Running into NPE errors with WTP RC4 [message #170531] |
Mon, 05 June 2006 04:20  |
Originally posted by: vbansal.tibco.com
I have created an extensibility element ecore model using WSDL.ecore from
org.eclipse.wst.wsdl plugin. Now I am trying to create a genmodel for my
extensibility element ecore model. Since the ExtensiblityElement is
defined inside wsdl.ecore, I need to reference wsdl.genmodel at the time
of my genmodel creation. The problem is when I click on the wsdl.genmodel
from the "New EMF model" dialog, Eclipse throws the following errors. I am
running Eclipse RC7 and EMF 2.2.
Will appreciate your help on this.
Vikram
at
org.eclipse.emf.converter.util.ConverterUtil.computeRequired Packages(ConverterUtil.java:392)
at
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPackagePage.validate(ModelConverterPackagePage.java:803)
at
org.eclipse.emf.importer.ui.contribution.base.ModelImporterP ackagePage.validate(ModelImporterPackagePage.java:92)
at
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPackagePage.referencedGenModelsCheckboxTreeViewerCheckState Changed(ModelConverterPackagePage.java:756)
at
org.eclipse.emf.converter.ui.contribution.base.ModelConverte rPackagePage$11.checkStateChanged(ModelConverterPackagePage. java:564)
at
org.eclipse.jface.viewers.CheckboxTreeViewer$1.run(CheckboxT reeViewer.java:133)
Re: Running into NPE errors with WTP RC4 [message #170703 is a reply to message #170589] |
Tue, 06 June 2006 07:53   |
--------------010501040208070403020606
Vikram,
I see you've opened a bugzilla. It looks like the WSDL model is
referencing the XSD model in a bad way. If the WSDL model registered
its GenModel, you'd be able to use "Browse Registered Packages..." to
load the model without importing WSDL into your workspace:
When producing the .genmodel for such a new model that extends/uses
WSDL/XSD, the system would already know where to find the referenced
GenModel for those registered models...
Vikram Bansal wrote:
> No, I have all three (Name, NsPrefix and Ns URI) correctly entered.
> The use case is as follows:
> 1. create an EMF model project
> 2. create an ecore model 3. create an EPackage and set Name, NsPrefix
> and Ns URI
> 4. create an EClass, give it some name
> 5. for this class add super class: wsdl.ecore --> ExtensibilityElement
> 6. save and now create a genmodel for the ecore you just created
> 7. in the "New Model" dialog you will reference wsdl.genmodel (your
> org.eclipse.wst.wsdl must be in the workspace as a binary project
> prior to this)
> 8. browse and pick wsdl.genmodel. The genmodel will be added to the
> "referenced genmodels" tree view.
> 9. Now when click on the wsdl.genmodel, a dialog will show up saying
> there were errors. The log shows you all those errors I sent with my
> last post.
> regards
> --vikram
Content-Type: multipart/related;
boundary="------------060602040606080708020701"
--------------060602040606080708020701
<html>
<head>
http-equiv="Content-Type">
</head>
Vikram,<br>
<br>
Re: Running into NPE errors with WTP RC4 [message #170756 is a reply to message #170703] |
Wed, 07 June 2006 06:47   |
--------------000304000605080205000700
If I follow the exact same way of loading WSDL model and then try to
click on a class that refers the XSD ecore; here's what I run into:
(screenshot attached). Is it the issue of WSDL ecore not referring the
XSD ecore properly as you are saying?
Anand
Ed Merks wrote:
> Vikram,
>> and Ns URI
>> prior to this)
>> last post.
>> regards
>> --vikram
Content-Type: image/png;
name="wsdl.PNG"
Content-Disposition: inline;
filename="wsdl.PNG"
iVBORw0KGgoAAAANSUhEUgAAA6AAAAHZCAYAAACYd1aRAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
