Home » Modeling » ATL » Stereotype attribute using ATL(problem in extracting stereotype attribute using ATL)
Stereotype attribute using ATL [message #1707965] Thu, 10 September 2015 19:03 Go to next message
Hey,
Could someone help me with the code for deriving the Stereotype Attributes name and properties. I have a message which is related to a lifeline. The lifeline is linked to a schedulable resource which is further allocated a hardware processor.
I am using Eclipse Luna and UML 5.0
In the code i am trying to pick the schedulableResource linked to the lifeline and the then the hardware processor allocated to it. But i am not able to do it....
Any help would be appreciated....
Code:
helper context UML!Element def: hasStereotype(stereotype : String) : Boolean =
self.getAppliedStereotypes() -> collect(st | st.name) -> includes(stereotype);
helper context UML!Lifeline def: getLifelineHost (): String =
if (self.hasStereotype('PaRunTInstance'))
then
self.getValue(self.getAppliedStereotype('PaRunTInstance'),'host')
else
endif;
rule MessageToConnector
from
m: UML!Message
using
mosr:UML!MessageOccurrenceSpecification = m.receiveEvent;
llr: UML!Lifeline = mosr.covered.first();
to
c : QNModel!Connector
name<- llr.getLifelineHost()
do
'ruleMessageToConnectorStarts'.println();
'receiver lifeline'.println();
llr.name.println();
It gives me the following error:
org.eclipse.m2m.atl.engine.emfvm.VMException: Operation not found: IN!User.getValue(org.eclipse.m2m.atl.engine.emfvm.lib.OclUndefined,java.lang.String)
at getLifelineHost#11(UML2QN.atl[20:7-20:72])
local variables: self=IN!User
at __applyMessageToConnector#20(UML2QN.atl[94:11-94:32])
local variables: self=UML2QN : ASMModule, link=TransientLink {rule = MessageToConnector, sourceElements = {m = org.eclipse.uml2.uml.internal.impl.MessageImpl@4eee2a3c (name: think time, visibility: <unset>) (messageSort: asynchCall)}, targetElements = {c = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@109a492c (eClass: org.eclipse.emf.ecore.impl.EClassImpl@d060492 (name: Connector) (instanceClassName: null) (abstract: false, interface: false))}, variables = {mosr = org.eclipse.uml2.uml.internal.impl.MessageOccurrenceSpecificationImpl@25da6960 (name: MessageRecv, visibility: <unset>), llr = org.eclipse.uml2.uml.internal.impl.LifelineImpl@688a9461 (name: User, visibility: <unset>)}}, m=IN!think time, c=OUT!<unnamed>, mosr=IN!MessageRecv, llr=IN!User
at __exec__#38(UML2QN.atl)
local variables: self=UML2QN : ASMModule, e=TransientLink {rule = MessageToConnector, sourceElements = {m = org.eclipse.uml2.uml.internal.impl.MessageImpl@4eee2a3c (name: think time, visibility: <unset>) (messageSort: asynchCall)}, targetElements = {c = org.eclipse.emf.ecore.impl.DynamicEObjectImpl@109a492c (eClass: org.eclipse.emf.ecore.impl.EClassImpl@d060492 (name: Connector) (instanceClassName: null) (abstract: false, interface: false))}, variables = {mosr = org.eclipse.uml2.uml.internal.impl.MessageOccurrenceSpecificationImpl@25da6960 (name: MessageRecv, visibility: <unset>), llr = org.eclipse.uml2.uml.internal.impl.LifelineImpl@688a9461 (name: User, visibility: <unset>)}}
at main#24(UML2QN.atl)
Re: Stereotype attribute using ATL [message #1711678 is a reply to message #1707965] Mon, 19 October 2015 04:40 Go to previous message
As the error indicates your getValue call is passing in an OclUndefined i.e. you have not retrieved the stereotype correctly in the method self.getAppliedStereotype('PaRunTInstance'). To get the stereotype correctly you should prefix the Stereotype name with the profile name i.e. PROFILE_NAME::STEREOTYPE_NAME
Ronan
Previous Topic:Get the Attribute name of a Class in ATL
Next Topic:Saving modification of a Map in a function
Current Time: Sun Jul 27 11:35:27 EDT 2025
Powered by FUDForum. Page generated in 0.25574 seconds
