Home » Modeling » TMF (Xtext) » dangling reference with models from different files
dangling reference with models from different files [message #1620562] Tue, 17 February 2015 04:17 Go to next message
hello.
with the following grammar
Model:
	classes+=Class*
Class:
	'class' name=ID '{'
		variables += Variable*
		statements += Statement*
Variable:
	name=ID ':' type=Type ';'
Type:
	PrimitiveType | ClassType
PrimitiveType:
	type=PrimitiveTypes
ClassType:
	refClass = [Class]
enum PrimitiveTypes:
	BOOL | INT | REAL
Statement:
	lValue=LValue '=' rValue=RValue ';'
LValue:
	VariableRef
RValue:
	VariableRef | ConstantLiteral
VariableRef:
	variable=[Variable] ({VariableRef.qualifier=current} '.' variable=[Variable])*
ConstantLiteral:
	value=INT
and the following scope provider
override getScope(EObject context, EReference reference) {
	if (reference == MyDslPackage.eINSTANCE.variableRef_Variable) {
		if (context instanceof VariableRef) {
			val type = context.qualifier?.variable?.type
			if (type instanceof ClassType) {
				return Scopes.scopeFor(type.refClass.variables)
	return super.getScope(context, reference)
i have a project with two files
file1 with
class A {
	x: INT;
        y: INT;
class B {
	vc: C;
class D {
	vb: B;
	vb.vc.va.x = 2;
and file2 with
class C {
	va: A;
if i edit the line vb.vc.va.x = 2; in file1 (e.g. delete x, activate content assist and choose y) i get a dangling reference error.
this happens because the file1 is reparsed and new model objects are instantiated. on the other hand file2 isn't reparsed and the model object keeps a reference to the old model objects from file1. How can I force file2 to be reparsed as well? The DefaultResourceDescriptionManager.isAffected is not called when editing and even after saving it isn't called with file2 as candidate.
I was able to solve the problem by adding the following code to the scope provider but I'm not sure if this is the way to go.
				var class = type.refClass
				if (class.eResource == null) {
					val uriFragment = EcoreUtil.getURI(class).fragment
					class = context.eResource.getEObject(uriFragment) as org.xtext.example.mydsl.myDsl.Class
				return Scopes.scopeFor(class.variables)
How would you solve the problem?
Thanks in advance!
Re: dangling reference with models from different files [message #1707251 is a reply to message #1620562] Thu, 03 September 2015 05:59 Go to previous messageGo to next message
This post has yet been replied over several months.
I wonder if anyone found a solution on this issue?
I faced the same situations in the last few days, and finally conclude to the same cause.
I made a workaround by checking the eResource of the EObject, and the eResource of the referenced EObject. If they are from different resources, I will unload the other resource, then resolveAll the other resource right after the unload. Since doing this will make all references in the other resource up-to-date. A pseudo code might look like this:
VariableRef:
someDispatchFunction(VariableRef variableRef){
if(!variableRef.eResource.equals(variableRef.variable.eResource)){
variableRef.variable.eResource.unload()
//rset.createResource(rsURI)
variableRef.variable.eResource.resolveAll
This inefficient workaround temporarily solves this issue. But as you can clearly see, this method is very not a good choice for large project. I wonder if anyone has better solution on this issue? Or any suggestions??
A better method I can think of is to to override default behavior the lazy-linker, through checking all references in other resources which are referencing the current resource in edit.
Thank you.
Yu-Jiu
Re: dangling reference with models from different files [message #1707287 is a reply to message #1707251] Thu, 03 September 2015 09:34 Go to previous messageGo to next message
did you try my solution for that problem: https://christiandietrich.wordpress.com/2013/05/18/xtext-and-dot-expressions/
Re: dangling reference with models from different files [message #1707339 is a reply to message #1707287] Thu, 03 September 2015 16:09 Go to previous messageGo to next message
Dear Christian,
I had read many of your posts over the year. Your articles help me a lot. Thank you.
The problem I faced is a different one. It only happen when we have 'Entity' defined across several files. Let's extend your "Xtext and Dot/Path-Expressions" post to repeat this issue.