RmBJREFUeF7t3QmULVdBLuDrCDiBAzKIgogDBkmIAwpqGniwiAGCC8WlKAmi IkuICwiKTx7c
BEIkQaYAilFQkggREjRMRkxMYhIzkBAxIIkMwadMD3nrIcTIkP123XuPnhS7 au+qc87u6urv
rlXr3ttdp6rOV//ZXX/t091fcsEFF4Q9/hAgQIAAAQIECBAgQIAAgU0LXHvN ZcHCQAZkQAZk
QAZkQAZkQAZkQAZkYNMZ2LPpHdi+EMuADMiADMiADMiADMiADMiADDQZUEDN AJsBlwEZkAEZ
kAEZkAEZkAEZkIEqGVBABa1K0NzxcsdLBmRABmRABmRABmRABmRAAVVAFVAZ kAEZkAEZkAEZ
kAEZkAEZqJIBBVTQqgTN3S53u2RABmRABmRABmRABmRABhRQBVQBlQEZkAEZ kAEZkAEZkAEZ
kIEqGVBABa1K0NztcrdLBmRABmRABmRABmRABmRAAVVAFVAZkAEZkAEZkAEZ kAEZkAEZqJIB
BVTQqgTN3S53u2RABmRABmRABmRABmRABhRQBVQBlQEZkAEZkAEZkAEZkAEZ kIEqGVBABa1K
0NztcrdLBmRABmRABmRABmRABmRAAVVAFVAZkAEZkAEZkAEZkAEZkAEZqJKB jRbQ61/3J+Ff
n/Lk8Imf+5nw6Z98ZPj8kY8IX3j4w8KNR/xE+OSjfjJ85Im/HD7wey8O115x UZUn646LOy4y
IAMyIAMyIAMyIAMysL0ZCP7MSmBra2tQl9tIAf3fz/yNcNOP/Ei4+SEPCeGX fimEY48NYe/e
EJ773BCe9awQnva0EB7/+BAe9ahw82GHhZvuec/wgVhSLz/3nEEHb/DY3sGD P38ZkAEZkAEZ
kAEZkIGhGWja19DHWH+aOdsbO962FtD3n/rycON9fyiEBz84hF/8xRB+67dC eMELQjj11BBO
Pz2E007b/+8XvnB/EX3Sk0L4hV8I4YgjQvjhHw7/9653DZc86QmTCuSePXuS x9P1cS+O4S+O
dVqWbKtkneXzOHT9dT12aJb6jjP1uVWe19BjK1m/OZ5Vj2ld2yg53nWts45j Xtex2M7w8YsZ
MxmQARkYngEFdLjZVHO2rQX0X556TPjCQQeF8IhHhPCrvxrCs58dwktfGsIf /3EIZ5wRwmtf
G8JrXhPCK1+5v4Aef3wIT3/6/nV/9mf3l9D73S+E7/7ucPUP/UC46Py3raWI Li7uxl7kKaCX
rVwKci+YsaUjdW4X2xpaxvpK49jja7a5fDzLx5szWX5sbt2xz3no82qvP/Tx fc9jHdsau43t
fF5jjzmXia7Pb/K5jj0mj5vPRYhz6VzKgAyUZkABnU9Wtq2A/uvj4izmwQeH 8PCHh/ArvxLC
M58Zwsknh/Cyl4XwileE8JKXhHDSSftnPZ/xjP1vwX3KU/bPgDZv0X3MY0J4 5CNDeNCDQvih
OIP6Xd8V3nH3u4U3vfF1K5fQVS+4FNBpFtBVzkvuon/VzKTK7Jht5o6zPcgP Ld2rbn/o43dj
Ac19IV6nYW5fQ25qlGzLOvO5eHAunUsZkIHaGVBA55O5bSmgH/rNp4abm5nP 5vs9m7fTHnNM
CL/92/u/5/O44/bPcj7hCSH89E+HcPjh+9d76EP3z5T+1E+F8DM/s798Np+L 38DavBX3xu/7
vnDj3e4Wzr3bXcPb3vSGlUpo14V/atYoNUOVmmVrX8jlHrdYP3Usi8emXvi5 7ZZsr2sbXSUp
t8/F4/q2u3xcqfWWPfqef+ksTq7wtY+hfXypIrd8XF0ZaD+PoQUr5zTkXJRk su959pksv1a6
XHK56MpB6eOW1+sqUn3nefkx7dd+6nEluS09pr68jz3HXcfcfi20X1+510Lf +u3xpvbFiv3N
52LFuXQuZUAGFND5ZKB6Ab3+9FeFm2JRDPe///7Zz5//+X0zoJ+Ps5r/cdRR +0tnM6t5n/uE
8O3fHsKd7hTCHe8Ywl3uEsJ3fuf+j9/3vuHGH/uxcHP8oUXhB38whO///vDZ e90rfDx+/qN3
vnM45QcODRec99bRJTRV0lKFsG+9voJT8rjUxX3uYq5ku6mL6tSx5i6U2xfk peun1istMn3H
mfvC1GeXKhep4tVVYlIfH3ouUsefOuah7rnn0bW9Ls+hz6tr/XYOhuZnqHnX +S89vlTJWvV1
kzumodZDXlt9r7nSczH2+HKvVZ+fzwWGc+lcyoAMrDMDcyiguWv5dXqtY1ub Ot7qBfSjh94n
fOHe994/c9l8D+eRR4bPPexh4bgnPjHs/bVfC59rSuY3fEMIX/u14bO3ulX4 9y//8vCpr/iK
8Jmv/Mrw+a/6qhC+5mvCp2PJfMLRR4cXNW/D/Y7v2Pf228/F7wP92N3vHm74 1m8N77rd7cLT
j/75cNXlF44qoct3/EvK0dALtvb2UyWgq4DmilTq2EsvFPsu6ku30VeQSo+t dL0hL6ycW0kx
L9lGSbHqyldXWUwVnZIMLR/L8vqp59ouWHMroEOfT+lreuz5LsnS0NfckGPu GteGvPbGHt+Q
1611XbzKgAzIgAwsMpAroO1rne3MTt/1cO64uq7xco8ruY7sujYsvSm+rkJa tYBef+Lx4d+a
Wc1DDgnhR380hB//8XBTnAn9g/i9nee9973hr667Lrwyfo/n/4s/2fLGuHws Lh+Oy0fi8tG4
fCYuH4jLsY9+dPj9t789nHrhheF1zazpHe4QPhtnSj8SZ0mvi3//0+1vH174 dV8X/vCVp4wu
oKmT3HXBVXrh1xXG1EVsrvimApALT+44N11Ax5jmLvBLX4xDLvj7bIcal5iX lqNcSe47f13H
kcp0iVXueZUOvKuUmLGvx1Shz+WsdF85l679pI5prE2JfWp8Gbq/oeuXvlat 52JTBmRABmQg
lYG+Apr7Or1dmVrluFYte0Ou50qvRVc9psV+qhbQGw763vCJe9wjhPj9mvve Sht/CNGr4w8f
OieWz8WfCz70ofCKOBt6w1IB/Zf47080v9okLk+JP/32j84/f9/qX4jLn77n PeFvnvrUcGOc
9fyXb/7m8J5YPt/5jd8YLokzqI874qHhkgvPHVxC110y2heEJRdufQU0VTTW UR7XsY2Si9++
IlVi0z7O0hdD7rz23SAYej7GPI/2i79v0Bq7/VwWu7I1tqDlBt6xz2NM2R5z A2RonnMFtC9j
Yx87xlABdXG3XRdj9it7MiADYzPQVUBLru+adRZL+6Zv++PL6+a23XVNuvz1 fnn7Jdvuu1md
eh591wGp51xyrdfeT9fzWWwrZdi3n2oF9N1vPiu8L85UNm+T/c/4ltnmV6eE WEbf89jHhgs+
+MHwmf+qoCFcFP9/aiyV7z8w89nMhP59XP7nUUeH0y+6aGnNED4b//fBOCP6 0fgW3RtiCb32
678+/N1tbxuujjOgj7vjHcIrX/HijRXQPvRcQEo+n7og7QrS8rpdIUgFuus4 ci/Skgvzvhf0
0BdX2zp1AV0yoKVe+Knn0vXCKznuXDnqGgRTBbRv3dxgmspE+7n2DShdhS23 367z3j6esZkt
