Home » Newcomers » Newcomers » Eclipse won't start
Eclipse won't start [message #1407865] Wed, 13 August 2014 12:49 Go to next message
Yes , I read the message at the head of this forum, and modified the ini file as suggested. Bur still. Eclipse does not start. And now I get this message
The JVM shared library "/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/../lib/server/libjvm.dylib"
does not contain the JNI_CreateJavaVM symbol.
Here is my ini file:
-startup
../../../plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
--launcher.library
../../../plugins/org.eclipse.equinox.launcher.cocoa.macosx.x86_64_1.1.200.v20140603-1326
-product
org.eclipse.epp.package.standard.product
--launcher.defaultAction
openFile
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
openFile
-vm
/Library/Internet Plug-ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
--launcher.appendVmargs
-vmargs
-Dosgi.requiredJavaVersion=1.7
-XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts
-XX:MaxPermSize=256m
-Xms40m
-Xmx512m
-Xdock:icon=../Resources/Eclipse.icns
I am completely new to Eclipse. I had a previous customized version from The Standford university which had no problem. I uninstalled everything before installing this version.
Can someone help me get this program running.
Thanks in advance
Claude
Re: Eclipse won't start [message #1408218 is a reply to message #1407865] Thu, 14 August 2014 10:18 Go to previous messageGo to next message
You've pointed -vm to a strange Java version. Try using one of the standard locations as described in https://wiki.eclipse.org/Eclipse.ini#-vm_value:_Mac_OS_X_Example
Re: Eclipse won't start [message #1408540 is a reply to message #1408218] Fri, 15 August 2014 06:16 Go to previous messageGo to next message
Thanks Eric for your post.It helped me to figure out what was the problem. In fact the java directory was empty.
It turned out that I only had the JRE installed. Once I installed the JDK, Eclipse launched and worked.
Eclipse could have told me that the JDK was not installed at install!
Thanks again.
Claude
Re: Eclipse won't start [message #1408600 is a reply to message #1408540] Fri, 15 August 2014 10:29 Go to previous messageGo to next message
Eclipse could not have told you anything, because Eclipse can't run without a valid JVM in which to run. JVM management on OS X is really messed up, and Apple has made it worse with every update.
Re: Eclipse won't start [message #1629706 is a reply to message #1408600] Sun, 22 February 2015 16:25 Go to previous messageGo to next message
I have a similar problem but the solution outlined here doesn't work.
I modified the -vm param as suggested (see below) and it gets me the error message about missing JNI symbols in the /Library/Internet Plug-ins/JavaAppletPlugin.plugin/Contents/Home/bin/.../libserver/ etc library.
The weird thing is that I don't reference this library anywhere in my eclipse.ini
If I run the command line:
./eclipse -vm /Library/Java/JavaVirtualMachines/jdk1.8.0_31.jdk/Contents/Home/bin/java
then eclipse starts up fine!
I used to have Kepler and it worked. I installed Luna and this is when it stopped working. After that I also installed Java 8 from Java 7.
Here is my eclipse.ini file
Thanks LOT for looking into this, it drives me slightly mad.
-startup
--launcher.library
-product
org.eclipse.epp.package.java.product
openFile
-showsplash
256m
openFile
--vm
-vmargs
-Dosgi.requiredJavaVersion=1.6
-Xms40m
-Xmx512m
Re: Eclipse won't start [message #1705221 is a reply to message #1629706] Wed, 12 August 2015 20:18 Go to previous messageGo to next message
You have a mistake in you eclipse.ini.
The vm parameter in your file should be:
-vm
/Library/Java/JavaVirtualMachines/jdk1.8.0_51.jdk/Contents/Home/bin/java
Please note that you shpuld put only one '-' character before the vm parameter.
Cheers.
Re: Eclipse won't start [message #1707298 is a reply to message #1705221] Thu, 03 September 2015 10:28 Go to previous messageGo to next message
I just installed Java EE 8 from Oracle, and my /Library/Java/JavaVirtualMachines directory is empty! Could there be some difference between EE and the standard JDK?
Java 8 is installed in /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin. This Terminal command:
/Library/Internet\ Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java -version
produces this output:
java version "1.8.0_60"
Java(TM) SE Runtime Environment (build 1.8.0_60-b27)
Java HotSpot(TM) 64-Bit Server VM (build 25.60-b23, mixed mode)
I do have Java 1.6 installed in /System/Library/Java/JavaVirtualMachines. Don't know how it got there. Maybe it's the one that Mars offered to install and then said it couldn't use because it needs at least 1.7!
