Home » Modeling » OCL » Exception on custom error message with complete OCL
Exception on custom error message with complete OCL [message #1707399] Fri, 04 September 2015 09:24 Go to next message
Hi there,
I follow this recipe to connect my custom Ecore file with my custom
ocl-File: http://wiki.eclipse.org/EMF/Validation/Recipes
The recipe uses some of the provided example projects, e.g.
org.eclipse.emf.validation.examples.ocl. This defines some glue code
that parses the OCL-file at runtime and creates some ConstraintProvider
for EMF if I understand correctly.
I provide a simple CompleteOCL file with rules as such
context Socket
inv emptyID('Socket has to have valid ID.'+self.toString()):
self.id <> ''
This is parsed correctly by the CompleteOCL-Xtext-Editor and I do not
get any error. However, running the example, during runtime I get the
exception below.
Looking in the class
org.eclipse.emf.validation.examples.ocl.OCLConstraintProvider, I
understand that the example uses org.eclipse.ocl.ecore.OCL to parse the
file. Is that something different to the CompleteOCL-Editor and might
not support custom string messages? Sorry, but I'm not so much into the
differences between the different flavors of OCL within Eclipse.
Any hint appreciated.
Hauke
!ENTRY org.eclipse.emf.validation.examples.ocl 4 1 2015-09-04 14:57:52.433
!MESSAGE Failed to parse OCL constraints in
org.eclipse.emf.validation.examples.ocl:constraints/core.ocl
!STACK 0
org.eclipse.ocl.SyntaxException: 7:5:7:11 ":" expected after "emptyID"
at org.eclipse.ocl.util.OCLUtil.checkForErrors(OCLUtil.java:350)
at org.eclipse.ocl.OCL.parse(OCL.java:317)
at
org.eclipse.emf.validation.examples.ocl.OCLConstraintProvider.parseConstraints(OCLConstraintProvider.java:127)
at
org.eclipse.emf.validation.examples.ocl.OCLConstraintProvider.parseConstraints(OCLConstraintProvider.java:104)
at
org.eclipse.emf.validation.examples.ocl.OCLConstraintProvider.setInitializationData(OCLConstraintProvider.java:78)
at
org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:251)
at
org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at
org.eclipse.emf.validation.internal.service.ProviderDescriptor.getProvider(ProviderDescriptor.java:268)
at
org.eclipse.emf.validation.internal.service.ConstraintCache.execute(ConstraintCache.java:285)
at
org.eclipse.emf.validation.internal.service.ConstraintCache.getBatchConstraints(ConstraintCache.java:386)
at
org.eclipse.emf.validation.internal.service.GetBatchConstraintsOperation.executeImpl(GetBatchConstraintsOperation.java:57)
at
org.eclipse.emf.validation.internal.service.AbstractGetConstraintsOperation.execute(AbstractGetConstraintsOperation.java:132)
at
org.eclipse.emf.validation.service.ModelValidationService.execute(ModelValidationService.java:541)
at
org.eclipse.emf.validation.service.ModelValidationService.access$6(ModelValidationService.java:529)
at
org.eclipse.emf.validation.service.ModelValidationService$4.execute(ModelValidationService.java:343)
at
org.eclipse.emf.validation.internal.service.AbstractValidator.execute(AbstractValidator.java:294)
at
org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:262)
at
org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:211)
at
org.eclipse.emf.validation.internal.service.BatchValidator.doValidate(BatchValidator.java:149)
at
org.eclipse.emf.validation.internal.service.AbstractValidator.validate(AbstractValidator.java:147)
at
org.eclipse.emf.validation.internal.service.AbstractValidator.validate(AbstractValidator.java:126)
at
org.eclipse.emf.validation.internal.service.BatchValidator.validate(BatchValidator.java:117)
at
org.eclipse.emf.validation.examples.adapter.EValidatorAdapter.validate(EValidatorAdapter.java:88)
at
org.eclipse.emf.ecore.util.Diagnostician.doValidate(Diagnostician.java:171)
at
org.eclipse.emf.edit.ui.action.ValidateAction$3.doValidate(ValidateAction.java:309)
at
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:158)
at
org.eclipse.emf.ecore.util.Diagnostician.validate(Diagnostician.java:137)
at
org.eclipse.emf.edit.ui.action.ValidateAction.validate(ValidateAction.java:264)
at
org.eclipse.emf.edit.ui.action.ValidateAction$1.run(ValidateAction.java:176)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:119)
Re: Exception on custom error message with complete OCL [message #1707550 is a reply to message #1707399] Mon, 07 September 2015 05:34 Go to previous messageGo to next message
[Reply reposted on-list this time.]