OQel+Uh9YenLSOqL1pjz3fUFbXlbfV9Q+rLS5dNl0v5435iQ+kI7ZLwpeY1a x8WpDMiADMhA
KgOrFND21+++r91dX39T20h9XSz5Wt53LVPydTy339TzS13DlH4NL7nubz/v vmudagX0vU87
Jrwnvj32w/Ftsp/6tm8Ln2/eihv/Dk1xjD+M6MoPfzh8eqlaXvHxj4fT4k/G ve7AzOfz469h
ef2VV96ifDb/+WT8HtJmhvRDX/3V4fo463l1/B7Ri+LSlNAXx23/8uOPCu+8 8uLBJdTgZ/CT
ARmQARmQARmQARmQgWlkYBMFtOSmc9fN6lTR7LrRX1oqu0ruYl+p413HtnPb GFNA+1431Qro
ux/xsHBtfHvsDc0saPyptp+KP0joM3H59zhT+X9igXxX/DUr13ziE7eYCX3P Jz8Z3n7CCeGs
E08Ml7z//eHmVv385/hrWd4VH/tP8YcUXRdL5z/EEnpF/EFF58flr+O/z4gF 9IGH/Wg4961v
VECvmcbgYRB3HmRABmRABmRABmRABoZmYBMFNHUMQ2ZA+95Z1jfLuo4Z0Pax lxx3br+5d1/l
9tFVVNvHWq2AXnXIwfu+N/Mf40+4/VD8+2Nx+URcPhKL4w2xRL4vLlcddlh4 V5z5vHGpaDZv
zf33L5r3DOF98Ve1XNEU12aGNBbNf4il8+pb3zpcGpe3x5+e++b495vix+99 928Przr15Qqo
AioDMiADMiADMiADMiADOzQDY38IUa5UtUtZrmTlZgtTM6MljxlaKFPfWrPK tyD1FeYdOwN6
6bfcOVwev0fzmjjjeX1cPhTfIvvPcbmheevsl31ZeM+Bt9pe+cAHhnd/7GPh c4nS2cyA/mdc
PnD44eHSuP47mtL6JV8S3hmL5jtj6bw8/v23cTb0bXE5K/77L+PHvucO3xxe +qKTDDY7dLAZ
enfM+u6oyoAMyIAMyIAMyMD8MjD217Dk3rZa+n2QQwpi6ucrlMyI9r0Ft/02 3JJS235uy4/p
csm9LTnllTPcthnQ82PpbL438/JYOK+Jy3vj8r74PZvXxZnKd8cC2sxk7pvN jMslD31I+PB/
NlXzln+amdGr73e/feXzyrhcHpcr4mOviIWzWS6Oy/nx94aeE5cz47/Pjct3 3O624eTnP1cB
VUBlQAZkQAZkQAZkQAZkYIdmIFdAu2469P0wHDcqtudGRbW34J535zuFv7rN bcJFsXBeEZdr
4nJt/P+1cZbyXbFEXnOgfF4U/z77pJPCx//jP/a1z5tvvnnf0vxpKullp5wS /jauc1lcmiJ6
aZwBvTQWzkua8hm389Yv/dLwhricFv99dpwFvWssvs9/3nEGmx062BgYtmdg 4M5dBmRABmRA
BmRgShlQQOeTx2oF9Px73yu8pfn+zFgKL45L83bZq+JyTfP22VgYm5nP8+Ly vGOOCeddf33i
Dbj7P3T9Zz4TTj/uuPDXzUxpXC6Oy4WxbDbl8y/jdv48Ln8alz+J/391XO58 268LJ514vAKq
gMqADMiADMiADMiADMjADs3A2AI6pRLtWPaX6GoF9KIjjwhnxdnOt8TC+fY4 Y3lRnLG8LC5X
Hnj77V/FIvmbj3tceP2ll3aWz8UnrorfI/ryY48Nb4uPaWZMz4uzoE35PCcu fxb//er496vi
dp8f/77DN31j+N2TTjDY7NDBxgt1Pne7nEvnUgZkQAZkQAZkYGwGFND5ZKda Ab3iN58aXhsL
59mxfL41lsO3x+XCWBavigXy3Lgc8+hHhzMuuOCLyuc773//8I+PfGT4bPxM 8xNxF38uu+GG
8KInPzmcEx/7l3H5i7i8Pm7vtLj8QVxeFcvnr8flLnf5lvCyl5ysgCqgMiAD MiADMiADMiAD
MrBDM6CAKqCDX7x/H38X52mxfL42LmfFYvimWBKbt9H+eVyedvTR4cyLL/7i 8rm1ta9Yvqn5
ns/4Oz8/eOONt/gVLVd+5CPhlKc9LZzZlM+4nB6XU+N2Xxq3f2pcfiT++9D7 HBz+9LQ/Gny8
Y+/OeNx8XhzOpXMpAzIgAzIgAzIgA9PIgAI6jfOwjtdDtRnQ5mDfEH8n52vi zOcZzQ8KimWx
mb383Wc8I5xx5ZXh8636efWRR4az4+ffEpe3Hlj3vCOOCNd96lPhpqV1r73p pnD28ceH18R1
/iguL4ul8yVx+y+Iy+3iv498xBHhgr9+iwK6Q+92rSPktjGfAcu5dC5lQAZk QAZkYHdmoLn8
b4qLZR4GW3Gicchrec+QlZfXff0Je8M5sYA2b49tZiv/LC5nHnxwuOAd7wif XiqVVzzgAfsK
ajPzuViasnpWU0gf9KBw3b/92y3q6hsPPTS8PH7upXE5OZbOU+L2fzr+ffvb f1N4xtOfMujJ
jX1uHrc7B0Pn3XmXARmQARmQARmQgc1noCkslnkZDHndjC6gzU7OvNtd9/2A oD+IZfGP4/In
zdtn73nPfd/j2fy57Cd+IpwRP/bGA8vZsUj+eVya/zeltPncWx/60P8qoGff 4x7hRfFjL47L
8w8U0L1x/a+J//7h+/5gOOM1f6iAmv2UARmQARmQARmQARmQARmQgR2agZUK 6Ll/+Ip9vybl
Zc0SS2JTRH8/Ln9z+OHh4kc9at/baF/bzIw2M6SxSDbLmXF5XVya8tm81bZ5 zCVHHRXedL/7
hZOa0hmX58XlOXGdZgb0vvHfzeznrz/5ieEdl10gaDs0aEPuilh383ceGTOW ARmQARmQARmQ
ARnYjgysVECbAz718UeF02MBfUksi83MZfP22VPi8oq4NAW0KZmL5bQD/25m Sl8dl1Pj8ntx
+d0DxbMpoM+Ny7MPzH7+VPz7VvHXvfyPB22FN5z5GuVT+ZQBGZABGZABGZAB GZABGZCBHZyB
lQtoU0JPevAD930v6AtjCX1BLI3N22ib7+FsymgzI/rKA383hXMxS9oUz2bW tFm3mfU8MS7H
HyifvxO385j47y+N2zzk4HuHF73gRCHbwSHbjjsr9umOngzIgAzIgAzIgAxM MwNf9OsyfGBH
C1T7IUTLL+h/eOffhecc/pBwSiyOTQltvn+zWZoyuiikzezoYlmUzmbGs3m7 bVM8nxWX45p/
Nz/t9kD5POh7vyeccPz/ClddfqECqoDKgAzIgAzIgAzIgAzIwAwy4NewTPPG wJgbNlV/DUv7
AP/+qkvCsx/7c+EZza9OiUtTLk9oLU3ZbJbmbbZN2dx7YMaz+Xez7lPj4w6J f9/61rcK9znk
3uE5xz0zXPl3vu9zTBg8Zj4vbOfSuZQBGZABGZABGZhTBhTQ+eR5Wwvo4kXx wpOfF446+PvC
02OZfF4zGxqXplw2s5yL0tkUz2Z5zoGPHxPXOSwut4k/UfdOd7pjePjDDg8v e8nJ4eorLnKX
awZ3ueY0YHou8xkwnUvnUgZkQAZkQAa2JwMK6Pa4byLvkyigzRN725vPCr9x 7K+Hw3/g0PCw
W986/EIsl0+Ky7GxcD49Lk+Ky2Pj/x8cl7vFf9/mNrcJ33LnO4UHPeCw8Nu/ dWx481/8meKp