First, let's try to add a custom ResourceDescriptionStrategy to export 'Entity' to index.
package org.xtext.example.mydsl.scoping
import org.eclipse.xtext.resource.impl.DefaultResourceDescriptionStrategy
import com.google.inject.Singleton
import com.google.inject.Inject
import org.eclipse.xtext.naming.IQualifiedNameProvider
import org.xtext.example.mydsl.myDsl.Entity
import org.eclipse.xtext.resource.EObjectDescription
import org.eclipse.emf.ecore.EObject
import org.eclipse.xtext.util.IAcceptor
import org.eclipse.xtext.resource.IEObjectDescription
import static extension org.eclipse.xtext.EcoreUtil2.*
import org.xtext.example.mydsl.myDsl.Model
@Singleton
class myDslResourceDescriptionStrategy extends DefaultResourceDescriptionStrategy{
	@Inject extension IQualifiedNameProvider
	override createEObjectDescriptions(EObject eObj, IAcceptor<IEObjectDescription> acceptor){
		if(eObj instanceof Model){
			(eObj as Model).getAllContentsOfType(typeof(Entity)).forEach[it|
				acceptor.accept(EObjectDescription::create((it as Entity).fullyQualifiedName, (it as Entity)))
			true
		} 	else false
Then, let's improve the MyDslScopeProvider to access the global index.
	def IScope scope_EntityRef_entity(EntityRef entity, EReference ref) {
		val model = entity.getContainerOfType(typeof(Model)) as Model
		val outerScope=delegateGetScope(model, ref)
		val currentScope=Scopes::scopeFor(model.getAllContentsOfType(typeof(Entity)), outerScope)
		return currentScope
	def IScope scope_Reference_type(Reference context, EReference ref) {
		val model = context.getContainerOfType(typeof(Model)) as Model
		val outerScope=delegateGetScope(context.getContainerOfType(typeof(Model)), ref)
		val currentScope=Scopes::scopeFor(context.getAllContentsOfType(typeof(Entity)), outerScope)
		return currentScope
And don't forget to change the MyDslRuntimeModule.
org.xtext.example.mydsl.AbstractMyDslRuntimeModule {
    public Class<? extends IDefaultResourceDescriptionStrategy> bindIDefaultResourceDescriptionStrategy() {
        return myDslResourceDescriptionStrategy.class;
Then, let's separate the test code into two separate files:
1. test1.mydsl
entity A {
    attr a1 : int
    attr a2 : string
    ref b : B
    ref c : C
entity C {
    attr c1 : string
    attr c2 : int
2. test2.mydsl
entity B {
    attr b1 : string
    attr b2 : string
    ref a : A
    ref c : C
use A.b.b2
use A.b.c.c1
use A.a1
use A.b.a.a1
Now, you can see in the editor of the second test file, where the b2 of A.b.b2; c of A.b.c.c1, the a of A.b.a showing dangling reference error. This is due to when we update test2.mydsl in the editor, the eResource of test2.mydsl is reparsed, which make all references in test1.mydsl back to Entity B in test1.mydsl out-of-date.
Obviously my previous workaround cannot be put inside the scope-provider; otherwise it will result in a endless job.
Any suggestions on these?
Yu-Jiu
Re: dangling reference with models from different files [message #1707342 is a reply to message #1707339] Thu, 03 September 2015 16:21 Go to previous messageGo to next message
hi,
why do you add these methods to the scope provider?
delegateGetScope already adds all local and global entities
[Updated on: Thu, 03 September 2015 16:22] by Moderator
Re: dangling reference with models from different files [message #1707343 is a reply to message #1707342] Thu, 03 September 2015 16:24 Go to previous messageGo to next message
=> the problem is that a is not reparsed. so let us force it to do so?
Re: dangling reference with models from different files [message #1707346 is a reply to message #1707343] Thu, 03 September 2015 16:34 Go to previous messageGo to next message
class MyDslResourceDescriptionManager extends DefaultResourceDescriptionManager implements IResourceDescription.Manager.AllChangeAware {
	override isAffectedByAny(Collection<Delta> deltas, IResourceDescription candidate,
		IResourceDescriptions context) throws IllegalArgumentException {
		for (delta : deltas) {
			val Set<QualifiedName> names = Sets.newHashSet()
			addExportedNames(names, delta.getOld())
			addExportedNames(names, delta.getNew())
			val result = !Collections.disjoint(names, getImportedNames(candidate))
			println(candidate)
			println(result)
			if (result) {
				return true
		return false
Re: dangling reference with models from different files [message #1707446 is a reply to message #1707346] Fri, 04 September 2015 14:30 Go to previous messageGo to next message
Thank you Christian, the codes you provide really works!
