Home » Eclipse Projects » Sirius » Only one Edge between two nodes
Only one Edge between two nodes [message #1707173] Wed, 02 September 2015 14:52 Go to next message
I'am working on an extended Version of Petri Nets (new edge types, new nodes).
I've implemented the needed creation Tools but now I can create two edges with the same source and target. Is there an easy way to restrict it or do I have to use Condition Expressions in the creation tool?
EMF diagram and an example are attached.
Thank you in advance!
Alex
  • Attachment: Beispiel.JPG
    (Size: 32.18KB, Downloaded 272 times)
  • Attachment: EMF.JPG
    (Size: 45.78KB, Downloaded 236 times)
[Updated on: Wed, 02 September 2015 14:54] by Moderator
Re: Only one Edge between two nodes [message #1707919 is a reply to message #1707173] Thu, 10 September 2015 10:06 Go to previous messageGo to next message
Le 02/09/2015 20:52, Alexander Schledewitz a écrit :
> Hello,
> nodes).
> EMF:
I guess you forgot the image here ...
> Example:
.... and here
> Best regards,
> Alex
Re: Only one Edge between two nodes [message #1707977 is a reply to message #1707919] Fri, 11 September 2015 03:39 Go to previous messageGo to next message
>> Hello,
>> nodes).
>> EMF:
>> Example:
> ... and here
>> Best regards,
>> Alex
oups sorry. The images were attached but i could not see it from
thunderbird.
Yes, use the precondition and use preSource/preSourceView and
preTarget/preTarget to make a condition on what you are about to select.
Laurent
Re: Only one Edge between two nodes [message #1709147 is a reply to message #1707977] Thu, 24 September 2015 09:10 Go to previous messageGo to next message
Thank you, it worked Smile
Re: Only one Edge between two nodes [message #1743626 is a reply to message #1709147] Sat, 17 September 2016 05:42 Go to previous messageGo to next message
I have a similar problem. I have tried to fix it by:
aql:preTarget.differs(preSource.outgoings -> filter(target))
or
aql:(preSource.outgoings -> filter (target)) -> excludes (preTarget)
But it doesn't work.
Does anybody have a hint, where I am thinking wrong?
Cheers, Xing
[Updated on: Sat, 17 September 2016 09:29] by Moderator
Re: Only one Edge between two nodes [message #1743635 is a reply to message #1743626] Sat, 17 September 2016 08:42 Go to previous messageGo to next message
You provide no repro so ...
Have you checked the source syntax errors? "filter" takes an OclType argument and "target" does not look like a type.
The isUnique iteration can help make uniqueness constraints readable.
Ed Willink
Re: Only one Edge between two nodes [message #1743638 is a reply to message #1743635] Sat, 17 September 2016 09:30 Go to previous messageGo to next message
Hello Ed,
thanks for the answer.
I was referring to the example EMF from above.
But now I fixed it by:
aql:not(preSource.outgoings.target->exists(s | s = preTarget))
Is that ok, or is it not very elegant?
Do I put it in the Node Representation Precondition or the Node Creation Representation?
Because when I go with the curser over the ? of the Node Representation Precondition, it also says "Prevent Creation of the Element", but that is referring to the view, is that correct?
Cheers, Xing
Re: Only one Edge between two nodes [message #1744872 is a reply to message #1743638] Sat, 01 October 2016 03:14 Go to previous message
I am referring in the following to Alexander's EMF model.
The expression I presented in my last post works perfectly.
But I still get an error:
Description: Feature outgoings not found in EClass EObject
Location Problem: EMF Problem
Can I just ignore it? Because it does work exactly how I want it to work. So obviously my expression and therefore "outgoings" must be working, so it mus be found somewhere. And the error does not effect me.
Thank you
Xing
Previous Topic:Working with a container to group model elements by dragging
Next Topic:[AQL] Change Context Back
Current Time: Fri Jul 18 22:20:50 EDT 2025
Powered by FUDForum. Page generated in 0.04945 seconds