eMqADMiADMiADMiADMjADDOggCqgG3lhN2/JPefs14YTT9gbjo5vzX3gA348 fP+hh4SDDrpn
aL63814Hfe++/zcfP/qox4TnPedZ4Y1vOCNc846LN3I8m2j8tjmfF49z6VzK gAzIgAzIgAzI
QJ0MKKB1nGvkeTIzoDWerH3MJ7jOpXMpAzIgAzIgAzIgA7snAwpo+bneE98t OuXXhgI6w7co
TDlwjq188GDFSgZkQAZkQAZkQAb2Z2CTBbQpbMvLOszHlMDFMSzvP/Wx3PGN 2Xdum+v8vAKq
gE76Dsk6w25bvojLgAzIgAzIgAzIwM7MwKYK6KbK2pjtKqDd2dzjhbszX7jO m/MmAzIgAzIg
AzIgAzKwEzOwiQLaVxIXn1tep2uWNPXx0o+1Zzub/7f3nTuG3PqLfXQd0/I+ F/8eM/Namisz
oGZAzYDKgAzIgAzIgAzIgAzIwKQzsB0FtF38UmWxXbpSxbVd8FL/7yueXUV5 eV+pYy05/nbR
HDNzW1o8F+spoAabSQ82QwNtfXd1ZUAGZEAGZEAGZGB+GdiOAtounF3fK5r6 eLvItddJFb2u
wtg1A9pXdkv337XeJl9DCqgCqoDKgAzIgAzIgAzIgAzIwKQzMIUCmiplqQJX OuPZNXuaekts
3zZLjiE3i5o6lk3NhiqgBptJDzabvPti2/O7O+qcOqcyIAMyIAMyMM8MbKKA dr0VtqRA5t5q
21UKF/nMzYCm3u5bUjRXLa8lbzNe9TWmgCqgCqgMyIAMyIAMyIAMyIAMTDoD myqgi8LW/gE9
XQUx9cN5cm/NXS6dfT/cp2SWsvTtvl0FNvc9n22HVctm6vEKqMFm0oPNJkJv m/O8M+q8Oq8y
IAMyIAMyMN8MbLKAyk3d3CigCqgCKgMyIAMyIAMyIAMyIAOTzoACWrckbrKU K6AGm0kPNpsM
v23PZyBzLp1LGZABGZABGZh3BhTQ+ZxfBVQBVUBlQAZkQAZkQAZkQAZkYNIZ UEAV0EkH1B2w
+QTUuXQuZUAGZEAGZEAGZEAGFND5ZMAMqLtdbibIgAzIgAzIgAzIgAzIwKQz oIAqoJMOqLtk
8wmoc+lcyoAMyIAMyIAMyIAMNAW0mTmzzMNga2trUJ/cYxAwCMiADMiADMiA DMiADMiADNTK
QFNYLPMyGJIdBdRbNAbdsRgSLuv6QiYDMiADMiADMiADMiADMrCcAQVUAVVA ZUAGZEAGZEAG
ZEAGZEAGZKBKBhRQQasSNHe+3PmSARmQARmQARmQARmQARlQQBVQBVQGZEAG ZEAGZEAGZEAG
qmWg+SFE/sxHwA8hMnhUGzzcwXIHSwZkQAZkQAZkQAZkYGgG/BqW+WTG7wFV PpVPGZABGZAB
GZABGZABGZh0BhRQBXTSAR16R8X68wm0c+lcyoAMyIAMyIAMyMD8MqCAzuec mgF1t8vNBBmQ
ARmQARmQARmQARmYdAYUUAV00gF112s+AXUunUsZkAEZkAEZkAEZkAEFdD4Z MAPqbpebCTIg
AzIgAzIgAzIgAzIw6QwooMML6J49eyZ5ThVQg80kg+lO5/BBhhkzGZABGZAB GZCBuWZgbgW0
KYfLS8l5Ky2Ui/VK1y/Z9zrXUUAVUAVUBmRABmRABmRABmRABiadgSkX0FzR S32+/bHcNpoC
WLLOclEcuv46S2bfthRQg82kB5taLwT7ccdYBmRABmRABmRABqabgSkW0MUM Zldu+j6fK6Wp
2dEhH2sX1qGzrZt8LSigCqgCKgMyIAMyIAMyIAMyIAOTzsCUCugqxXNR7PoK aNfsaG5Gs/3W
26m+FVcBNdhMerDZ5N0X257uXU7nxrmRARmQARmQARlYzsBUCmhpCczlN1dA U98j2vWY9uxm
qojmjjt3vOv8vAKqgCqgMiADMiADMiADMiADMjDpDEylgC7e2tpX6HIzpF3f z5mbscx932jX
DOjyrOsUiqgCarCZ9GCzzrsttuVOqgzIgAzIgAzIgAzszAxMqYCWFroh3wO6 XAxL34KbWy/3
fabb9VpQQBVQBVQGZEAGZEAGZEAGZEAGJp2BKRbQvu/nXC53pW+dbT8mVWDb H+t7q+7yjGjJ
rGytQqqAGmwmPdjUeiHYz868G+q8OW8yIAMyIAMysDsyMOUCKoPDMqiAKqAK qAzIgAzIgAzI
gAzIgAxMOgMK6LCSN+VSrIAabCY92Ez5xePY5jMQOpfOpQzIgAzIgAxMOwMK 6LTPz5DXjwKq
gCqgMiADMiADMiADMiADMjDpDCigCuikAzqkgVt3PmF2Lp1LGZABGZABGZAB GZhnBhTQ+ZxX
M6DudrmZIAMyIAMyIAMyIAMyIAOTzoACqoBOOqDufM0noM6lcykDMiADMiAD MiADMtAU0Gbm
zDIPg62trUF9co9BwCAgAzIgAzIgAzIgAzIgAzJQKwNNYbHMy2BIdhRQb9EY dMdiSLis6wuZ
DMiADMiADMiADMiADMjAcgYUUAVUAZUBGZABGZABGZABGZABGZCBKhlQQAWt StDc+XLnSwZk
QAZkQAZkQAZkQAZkQAFVQBVQGZABGZABGZABGZABGZABGaiSAQVU0KoEzd0u d7tkQAZkQAZk
QAZkQAZkQAYUUAVUAZUBGZABGZABGZABGZABGZCBKhlQQAWtStDc7XK3SwZk QAZkQAZkQAZk
QAZkQAFVQBVQGZABGZABGZABGZABGZABGaiSAQVU0KoEzd0ud7tkQAZkQAZk QAZkQAZkQAYU
UAVUAZUBGZABGZABGZABGZABGZCBKhlQQAWtStDc7XK3SwZkQAZkQAZkQAZk QAZkQAFVQBVQ
GZABGZABGZABGZABGZABGaiSAQVU0KoEzd0ud7tkQAZkQAZkQAZkQAZkQAZG FdC9e/cGCwMZ
kAEZkAEZkAEZkAEZkAEZ2N0ZCPHPkBsLowvo1tZWsDCQARmQARmQARmQARmQ ARmQgd2ZgaZ4
Vi2g+/a2pj9DWrN1Td3LgAzIwO7NwJq+7NgMAQIECBAgsKKAAur7OQdNf7uA 370X8M69c7+T
M7Di10oPJ0CAAAECBNYkoIAqoAqoDMiADMw+A2v6mmkzBAgQIECAwIoCCmi8 8NyzZ0/y4qvr
4zt5FmC7jn0dls022tsZst3FurnH5D6fMkwd26asxxzfuo9lCsfQ95xWycm6 rdrb2/Sx5c7N
pve/ab/c9rte5yt+rfRwAgQIECBAYE0CkyigJT8FK/V8Fxcii4v/sSVAAe0u 4bmLvdLPp4xz
F8rL2+66aB6zjdxjhn4+t36pUel6tffXVbibj0/hWPqOb3mMKPXd9HqbLoC5 c1L6WlpeLzXG
rjrubspZAV3T1YHNECBAgACBDQlMpoD2Pb+moOYKaF9ZyV3oKKCbLxK5i+Ia 52hdM6CbLhBj
LXKPW+fnVz2f6zwWBfSW35uaOzdDC2jp+Jjb76bPeftmQ/t4NvQ11GYJECBA gACBgQKzLqCp
wrF81z43g9o1A5B63GI2KHVx1zczO+R4lvdRcmypUt41a5E7jr6Lu9Rj28ea ujhdPj9d2+iz