Re: Eclipse won't start [message #1707305 is a reply to message #1707298] Thu, 03 September 2015 11:07 Go to previous messageGo to next message
OK, I seem to have gotten it working. Issues:
1. When you "download Java for Mac" from the Oracle site, you only get the runtime, which installs in the /Library/Internet Plug-Ins/... directory. I had to explicitly search Oracle for the JDK download, which installs (as expected) in /Library/Java/JavaVirtualMachines.
2. I had to edit the Eclipse.ini file, but the commented-out lines in it are wrong.
It's not:
<string>-vm</string><string>/Library/Java/JavaVirtualMachines/1.8.0.jdk/Contents/Home/bin/java</string>
It's:
<string>-vm</string><string>/Library/Java/JavaVirtualMachines/jdk1.8.0_60.jdk/Contents/Home/bin/java</string>
Note the name difference for the .jdk directory.
Hopefully I won't have to go through this each time Java gets an update.
Re: Eclipse won't start [message #1707311 is a reply to message #1707305] Thu, 03 September 2015 12:03 Go to previous messageGo to next message
Yes, Apple made a terrible mess when they were responsible for the JRE and JDK releases for OS X. Oracle might or might not be doing better about it.
In any case, the Eclipse Installer (Oomph) that's available now does a pretty good job of identifying JREs/JDKs on your system and configuring eclipse.ini the right way. Give it a try next time you want to install Eclipse.
Re: Eclipse won't start [message #1707369 is a reply to message #1707311] Fri, 04 September 2015 05:15 Go to previous messageGo to next message
I have a problem with eclipse.
It won't strat /windows/ and have a long log. I paste the end of the log.
!MESSAGE Missing required bundle org.eclipse.ui.ide_[3.2.0,4.0.0).
!SUBENTRY 2 org.eclipse.wst.xsd.ui 2 0 2015-09-04 10:23:28.620
!MESSAGE Missing required bundle org.eclipse.emf.edit.ui_[2.2.0,3.0.0).
!MESSAGE Missing required bundle org.eclipse.ltk.ui.refactoring_[3.2.0,4.0.0).
!MESSAGE Missing required bundle org.eclipse.search_[3.2.0,4.0.0).
!ENTRY org.eclipse.osgi 4 0 2015-09-04 10:23:28.630
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "org.eclipse.ui.ide.workbench" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.jdt.core.JavaIndexer.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
Can anybody help me?
Re: Eclipse won't start [message #1707422 is a reply to message #1707369] Fri, 04 September 2015 11:25 Go to previous messageGo to next message
On 09/04/2015 04:14 AM, Andras Menyhart wrote:
> Hello,
> I have a problem with eclipse. It won't strat /windows/ and have a long
> [snip]
You shouldn't hijack forum threads.
Did you check out the sticky posts at forum's top? There's one
especially for you.
Re: Eclipse won't start [message #1707547 is a reply to message #1707422] Mon, 07 September 2015 05:02 Go to previous messageGo to next message
I checked but didn't find solution for this problem.
Re: Eclipse won't start [message #1707617 is a reply to message #1707547] Mon, 07 September 2015 20:32 Go to previous messageGo to next message
https://www.eclipse.org/forums/index.php/t/198527/
Re: Eclipse won't start [message #1707629 is a reply to message #1707617] Tue, 08 September 2015 02:16 Go to previous messageGo to next message
I think the issue is with the link. /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java links to the java Plugin for safari, which is different from the regular version of java.
When you changed the link, you changed the link from a valid jvm to a plugin.
java -version returns the default version of java, which on Macs, is jdk 6, and comes with your mac. To get the location of all versions of java, run /usr/libexec/java_home, which on my mac, leads to /Library/Java/JavaVirtualMachines/jdk1.8.0_40.jdk/Contents/Home.
Another way to list all Java installations is by opening the Java Control Panel, which should be openable from System Preferences.
Hope this helps!
Re: Eclipse won't start [message #1737826 is a reply to message #1707311] Wed, 13 July 2016 06:28 Go to previous messageGo to next message
Eric Rizzo wrote on Thu, 03 September 2015 16:03
Ok so I just tried this. I have installed the JRE which will go into the Internet Plugins path mentioned above. The latest eclipse installer does NOT recognize this location so I had to select it manually after which 1 new JVM installation is found. When bootstrap finishes, the error about the missing CreateJVM Symbol pops up. I will now try the JDK version and see what happens, but it would be great to get it working just with the jre.
Re: Eclipse won't start [message #1738378 is a reply to message #1737826] Tue, 19 July 2016 06:47 Go to previous message
I have the same problem and I will try the methods mentioned here. Thanks.
Previous Topic:Eclipse Unzip-Plugin with the Sonatype Nexus 3.0
Next Topic:Setting SSH connection on secondary ethernet card
Current Time: Mon Jul 21 11:16:01 EDT 2025
Powered by FUDForum. Page generated in 0.10163 seconds
