dangling reference with models from different files [message #1620562] |
Tue, 17 February 2015 04:17  |
hello.
with the following grammar
Model:
classes+=Class*
Class:
'class' name=ID '{'
variables += Variable*
statements += Statement*
Variable:
name=ID ':' type=Type ';'
Type:
PrimitiveType | ClassType
PrimitiveType:
type=PrimitiveTypes
ClassType:
refClass = [Class]
enum PrimitiveTypes:
BOOL | INT | REAL
Statement:
lValue=LValue '=' rValue=RValue ';'
LValue:
VariableRef
RValue:
VariableRef | ConstantLiteral
VariableRef:
variable=[Variable] ({VariableRef.qualifier=current} '.' variable=[Variable])*
ConstantLiteral:
value=INT
and the following scope provider
override getScope(EObject context, EReference reference) {
if (reference == MyDslPackage.eINSTANCE.variableRef_Variable) {
if (context instanceof VariableRef) {
val type = context.qualifier?.variable?.type
if (type instanceof ClassType) {
return Scopes.scopeFor(type.refClass.variables)
return super.getScope(context, reference)
i have a project with two files
file1 with
class A {
x: INT;
y: INT;
class B {
vc: C;
class D {
vb: B;
vb.vc.va.x = 2;
and file2 with
if i edit the line vb.vc.va.x = 2; in file1 (e.g. delete x, activate content assist and choose y) i get a dangling reference error.
this happens because the file1 is reparsed and new model objects are instantiated. on the other hand file2 isn't reparsed and the model object keeps a reference to the old model objects from file1. How can I force file2 to be reparsed as well? The DefaultResourceDescriptionManager.isAffected is not called when editing and even after saving it isn't called with file2 as candidate.
I was able to solve the problem by adding the following code to the scope provider but I'm not sure if this is the way to go.
var class = type.refClass
if (class.eResource == null) {
val uriFragment = EcoreUtil.getURI(class).fragment
class = context.eResource.getEObject(uriFragment) as org.xtext.example.mydsl.myDsl.Class
return Scopes.scopeFor(class.variables)
How would you solve the problem?
Thanks in advance!
Re: dangling reference with models from different files [message #1707339 is a reply to message #1707287] |
Thu, 03 September 2015 16:09   |
Dear Christian,
I had read many of your posts over the year. Your articles help me a lot. Thank you.
The problem I faced is a different one. It only happen when we have 'Entity' defined across several files. Let's extend your "Xtext and Dot/Path-Expressions" post to repeat this issue.
First, let's try to add a custom ResourceDescriptionStrategy to export 'Entity' to index.
package org.xtext.example.mydsl.scoping
import org.eclipse.xtext.resource.impl.DefaultResourceDescriptionStrategy
import com.google.inject.Singleton
import com.google.inject.Inject
import org.eclipse.xtext.naming.IQualifiedNameProvider
import org.xtext.example.mydsl.myDsl.Entity
import org.eclipse.xtext.resource.EObjectDescription
import org.eclipse.emf.ecore.EObject
import org.eclipse.xtext.util.IAcceptor
import org.eclipse.xtext.resource.IEObjectDescription
import static extension org.eclipse.xtext.EcoreUtil2.*
import org.xtext.example.mydsl.myDsl.Model
@Singleton
class myDslResourceDescriptionStrategy extends DefaultResourceDescriptionStrategy{
@Inject extension IQualifiedNameProvider
override createEObjectDescriptions(EObject eObj, IAcceptor<IEObjectDescription> acceptor){
if(eObj instanceof Model){
(eObj as Model).getAllContentsOfType(typeof(Entity)).forEach[it|
acceptor.accept(EObjectDescription::create((it as Entity).fullyQualifiedName, (it as Entity)))
true
} else false
Then, let's improve the MyDslScopeProvider to access the global index.