bs/A5bbRvgDus+jab+ocjLVrPy6Vk1zZ7dp3n01fUSg5l8vbLjmHpT6p89N1 Yym3zfbro72d
ZevScaLvJlfJ67HvXPXlqu/YS8awdq5yNqnslJT89uP6Xm+55zQm17mCO/Br o9UJECBAgACB
DQnMvoAOvdjqurjuKnPtYpZ6fNeFUVe5KP146oIvdTHdd0y59VPFcxXTnGPX RWzOJFfUSi6g
uyxSBqVlpG3fZVfy8VwxaJfBVDb7SkLOuO/cjXls1/HlMpIq0H3nvy+vy8Wv 5HhqHVvqmEuN
c6/pEo+S8lhyHnIZLNnGqrleHMOGvobaLAECBAgQIDBQYFIFdPmu9+LfzfNZ vAW3/ffyxU1u
dmGVspY6rr4y0HXB1HdRtzxLUXqhucpzKilV7efdtb/S9VLPv+85lJS8tnUq B6nyWWo35rmV
nr/S0tnlMGY/uQJa8nzbpTpnmTrO1H6GnKe+wpl7bQ55bGqMyeVyyPZLMjCk ULbPTe58lhTA
0tfturM1dozqytHAr41WJ0CAAAECBDYkMKkC2vUch34PaO6ue8mFTeoiu+tC rO+Cd/G5IRd6
pcUid+GfulAu3XbqeEvLYul6uQvr3IV+yTnquhgtsRtrNeZxXUWkNHN9FrlC 1PV66ft4+9zl
9tF3g6XvHJWUmlzeul57Q/JXWo7bhXXIseXK6NBclbyGS7dZMpbkzlXKsGRc XMd5Wnyh29DX
UZslQIAAAQIEBggooImf5Fl6cZ27YOwrUCUFKFeU17GN0ou7da83pDCVPM9c ASq5+B1z3nMF
o/R5lmapr6gOPUftYx9SRkqtSorLmOeUe22UFPpSr1z5zBW9vmyWnPfccZae t9R2Suy7boLk
XnMl215nAe06D4vjH/B10aoECBAgQIDABgV2VQFdXHA3Fyrti6PFx/ouCFOP S80SLV/otR+T
upjr226qJPQdf/uCv/28chfDXS6p59me7UltO+U6pDx07bfrYjrnnfPp807Z dM365PLUV/5K
SkmffddFfekxpQy7cpTKei5DXa/DIYU4d4ypfPS9/ktel6kyncryKsfWN57k 3LrOb9f40jcW
tG+c5Lbdlbmu11vu4yVZ7fNI3TTY4NdRmyZAgAABAgQGCEymgOZ+F2jqOXXN TPj4LX8tA4+0
R+qiecpW6zredW2nr5BNxXETz3Vdz227j227978ux9LtDPi6aFUCBAgQIEBg gwKTKKBjn1/p
hYf1FNJUBnbaBfgqx9s3E72O18cqx7aO/XdtY6rH1Z7t3aTBTrTZhMfYrzMe R4AAAQIECKxX
QAGN3wO6iYsd2+QqAzIgA9PJwHq/dNoaAQIECBAgMFZAAVVAFXAZkAEZmH0G xn6R9DgCBAgQ
IEBgvQI7uoCWUHT9CpeSx1qHAAECBAgQIECAAAECBNYnMPsCuj4qWyJAgAAB AgQIECBAgACB
VQRmX0DNgK4SD48lQIAAAQIECBAgQIDA+gRmX0DXR9W/peanbS7+LH7iaK19 L+9n+Ti2Y//2
OV2BVDYWH8vlJvf51LOu8TooPf6pnJUxjlM59tQ4M4XnM4Vj6DtH7YxO/Xin mDfHRIAAAQLz
Eph9AR06A5q6aC65kJ7KhXDfcSx/bvnXcuQK7PK6JRbreIm0L9I2cdHWV8jW 8Rw2tY2xFpss
oDXOV1fJbT4+1qSkOKzzPG7HcW7i3ExlvFs+95uwXce5V0DXoWgbBAgQIDAn gdkX0KEna7cU
0K7SOZVSVuNicirPdUxGhz6mq6SVFonc+dhEySl5jqXHX7Kt9jq55zyVbeaO Y5PPYxPbzj2f
Gudp6DGU3MjYZFbXeby2RYAAAQIENi0w+wI6ZgY0dVd9+UIrNXuYml1cnLzc +ov9LZffviKc
uthv72PIbFf7uZVe4PWVjq7n3H5ey+v1GZf4p/bZVbxKClnf9trnKlXoS55b 37lczk87k32O
7WPpeh6pwaXvmHN5TuW35Lz1Pbeu10HJwJh7LiXHNsY555R7fZUcV2qMSo0j XWNL7hiHZCa3
rfZrreu8pFxKxsHlsbf9fEtfX6n9pF7T7ddkiXlqLC7Jr3UIECBAgMBcBWZf QIeeuNTFTEmJ
aT8udaGSutDuuqBpf7yr7JV+vOuCNXVx2HchWLK/1AVXyeNKjnHodkrOXepC s3Q/qe3nslC6
7eXttEtJycVx1376XhOlx1aaz3W/DvrOZyq3Xee2xDPn13Weh2Sib92u55Mq xalzuu4cjs1N
ifWQc9fnsin7rrFpyFg39GuR9QkQIECAwFwFZl9AFzOgub9TF8pdF06pO/i5 i70hF+yp/bb3
mdtf34VR6vi7ikLJBX/uQn2xjT63Up/SgpR6/rmL3K6LzPbHc8936LkZu/6y 2RDbsUWia38l
JWrMeesrLiUD8ph9lmQgl9WhJSi3z+Vzm7MekoOxPin7sdvqep2Wjncpu75j SX2ubzzMjRnt
mwG581OSW+sQIECAAIG5C8y+gA49gX2ls+TCctVy0t5HVznpKox966c+lzve dRbQdVy4jr3Q
Ldl3rggsb2P5wnPoMa1r/a4M5LKxSgEdeuy5Y+nL324voEOtN73+KrnJ5SBX 9Pqy3h7XcmNa
32s39/UiV5gV0JygzxMgQIAAgRAU0FYK+i4wplRAu4rm0ALaVXjbZavrxVJS akvc2heY67qY
7ivQqXOdc025rOtYh24nd1GfuxAvKeWlF/e5fY15brmbQbkBfMw+h96E6MpX 6b77Xmel28hl
dl3b2XQB7bvhMGRcy2Wx9ByXupWOXSWvt1ymfZ4AAQIECMxBQAEdWEAXFy+L u+i5C/T2+rnS
0FcI2/tc3lbqc8sf67u4a1+QpZ5balt9F3q548kd+7JbymSx/aGe7RdtqdHy eW7vuy8TOYeU
Ye65tW26MtZ1XLki0XXMuXO2fNzt57Xu10HJ4Ft6bkv8Us99+Rhy57krp+1t lOSz9HXXfs2n
SlzuXLdfe6XZ6Xu+peelZLxrj119mS/dXurY+8po6XiQsku9TkqybR0CBAgQ ILCTBRTQnXz2
ZnDsc74A63puU37OUz62oXGf03MZ+tx3yvqbOEeb2OZO8XScBAgQIEBgJwgo oDvhLM34GOd8
saiAbm9w55yt7ZVdbe9dM5GrbfW/H+28r0vSdggQIECAwGYEFNDNuNoqAQIE CBAgQIAAAQIE
CLQEFFCRIECAAAECBAgQIECAAIEqAgpoFWY7IUCAAAECBAgQIECAAAEFVAYI ECBAgAABAgQI
ECBAoIqAAlqF2U4IECBAgAABAgQIECBAQAGVAQIECBAgQIAAAQIECBCoIqCA VmG2EwIECBAg
QIAAAQIECBBQQGWAAAECBAgQIECAAAECBKoIKKBVmO2EAAECBAgQIECAAAEC BBRQGSBAgAAB
AgQIECBAgACBKgIKaBVmOyFAgAABAgQIECBAgAABBVQGCBAgQIAAAQIECBAg QKCKgAJahdlO
CBAgQIAAAQIECBAgQEABlQECBAgQIECAAAECBAgQqCKggFZhthMCBAgQIECA AAECBAgQUEBl
gAABAgQIECBAgAABAgSqCCigVZjthAABAgQIECBAgAABAgQUUBkgQIAAAQIE CBAgQIAAgSoC
