris/Hyperlinks look like
Re: Control Variable Assignments [message #1709569 is a reply to message #1709567] Tue, 29 September 2015 06:28 Go to previous messageGo to next message
ok. I use eclipse. So how can I do this with eclipse
[Updated on: Tue, 29 September 2015 07:08] by Moderator
Re: Control Variable Assignments [message #1709581 is a reply to message #1709569] Tue, 29 September 2015 07:51 Go to previous messageGo to next message
as is said: this is a matter of the Editor implementation you use. (e.g. Eclipse CDT)
Re: Control Variable Assignments [message #1709613 is a reply to message #1709581] Tue, 29 September 2015 10:47 Go to previous messageGo to next message
ok thank you!
Re: Control Variable Assignments [message #1709807 is a reply to message #1709613] Thu, 01 October 2015 05:02 Go to previous messageGo to next message
for hyperlinking I have the URI of another file. Jumping to that file is working with:
>> result.setURI(normalized); (see code above)
But how can I specify also the exact position of that referenced (here) variable with e.g. the offset of that variable in the linked file?
What I have is the IASTFileLocation (= path,offset,length)
Thanks in advance
Re: Control Variable Assignments [message #1709814 is a reply to message #1709807] Thu, 01 October 2015 06:34 Go to previous messageGo to next message
i do not get that question. please explain exaclty (based on sample models and generated code) what you are talking about
Re: Control Variable Assignments [message #1709832 is a reply to message #1709814] Thu, 01 October 2015 08:14 Go to previous messageGo to next message
So what I try to do is to tell the XtextHyperlink to consider not only the path of that file as URI (here: curi) but also the position (offset, length) of a sepcific variable (here as IASTFIleLocation location).
The sample project looks like this:
	val ICProject[] cppPrjs = CoreModel.^default.CModel.CProjects;
	var URI curi = null;
	val IIndex index = CCorePlugin.indexManager.getIndex(cppPrjs.head)
	var IIndexFile file = null
	for (f : index.allFiles) {
		if (f.location.toString.contains("IRL_variables")){
			println("file path " + f.location.URI)
			curi = URI.createURI(f.location.URI.toString)
			file = f
	var IASTFileLocation location= null
    val ICProject cproject = CoreModel.getDefault().getCModel().getCProject("IRLSampleProject");
	try {
		var IPath _path = new Path("IRLSampleProject/src-gen/IRL_variables/testfile.cpp")
		var IFile _ifile = ResourcesPlugin.workspace.root.getFile(_path)
		var ITranslationUnit unit = CoreModelUtil.findTranslationUnit(_ifile);
		if (unit == null) {
		    unit = CoreModel.getDefault().createTranslationUnitFrom(cproject, _ifile.getLocation() );
		var IASTTranslationUnit ast = null;
		var IIndex idx = null;
		try {
		    idx = CCorePlugin.getIndexManager().getIndex(cproject);
		} catch (CoreException e) {
	    ast = unit.getAST(index, ITranslationUnit.AST_SKIP_INDEXED_HEADERS);
	    for (a : ast.children){
	    	println("ast ---------------------------->   " + a)
	    	if (a instanceof CPPASTFunctionDefinition){
	    		// Path of that declaration, with offset and length
	    		location = ((a as CPPASTFunctionDefinition).body.children.head as CPPASTDeclarationStatement).declaration.children.get(1).fileLocation
	    if (ast == null) {
	        throw new IllegalArgumentException(_ifile.getLocation().toPortableString() + ": not a valid C/C++ code file");
        e.printStackTrace();
    } catch (FileNotFoundException e) {
	// here I want set the URI with the position of variable that should be linked to
	result.setURI(curi);
Re: Control Variable Assignments [message #1709837 is a reply to message #1709832] Thu, 01 October 2015 08:45 Go to previous messageGo to next message
still the question. where does the hyplink point to? xtext cannot know in which line in a non xtext file an object is or not.
so do you use cdt? or what is the stuff you use? the stuff you use can tell you how the links for the stuff you use look like?!?
thus you should not create an xtext hyperlink but an IHyperlink for the tool you use.
thus this is a question on e.g. cdt and not xtext
Re: Control Variable Assignments [message #1709841 is a reply to message #1709837] Thu, 01 October 2015 09:07 Go to previous messageGo to next message
P.S:
i asumes the nodes in cdt provide offset and length. is so you can have your own ihyperlink method
that calls a job that opens the editor and then calls selectandreveal(offset,length) - the same as
LangaugeSpecific/GlobalUriEditorOpener do
Re: Control Variable Assignments [message #1709842 is a reply to message #1709837] Thu, 01 October 2015 09:08 Go to previous messageGo to next message
oh ok. yes you are right... I am using CDT. Then I'll try it with IHyperlink.
Thanks again.
Re: Control Variable Assignments [message #1709959 is a reply to message #1709842] Fri, 02 October 2015 05:12 Go to previous messageGo to next message
I have solved the problem now in a different way. Instead of fighting with IHyperlink...I got the solution in the context of my first approach. What I did is to link still to the cpp-file. When I jump to that file this file gets my active window. With that I focused a variable/object simply with its offset and length:
if (u != null) {
	val IWorkbenchPage page = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
	val ITextEditor editor = IDE.openEditor(page, _ifile) as ITextEditor;
	editor.selectAndReveal(u.nodeOffset, u.nodeLength);
The problem I have right now is ... that linking/jumping to that generated cpp-file occurs as soon as I click "ctrl" and hover the variable/object. But I want to link when clicking at an object, not during hovering. How can I do this?
Re: Control Variable Assignments [message #1709960 is a reply to message #1709959] Fri, 02 October 2015 05:28 Go to previous messageGo to next message
As i said, you should move that to the open() method of the IHyperlink().
Re: Control Variable Assignments [message #1709962 is a reply to message #1709960] Fri, 02 October 2015 05:37 Go to previous messageGo to next message
That is not the problem. It is working fine. But how can I check if an object is clicked? How can I check a "Clicking" event?
Re: Control Variable Assignments [message #1709963 is a reply to message #1709962] Fri, 02 October 2015 05:40 Go to previous messageGo to next message
no you dont
you simply create the hyperlink
the framework will then call open on it if you click/f3
Re: Control Variable Assignments [message #1709966 is a reply to message #1709963] Fri, 02 October 2015 05:43 Go to previous messageGo to next message
click/f3 is working fine. But is there no event handler for clicking on the editor?
Re: Control Variable Assignments [message #1709973 is a reply to message #1709966] Fri, 02 October 2015 06:30 Go to previous messageGo to next message
hi i do not understand this question. can you please elaborate.
Re: Control Variable Assignments [message #1711007 is a reply to message #1709973] Mon, 12 October 2015 06:06 Go to previous message
Thank you, I solved it.
But I have another important problem. Do you have an idea? :
http://www.eclipse.org/forums/index.php?t=msg&th=1071102&goto=1710948&
Previous Topic:Building current Xtext master branch locally fails
Next Topic:[Xtext] Backslash at end of line
Current Time: Fri Jul 25 23:45:53 EDT 2025
Powered by FUDForum. Page generated in 0.36811 seconds