Overriding the default DefaultResourceDescriptionManager by implementing the isAffectedByAny(Collection<Delta> deltas, IResourceDescription candidate, IResourceDescriptions context) changes the default builder behavior to reflect the resources that are affected by the current file in edit!
I try to go through some related codes, and I found that the default method called by builder:
isAffected(Collection<Delta> deltas, IResourceDescription candidate, IResourceDescriptions context) in the DefaultResourceDescriptionManager shares the same input parameters as the method:
isAffectedByAny() of IResourceDescription.Manager.AllChangeAware
So, I try to track the execution of the default isAffected() method:
	public boolean isAffected(Collection<Delta> deltas, IResourceDescription candidate, IResourceDescriptions context) {
        Set<URI> outgoingReferences = descriptionUtils.collectOutgoingReferences(candidate);
        if (!outgoingReferences.isEmpty()) {
	        for (IResourceDescription.Delta delta : deltas)
	            if (hasChanges(delta, candidate) && outgoingReferences.contains(delta.getUri()))
	                return true;
        // this is a tradeoff - we could either check whether a given delta uri is contained
        // in a reachable container and check for intersecting names afterwards, or we can do
        // the other way round
        // unfortunately there is no way to decide reliably which algorithm scales better
        // note that this method is called for each description so we have something like a
        // number of deltas x number of resources which is not really nice
        List<IContainer> containers = null;
        Collection<QualifiedName> importedNames = getImportedNames(candidate);
        for (IResourceDescription.Delta delta : deltas) {
			if (hasChanges(delta, candidate)) {
				// not a java resource - delta's resource should be contained in a visible container
				// as long as we did not delete the resource
				URI uri = delta.getUri();
				if ((uri.isPlatform() || uri.isArchive()) && delta.getNew() != null) {
					if (containers == null)
						containers = containerManager.getVisibleContainers(candidate, context);
					boolean descriptionIsContained = false;
					for(int i = 0; i < containers.size() && !descriptionIsContained; i++) {
						descriptionIsContained = containers.get(i).hasResourceDescription(uri);
					if (!descriptionIsContained)
						return false;
				if (isAffected(importedNames, delta.getNew()) || isAffected(importedNames, delta.getOld())) {
					return true;
        return false;
What I found is that the two occurrences of the hasChanges(delta, candidate) inside the conditionals of the above codes always return false for our test codes. So, the default
isAffected(Collection<Delta> deltas, IResourceDescription candidate, IResourceDescriptions context) always return a false, which prevent the builder to reparse the affected resource. And eventually causes the problem that we have here.
So, for the default hasChanges() method; instead checking whether the file in-edit is changed using hasChanges(delta, candidate), might it be more correct to check whether the file in edit is reparsed and its eResource is recreated? Since hasChanges() eventually calls DefaultResourceDescriptionDelta.haveEObjectDescriptionsChanged(), and it only compares the changes of EObjectDescriptions of the old/new versoin of an eResource, but not the reparse and re-creation of the EObjects for the resource in edit?
Any comments or suggestions?
Yu-Jiu
Re: dangling reference with models from different files [message #1707454 is a reply to message #1707446] Fri, 04 September 2015 15:06 Go to previous messageGo to next message
this is why i implement IResourceDescription.Manager.AllChangeAware
you could try to modify hasChanged as well.
the code is an optimization and trys to reparse as few as possible.
Re: dangling reference with models from different files [message #1716476 is a reply to message #1707454] Fri, 04 December 2015 04:35 Go to previous message
Thank you. After replacing the DefaultResourceDescriptionManager as instructed it works.
Previous Topic:Change Quickfix order
Next Topic:Getting started
Current Time: Tue Aug 12 03:46:36 EDT 2025
Powered by FUDForum. Page generated in 0.07548 seconds