CmgVZjshQIAAAQIECBAgQIAAAQVUBggQIECAAAECBAgQIECgioACWoXZTggQ IECAAAECBAgQ
IEBAAZUBAgQIECBAgAABAgQIEKgioIBWYbYTAgQIECBAgAABAgQIEFBAZYAA AQIECBAgQIAA
AQIEqggooFWY7YQAAQIECBAgQIAAAQIEFFAZIECAAAECBAgQIECAAIEqAgpo FWY7IUCAAAEC
BAgQIECAAAEFVAYIECBAgAABAgQIECBAoIqAAlqF2U4IECBAgAABAgQIECBA QAGVAQIECBAg
QIAAAQIECBCoIqCAVmG2EwIECBAgQIAAAQIECBBQQGWAAAECBAgQIECAAAEC BKoIKKBVmO2E
AAECBAgQIECAAAECBBRQGSBAgAABAgQIECBAgACBKgIKaBVmOyFAgAABAgQI ECBAgAABBVQG
CBAgQIAAAQIECBAgQKCKgAJahdlOCBAgQIAAAQIECBAgQEABlQECBAgQIECA AAECBAgQqCKg
gFZhthMCBAgQIECAAAECBAgQUEBlgAABAgQIECBAgAABAgSqCCigVZjthAAB AgQIECBAgAAB
AgQUUBkgQIAAAQIECBAgQIAAgSoCCmgVZjshQIAAAQIECBAgQIAAAQVUBggQ IECAAAECBAgQ
IECgioACWoXZTggQIECAAAECBAgQIEBAAZUBAgQIECBAgAABAgQIEKgioIBW YbYTAgQIECBA
gAABAgQIEFBAZYAAAQIECBAgQIAAAQIEqggooFWY7YQAAQIECBAgQIAAAQIE FFAZIECAAAEC
BAgQIECAAIEqAgpoFWY7IUCAAAECBAgQIECAAAEFVAYIECBAgAABAgQIECBA oIqAAlqF2U4I
ECBAgAABAgQIECBAQAGVAQIECBAgQIAAAQIECBCoIqCAVmG2EwIECBAgQIAA AQIECBBQQGWA
AAECBAgQIECAAAECBKoIKKBVmO2EAAECBAgQIECAAAECBBRQGSBAgAABAgQI ECBAgACBKgIK
aBVmOyFAgAABAgQIECBAgAABBVQGCBAgQIAAAQIECBAgQKCKgAJahdlOCBAg QIAAAQIECBAg
QEABlQECBAgQIECAAAECBAgQqCKggFZhthMCBAgQIECAAAECBAgQUEBlgAAB AgQIECBAgAAB
AgSqCCigVZjthAABAgQIECBAgAABAgQUUBkgQIAAAQIECBAgQIAAgSoCCmgV ZjshQIAAAQIE
CBAgQIAAAQVUBggQIECAAAECBAgQIECgioACWoXZTggQIECAAAECBAgQIEBA AZUBAgQIECBA
gAABAgQIEKgioIBWYbYTAgQIECBAgAABAgQIEFBAZYAAAQIECBAgQIAAAQIE qggooFWY7YQA
AQIECBAgQIAAAQIEFFAZIECAAAECBAgQIECAAIEqAgpoFWY7IUCAAAECBAgQ IECAAAEFVAYI
ECBAgAABAgQIECBAoIqAAlqF2U4IECBAgAABAgQIECBAQAGVAQIECBAgQIAA AQIECBCoIqCA
VmG2EwIECBAgQIAAAQIECBBQQGWAAAECBAgQIECAAAECBKoIKKBVmO2EAAEC BAgQIECAAAEC
BBRQGSBAgAABAgQIECBAgACBKgIKaBVmOyFAgAABAgQIECBAgAABBVQGCBAg QIAAAQIECBAg
QKCKgAJahdlOCBAgQIAAAQIECBAgQEABlQECBAgQIECAAAECBAgQqCKggFZh thMCBAgQIECA
AAECBAgQUEBlgAABAgQIECBAgAABAgSqCCigVZjthAABAgQIECBAgAABAgQU UBkgQIAAAQIE
CBAgQIAAgSoCCmgVZjshQIAAAQIECBAgQIAAAQVUBggQIECAAAECBAgQIECg ioACWoXZTggQ
IECAAAECBAgQIEBAAZUBAgQIECBAgAABAgQIEKgioIBWYbYTAgQIECBAgAAB AgQIEFBAZYAA
AQIECBAgQIAAAQIEqggooFWY7YQAAQIECBAgQIAAAQIEFFAZIECAAAECBAgQ IECAAIEqAgpo
FWY7IUCAAAECBAgQIECAAAEFVAYIECBAgAABAgQIECBAoIqAAlqF2U4IECBA gAABAgQIECBA
QAGVAQIECBAgQIAAAQIECBCoIqCAVmG2EwIECBAgQIAAAQIECBBQQGWAAAEC BAgQIECAAAEC
BKoIKKBVmO2EAAECBAgQIECAAAECBBRQGSBAgAABAgQIECBAgACBKgIKaBVm OyFAgAABAgQI
ECBAgAABBVQGCBAgQIAAAQIECBAgQKCKgAJahdlOCBAgQIAAAQIECBAgQEAB lQECBAgQIECA
AAECBAgQqCKggFZhthMCBAgQIECAAAECBAgQUEBlgAABAgQIECBAgAABAgSq CCigVZjthAAB
AgQIECBAgAABAgQUUBkgQIAAAQIECBAgQIAAgSoCCmgVZjshQIAAAQIECBAg QIAAAQVUBggQ
IECAAAECBAgQIECgioACWoXZTggQIECAAAECBAgQIEBAAZUBAgQIECBAgAAB AgQIEKgioIBW
YbYTAgQIECBAgAABAgQIEFBAZYAAAQIECBAgQIAAAQIEqggooFWY7YQAAQIE CBAgQIAAAQIE
FFAZIECAAAECBAgQIECAAIEqAgpoFWY7IUCAAAECBAgQIECAAAEFVAYIECBA gAABAgQIECBA
oIqAAlqF2U4IECBAgAABAgQIECBAQAGVAQIECBAgQIAAAQIECBCoIqCAVmG2 EwIECBAgQIAA
AQIECBBQQGWAAAECBAgQIECAAAECBKoIKKBVmO2EAAECBAgQIECAAAECBBRQ GSBAgAABAgQI
ECBAgACBKgIKaBVmOyFAgAABAgQIECBAgAABBVQGCBAgQIAAAQIECBAgQKCK gAJahdlOCBAg
QIAAAQIECBAgQEABlQECBAgQIECAAAECBAgQqCKggFZhthMCBAgQIECAAAEC BAgQUEBlgAAB
AgQIECBAgAABAgSqCCigVZjthAABAgQIECBAgAABAgQUUBkgQIAAAQIECBAg QIAAgSoCCmgV
ZjshQIAAAQIECBAgQIAAAQVUBggQIECAAAECBAgQIECgioACWoXZTggQIECA AAECBAgQIEBA
AZUBAgQIECBAgAABAgQIEKgioIBWYbYTAgQIECBAgAABAgQIEFBAZYAAAQIE CBAgQIAAAQIE
qggooFWY7YQAAQIECBAgQIAAAQIEFFAZIECAAAECBAgQIECAAIEqAgpoFWY7 IUCAAAECBAgQ
IECAAAEFVAYIECBAgAABAgQIECBAoIqAAlqF2U4IECBAgAABAgQIECBAQAGV AQIECBAgQIAA
AQIECBCoIqCAVmG2EwIECBAgQIAAAQIECBBQQGWAAAECBAgQIECAAAECBKoI KKBVmO2EAAEC
BAgQIECAAAECBBRQGSBAgAABAgQIECBAgACBKgIKaBVmOyFAgAABAgQIECBA gAABBVQGCBAg
QIAAAQIECBAgQKCKgAJahdlOCBAgQIAAAQIECBAgQEABlQECBAgQIECAAAEC BAgQqCKggFZh