The general EMFv technology predates the EValidator framework and so it
does not integrate well with EMF.
The EMFv OCL integration was the first attempt and revealed many
problems. It inspired the far superior EMF delegates solution which is
supported by the OCLinEcore editor and works with both Classic
(Ecore/UML) and Pivot-based OCL implementations.
Pivot OCL prototypes many new facilities for the OCL specification; some of
these have been backported to Classic OCL. Custom messages is an extension
supported by both, but are not supported by EMF's EValiditor.
You therefore have to ensure that a custom-message-aware EValidator is
installed. I very much doubt the EMFv does this.
Revisiting the EMFv approach is on my to-do list, but it's a very long list and it
is way down my priority list. One possible approach is an alternative Save
capability from an OCL editor to store the OCL in CDATA form. More
realistically significant development is needed on the various bugs that
inhibit extension of EMFv to support OCL constraint providers. This is a
particularly severe problem for OCL in UML profiles.
Ed Willink
On 04/09/2015 14:24, Hauke Fuhrmann wrote:
> Hi there,
> ConstraintProvider for EMF if I understand correctly.
> context Socket
> self.id <> ''
> exception below.
> the file. Is that something different to the CompleteOCL-Editor and
> might not support custom string messages? Sorry, but I'm not so much
> into the differences between the different flavors of OCL within Eclipse.
> Cheers,
> Hauke
> 14:57:52.433
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Exception on custom error message with complete OCL [message #1707554 is a reply to message #1707550] Mon, 07 September 2015 06:05 Go to previous messageGo to next message
thanks for the insights. Sounds like the validation topic is a little
intermingled due to the historic growth of the approaches.
I was mainly confused due to the situation of documentation at the
Eclipse help. At http://help.eclipse.org/ there is only some
documentation from 2005 in the EMF Developer Guide called "EMF
Validation Overview". I guess this describes the EValidator topic,
briefly, right? For EMFv there is no documentation there at all, lacking
also any descriptions for the different extension points provided by the
framework. For the OCL-Topics, there is some documentation, however, it
mainly touches the end-user-guis and explicitly stresses the OCLinEcore
Editor. Other frameworks like Xtext or EMFForms tend to bring in some
additional layer to validation in their own layer; so the interface for
the end-user is, again, something different. So what I explicitly miss
is these kind of background information that helps to sort the different
technologies and to understand where what kind of glue-code is needed.
So are you aware of any introducing article or book about this topic? Or
are you aware of companies that are experts and doing commercial support
for it to help integrate the technology in the proper manner?
I will now work through the OCL documentation from the beginning to try
to understand it at least from the OCL-point-of-view.
Hauke
Am 07.09.2015 11:34, schrieb Ed Willink:
> Hi
> list and it
> Regards
> Ed Willink
>> Hi there,
>> context Socket
>> self.id <> ''
>> exception below.
>> Cheers,
>> Hauke
>> 14:57:52.433
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: Exception on custom error message with complete OCL [message #1707555 is a reply to message #1707554] Mon, 07 September 2015 06:24 Go to previous message
Eclipse OCL used to be a Modeling component like Eclipse UML2; useful
Java functionality, very limited UI.
Eclipse OCL has grown significantly to have useful UI (Papyrus provides
UML2 UI).
The tutorials in the OCL documentation are much better than nothing.
An Eclipse OCL book is on my to-do list, but so are very many other much
more exciting things. Certainly won't be done till the revised OMG OCL
specification is done.
Ed Willink
On 07/09/2015 11:05, Hauke Fuhrmann wrote:
> lacking also any descriptions for the different extension points
> provided by the framework. For the OCL-Topics, there is some
> documentation, however, it mainly touches the end-user-guis and
> explicitly stresses the OCLinEcore Editor. Other frameworks like
> Xtext or EMFForms tend to bring in some additional layer to validation
> in their own layer; so the interface for the end-user is, again,
> something different. So what I explicitly miss is these kind of
> background information that helps to sort the different technologies
> Or are you aware of companies that are experts and doing commercial
> support for it to help integrate the technology in the proper manner?
> try to understand it at least from the OCL-point-of-view.
> Cheers,
> Hauke
>> Hi
>> some of
>> extension
>> list and it
>> Save
>> Regards
>> Ed Willink
>>> Hi there,
>>> context Socket
>>> self.id <> ''
>>> exception below.
>>> Eclipse.
>>> Cheers,
>>> Hauke
>>> 14:57:52.433
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Previous Topic:Unable to resolve OCL pivot variable types in standalone mode during a M2M transformation
Next Topic:OCLInECore standalone, Mars
Current Time: Sat Jul 26 11:36:37 EDT 2025
Powered by FUDForum. Page generated in 0.04125 seconds
