Jenkins Maven CI RCPTT Job failing [message #1707903] |
Thu, 10 September 2015 06:48  |
I get the following error, when I run RCPTT in Jenkins server using Maven.
[INFO] Fail 2 (46) processed. 1 failed. spent: 10:30, 112:52 mins remaining. RcpttTest_CloneFuses_RegionInfo. time: 616080ms Cause: Execution timed out after 300 seconds
[INFO]
[INFO]
[INFO] Connection to AUT is not available. Restarting AUT.
[INFO]
[INFO]
[INFO] AUT-0:Restarting (restartId=1)
[INFO] AUT-0:Product: com.company.qti.project.rcp.project_product
[INFO] AUT-0:Application: com.company.qti.project.rcp.application
[INFO] AUT-0:Architecture: x86_64
[INFO] 64bit arch is selected because AUT uses launcher library
[INFO] "plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.200.v20140116-2212" specified in config file: project.ini
[INFO] /local/mnt/workspace/jenkins-slave/workspace/Test-app-Harshini-TrunkBuildTest/rcptttests/target/aut-ws: AUT arguments: -os ${target.os} -arch ${target.arch} -consoleLog
[INFO] /local/mnt/workspace/jenkins-slave/workspace/Test-app-Harshini-TrunkBuildTest/rcptttests/target/aut-ws: AUT VM arguments: -Dosgi.requiredJavaVersion=1.7 -Xms40m -Xmx1024m -XX:MaxPermSize=512m -Declipse.vm=project.bin
[INFO] Trying to use VM from application's ini file: /prj/iceng/project1/shared/tooling/linux/jdk1.7.0_10/bin
[INFO] Unknown file system layout of Java VM from ini file
[INFO] Fail 3 (46) processed. 2 failed. spent: 10:47, 115:55 mins remaining. RcpttTest_Clone_RegionInfo_multipleTarget. time: 16588ms Cause: Connection is not Available
[INFO] AUT-0: Launch failed. Reason: No launch for configuration: AUT_1
[INFO] AUT-0: For more information check AUT output at '/local/mnt/workspace/jenkins-slave/workspace/Test-app-Harshini-TrunkBuildTest/rcptttests/target/results/aut-console-0_console.log'
[ERROR] Exception in thread "AUT-Worker-0" java.lang.RuntimeException: AUT-0: Launch failed. Reason: No launch for configuration: AUT_1
[ERROR] at org.eclipse.rcptt.runner.util.AutThread.launchAut(AutThread.java:460)
[ERROR] at org.eclipse.rcptt.runner.util.AutThread.restart(AutThread.java:479)
[ERROR] at org.eclipse.rcptt.runner.util.ResultsHandler.restartAutWithMessage(ResultsHandler.java:74)
[ERROR] at org.eclipse.rcptt.runner.util.ResultsHandler.testCompleted(ResultsHandler.java:58)
[ERROR] at org.eclipse.rcptt.runner.ScenarioRunnable.run(ScenarioRunnable.java:101)
[ERROR] at org.eclipse.rcptt.runner.util.AutThread.run(AutThread.java:137)
[ERROR] Caused by: org.eclipse.core.runtime.CoreException: No launch for configuration: AUT_1
[ERROR] at org.eclipse.rcptt.runner.util.AutThread.launchAut(AutThread.java:436)
[ERROR] ... 5 more
[INFO] Skip remaining: AUT is not available
[INFO] Failed Tests:
[INFO] RcpttTest_CloneFuses_RegionInfo
[INFO] RcpttTest_Clone_RegionInfo_multipleTarget
[INFO] Process terminated. Shut down AUTs
[ERROR] Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.debug.core.DebugPlugin$EventDispatchJob
[INFO] Runner exit code is: 56
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
It happened once, I tried to re-run and the error disappeared. What may be the cause for the issue?
Thank you
Jeevan
[Updated on: Thu, 10 September 2015 07:56] by Moderator
FUDForum. Page generated in 0.05289 seconds