thMCBAgQIECAAAECBAgQUEBlgAABAgQIECBAgAABAgSqCCigVZjthAABAgQI ECBAgAABAgQU
UBkgQIAAAQIECBAgQIAAgSoCCmgVZjshQIAAAQIECBAgQIAAAQVUBggQIECA AAECBAgQIECg
ioACWoXZTggQIECAAAECBAgQIEBAAZUBAgQIECBAgAABAgQIEKgioIBWYbYT AgQIECBAgAAB
AgQIEFBAZYAAAQIECBAgQIAAAQIEqggooFWY7YQAAQIECBAgQIAAAQIEFFAZ IECAAAECBAgQ
IECAAIEqAgpoFWY7IUCAAAECBAgQIECAAAEFVAYIECBAgAABAgQIECBAoIqA AlqF2U4IECBA
gAABAgQIECBAQAGVAQIECBAgQIAAAQIECBCoIqCAVmG2EwIECBAgQIAAAQIE CBBQQGWAAAEC
BAgQIECAAAECBKoIKKBVmO2EAAECBAgQIECAAAECBBRQGSBAgAABAgQIECBA gACBKgIKaBVm
OyFAgAABAgQIECBAgAABBVQGCBAgQIAAAQIECBAgQKCKgAJahdlOCBAgQIAA AQIECBAgQEAB
lQECBAgQIECAAAECBAgQqCKggFZhthMCBAgQIECAAAECBAgQUEBlgAABAgQI ECBAgAABAgSq
CCigVZjthAABAgQIECBAgAABAgQUUBkgQIAAAQIECBAgQIAAgSoCCmgVZjsh QIAAAQIECBAg
QIAAAQVUBggQIECAAAECBAgQIECgioACWoXZTggQIECAAAECBAgQIEBAAZUB AgQIECBAgAAB
AgQIEKgioIBWYbYTAgQIECBAgAABAgQIEFBAZYAAAQIECBAgQIAAAQIEqggo oFWY7YQAAQIE
CBAgQIAAAQIEFFAZIECAAAECBAgQIECAAIEqAgpoFWY7IUCAAAECBAgQIECA AAEFVAYIECBA
gAABAgQIECBAoIqAAlqF2U4IECBAgAABAgQIECBAQAGVAQIECBAgQIAAAQIE CBCoIqCAVmG2
EwIECBAgQIAAAQIECBBQQGWAAAECBAgQIECAAAECBKoIKKBVmO2EAAECBAgQ IECAAAECBBRQ
GSBAgAABAgQIECBAgACBKgIKaBVmOyFAgAABAgQIECBAgAABBVQGCBAgQIAA AQIECBAgQKCK
gAJahdlOCBAgQIAAAQIECBAgQEABlQECBAgQIECAAAECBAgQqCKggFZhthMC BAgQIECAAAEC
BAgQUEBlgAABAgQIECBAgAABAgSqCFQtoM3OLAxkQAZkQAZkQAZkQAZkQAZk YPdmoGm6Q87/
niErL9atUqfthAABAgQIECBAgAABAgQmLzCkU44qoEN2YN3dezfEuXfuZUAG ZEAGZEAGZEAG
ZEAGljOggHor8aApcwOIAUQGZEAGZEAGZEAGZEAGZGBsBhRQBVQBlQEZkAEZ kAEZkAEZkAEZ
kIEqGRhVQPfu3RssDGRABmRABmRABmRABmRABmRgd2egyg8hakK2tbVlYSAD MiADMiADMiAD
MiADMiADuzQDVX8NS1NA/SFAgAABAgQIECBAgACBnSkw9vs4m8c1fVAB3Znn 3VETIECAAAEC
BAgQIECgusCiQA7d8eIdsQroUDnrEyBAgAABAgQIECBAYJcKjCmQzWMU0F0a GE+bAAECBAgQ
IECAAAECYwUU0LFyHkeAAAECBAgQIECAAAECgwQU0EFcViZAgAABAgQIECBA gACBsQIK6Fg5
jyNAgAABAgQIECBAgACBQQJ9BbT5Ps+un5Lre0AHMVuZAAECBAgQIECAAAEC BLoKaFMwF0uq
hCqgskOAAAECBAgQIECAAAECgwRSBXS5fHaVUAV0ELOVCRAgQIAAAQIECBAg QKBdQFPlM1VC
FVDZIUCAAAECBAgQIECAAIFBAqkZ0L4NLN6Oq4AOYrYyAQIECBAgQIAAAQIE CPgpuDJAgAAB
AgQIECBAgAABAlUEFNAqzHZCgAABAgQIECBAgAABAgqoDBAgQIAAAQIECBAg QIBAFYGmgPb9
4KG+z21tbe37PaHNn67fF5r6+J4hK7e/6bSKip0QIECAAAECBAgQIECAwNoF mhK5yqKArv2U
2CABAgQIECBAgAABAgTmKbBcIBczmWP/Lp3YNAM6zyx5VgQIECBAgAABAgQI EMgKrFJCzYBm
ea1AgAABAgQIECBAgAABAmNnOrseZwZUpggQIECAAAECBAgQIECgV8AMqIAQ IECAAAECBAgQ
IECAwMYFVimf7ZlQM6AbP112QIAAAQIECBAgQIAAgZ0tsEoJ9T2gO/vcO3oC BAgQIECAAAEC
BAhUE1ilfJoBrXaa7IgAAQIECBAgQIAAAQLzEFilhJoBnUcGPAsCBAgQIECA AAECBAhsXGCV
8mkGdOOnxw4IECBAgAABAgQIECAwL4FVSqgZ0HllwbMhQIAAAQIECBAgQIDA xgRWKZ9mQDd2
WmyYAAECBAgQIECAAAEC8xRYpYSaAZ1nJjwrAgQIECBAgAABAgQIrF1glfJp BnTtp8MGCRAg
QIAAAQIECBAgMG+BVUqoGdB5Z8OzI0CAAAECBAgQIECAwNoEVimfZkDXdhps iAABAgQIECBA
gAABArtDYJUSagZ0d2TEsyRAgAABAgQIECBAgMDKAquUTzOgK/PbAAECBAgQ IECAAAECBHaX
wCol1Azo7sqKZ0uAAAECBAgQIECAAIHRAquUTzOgo9k9kAABAgQIECBAgAAB ArtTYJUSagZ0
d2bGsyZAgAABAgQIECBAgMBggVXKpxnQwdweQIAAAQIECBAgQIAAgd0tsEoJ NQO6u7Pj2RMg
QIAAAQIECBAgQKBYYJXyaQa0mNmKBAgQIECAAAECBAgQINAukUP/bwZUhggQ IECAAAECBAgQ
IECgSMAMaBGTlQgQIECAAAECBAgQIEBgHQKrlFAzoOs4A7ZBgAABAgQIECBA gACBXSCwSvls
eBTQXRAST5EAAQIECBAgQIAAAQLrElilhCqg6zoLtkOAAAECBAgQIECAAIGZ C6xSPs2Azjwc
nh4BAgQIECBAgAABAgTWLbBKCTUDuu6zYXsECBAgQIAAAQIECBCYqcAq5dMM 6ExD4WkRIECA
AAECBAgQIEBgUwKrlFAzoJs6K7ZLgAABAgQIECBAgACBmQmsUj7NgM4sDJ4O AQIECBAgQIAA
AQIENi2wSgk1A7rps2P7BAgQIECAAAECBAgQmInAKuXTDOhMQuBpECBAgAAB AgQIECBAoJbA
KiXUDGits2Q/BAgQIECAAAECBAgQ2OECq5RPM6A7/OQ7fAIECBAgQIAAAQIE CNQWWKWEmgGt
fbbsjwABAgQIECBAgAABAjtUYJXyaQZ0h550h02AAAECBAgQIECAAIHtElil hJoB3a6zZr8E
CBAgQIAAAQIECBDYYQKrlE8zoDvsZDtcAgQIECBAgAABAgQIbLfAKiXUDOh2 nz37J0CAAAEC
BAgQIECAwA4RWKV8mgHdISfZYRIgQIAAAQIECBAgQGAqAquUUDOgUzmLjoMA AQIECBAgQIAA
AQITF1ilfJoBnfjJdXgECBAgQIAAAQIECBCYmsAqJdQM6NTOpuMhQIAAAQIE CBAgQIDARAVW
KZ9mQCd6Uh0WAQIECBAgQIAAAQIEpiqwSgk1AzrVs+q4CBAgQIAAAQIECBAg MDGBVcqnGdCJ
nUyHQ4AAAQIECBAgQIAAgakLrFJCzYBO/ew6PgIECBAgQIAAAQIECExEYJXy aQZ0IifRYRAg
QIAAAQIECBAgQGCnCKxSQs2A7pSz7DgJECBAgAABAgQIECCwzQKrlE8zoNt8 8uyeAAECBAgQ
IECAAAECO0mgKaBjl62trX2PXRTR0u3sKV1xeb29e/eGZof+ECBAgAABAgQI ECBAgMDOFFgU
yKFHv+iDCuhQOesTIECAAAECBAgQIEBglwqMKZDNYxTQXRoYT5sAAQIECBAg QIAAAQJjBRTQ
sXIeR4AAAQIECBAgQIAAAQKDBBTQQVxWJkCAAAECBAgQIECAAIGxAgroWDmP I0CAAAECBAgQ
IECAAIFBAu0C2nxvZ9eS+qG0Ywqsn4I76BRZmQABAgQIECBAgAABAvMQSBXI VAFdPNtFCfVD
iOZx/j0LAgQIECBAgAABAgQIVBPomsFcLqHt8umn4FY7PXZEgAABAgQIECBA gACB+Qj0vYW2
KaGp8qmAzuf8eyYECBAgQIAAAQIECBCoJpD7Hs7mQJa/99NbcKudGjsiQIAA AQIECBAgQIDA
vARyBTRVPs2AzisDng0BAgQIECBAgAABAgSqCCigVZjthAABAgQIECBAgAAB AgQUUBkgQIAA
AQIECBAgQIAAgSoCi7fT9v3+z67PbW1t7fv+0OZP11t1Ux/3e0CrnFo7IUCA AAECBAgQIECA
wLQEmhK5ylK9gA5puu11mye6aMv+3n/XgAMHOfA6MA4YB4wDxgHjgHHAOGAc KB0HVu1jqzx+
8diqM6CLF8fQHt9M47anbEuRrWdQNigblI0DxgHjgHHAOGAcMA4YB4wD/z0O rNLHVi2h21JA
hx70ooAKjS8evnj44mEcMA4YB4wDxgHjgHHAOGAcGDcOjHkLbPvXqAztcu31 d1QBNdgYbAw2
4wYbbtyMn8ZP44BxwDhgHDAOGAcU0Ph9jMuNuJnpTDVqM6BeLL5o+qLpi6Zx wDhgHDAOGAeM
A8YB48Bq40BXAe3qYYtutvwtkbOZAV38uN7UlKzvATXYGGxWG2z48XPRZhw1 DhgHjAPGAeOA
caCvgPaV0NkV0OXfFdNXQL1ovGh88fTF0zhgHDAOGAeMA8YB44BxwDgwbhzI FdDcO1JXnf0c
8xbglX4PaGqH7V9UagZ0XJi8CLn5YuyLsXHAOGAcMA4YB4wDxgHjQOk40P5W yOVe1i6aZkCj
qheXF1fpi8t6Xi/GC+OFccA4YBwwDhgHjAPGgf0/f6drwm/5WyLb68yugDYQ vgfUoGBQcHHg
4sA4YBwwDhgHjAPGAeOAcaDOOJCaAd3XTg9M9rU/v7W1lfyBsUPflpvaft82 1v4W3PYT8z2g
Bh2DTp1BhzNnF3nGW+OAccA4YBwwDuyucaBvBrSrfC4mC2dZQPtAFk/Yi2R3 vUicb+fbxZGL
I+OAccA4YBwwDhgHjAPrHwfas459M5OzfAtu37Sr3wNq0DHorH/Q8cXc68rr yuvKOGAcMA4Y
B4wDu2sc6Jrwy72NdtcWUIOkQdIgubsGSefb+TbuG/eNA8YB44BxwDiwmXEg Vzpn8z2g7V+7
Uvr/5i24wreZ8HHl6ou7L+7GAeOAccA4YBwwDhgH5j8OLP/w19IetlhvR34P aHPQqyxeFPN/
Ufji54uf17nXuXHAOGAcMA4YB4wDxoHNjAOrdLEdV0CHTPFad//v6LEwkAEZ kAEZkAEZkAEZ
kAEZmFMGqvwalsWP9PU3AQIECBAgQIAAAQIECOxugSGFetTvAR2yA+u6wyMD MiADMiADMiAD
MiADMiADMtBkQAH11lhvDZYBGZABGZABGZABGZABGZCBKhlQQAWtStDc8XLH SwZkQAZkQAZk
QAZkQAZkQAFVQBVQGZABGZABGZABGZABGZABGaiSAQVU0KoEzd0ud7tkQAZk QAZkQAZkQAZk
QAYUUAVUAZUBGZABGZABGZABGZABGZCBKhlQQAWtStDc7XK3SwZkQAZkQAZk QAZkQAZkQAFV
QBVQGZABGZABGZABGZABGZABGaiSAQVU0KoEzd0ud7tkQAZkQAZkQAZkQAZk QAYUUAVUAZUB
GZABGZABGZABGZABGZCBKhlQQAWtStDc7XK3SwZkQAZkQAZkQAZkQAZkQAFV QBVQGZABGZAB
GZABGZABGZABGaiSAQVU0KoEzd0ud7tkQAZkQAZkQAZkQAZkQAb27N27N0xp CTP4MyVPxzKt
fDsfzocMyIAMyIAMyIAMyMBuzsCkZkCbEzGHP83zcHfH3R0ZkAEZkAEZkAEZ kAEZkAEZuGUG
FNANNF4F1EBjoJEBGZABGZABGZABGZABGfjiDCigCqjZWt8HLAMyIAMyIAMy IAMyIAMyUCUD
sy6ge/bsSdbLro+vq4uaAXW3y90uGZABGZABGZABGZABGZCBghnQppy1l1pw 7e8BbR/H0IKo
gHrR18qu/ciaDMiADMiADMiADMiADOQz8EUzoE1p2y64VAFdLp1DZy4V0HwA tutc269zIwMy
IAMyIAMyIAMyIAO7LwODCujyjOQiLF0faz6/XGZT67UDV1pAF8VyuWAub39R WrtmUIc8rtnW
YjvtMpz6eLOOt+DuvheSwdM5lwEZkAEZkAEZkAEZkIF8Bv4/teFpY5bqN4EA AAAASUVORK5C
YII=
--------------000304000605080205000700--
Re: Running into NPE errors with WTP RC4 [message #170764 is a reply to message #170756] |
Wed, 07 June 2006 14:00   |
--------------080908030302080104080903
Anad,
Yes, that looks like the same type of problem.
Anand Hatwalne wrote:
> Anand
> Ed Merks wrote:
>> Vikram,
>>> NsPrefix and Ns URI
>>> prior to this)
>>> last post.
>>> regards
>>> --vikram
boundary="------------080803070200090400040901"
--------------080803070200090400040901
<html>
<head>
</head>
Anad,<br>
<br>
Yes, that looks like the same type of problem.<br>
<br>
<br>
<blockquote cite="mide66ask$ldg$1@utils.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
Anand
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Vikram,
<br>
<br>
FUDForum. Page generated in 0.04805 seconds