def IScope scope_EntityRef_entity(EntityRef entity, EReference ref) {
val model = entity.getContainerOfType(typeof(Model)) as Model
val outerScope=delegateGetScope(model, ref)
val currentScope=Scopes::scopeFor(model.getAllContentsOfType(typeof(Entity)), outerScope)
return currentScope
def IScope scope_Reference_type(Reference context, EReference ref) {
val model = context.getContainerOfType(typeof(Model)) as Model
val outerScope=delegateGetScope(context.getContainerOfType(typeof(Model)), ref)
val currentScope=Scopes::scopeFor(context.getAllContentsOfType(typeof(Entity)), outerScope)
return currentScope
And don't forget to change the MyDslRuntimeModule.
org.xtext.example.mydsl.AbstractMyDslRuntimeModule {
public Class<? extends IDefaultResourceDescriptionStrategy> bindIDefaultResourceDescriptionStrategy() {
return myDslResourceDescriptionStrategy.class;
Then, let's separate the test code into two separate files:
1. test1.mydsl
entity A {
attr a1 : int
attr a2 : string
ref b : B
ref c : C
entity C {
attr c1 : string
attr c2 : int
2. test2.mydsl
entity B {
attr b1 : string
attr b2 : string
ref a : A
ref c : C
use A.b.b2
use A.b.c.c1
use A.a1
use A.b.a.a1
Now, you can see in the editor of the second test file, where the b2 of A.b.b2; c of A.b.c.c1, the a of A.b.a showing dangling reference error. This is due to when we update test2.mydsl in the editor, the eResource of test2.mydsl is reparsed, which make all references in test1.mydsl back to Entity B in test1.mydsl out-of-date.
Obviously my previous workaround cannot be put inside the scope-provider; otherwise it will result in a endless job.
Any suggestions on these?
Yu-Jiu
Re: dangling reference with models from different files [message #1707446 is a reply to message #1707346] |
Fri, 04 September 2015 14:30   |
Thank you Christian, the codes you provide really works!
Overriding the default DefaultResourceDescriptionManager by implementing the isAffectedByAny(Collection<Delta> deltas, IResourceDescription candidate, IResourceDescriptions context) changes the default builder behavior to reflect the resources that are affected by the current file in edit!
I try to go through some related codes, and I found that the default method called by builder:
isAffected(Collection<Delta> deltas, IResourceDescription candidate, IResourceDescriptions context) in the DefaultResourceDescriptionManager shares the same input parameters as the method:
isAffectedByAny() of IResourceDescription.Manager.AllChangeAware
So, I try to track the execution of the default isAffected() method:
public boolean isAffected(Collection<Delta> deltas, IResourceDescription candidate, IResourceDescriptions context) {
Set<URI> outgoingReferences = descriptionUtils.collectOutgoingReferences(candidate);
if (!outgoingReferences.isEmpty()) {
for (IResourceDescription.Delta delta : deltas)
if (hasChanges(delta, candidate) && outgoingReferences.contains(delta.getUri()))
return true;
// this is a tradeoff - we could either check whether a given delta uri is contained
// in a reachable container and check for intersecting names afterwards, or we can do
// the other way round
// unfortunately there is no way to decide reliably which algorithm scales better
// note that this method is called for each description so we have something like a
// number of deltas x number of resources which is not really nice
List<IContainer> containers = null;
Collection<QualifiedName> importedNames = getImportedNames(candidate);
for (IResourceDescription.Delta delta : deltas) {
if (hasChanges(delta, candidate)) {
// not a java resource - delta's resource should be contained in a visible container
// as long as we did not delete the resource
URI uri = delta.getUri();
if ((uri.isPlatform() || uri.isArchive()) && delta.getNew() != null) {
if (containers == null)
containers = containerManager.getVisibleContainers(candidate, context);
boolean descriptionIsContained = false;
for(int i = 0; i < containers.size() && !descriptionIsContained; i++) {
descriptionIsContained = containers.get(i).hasResourceDescription(uri);
if (!descriptionIsContained)
return false;
if (isAffected(importedNames, delta.getNew()) || isAffected(importedNames, delta.getOld())) {
return true;
return false;
What I found is that the two occurrences of the hasChanges(delta, candidate) inside the conditionals of the above codes always return false for our test codes. So, the default
isAffected(Collection<Delta> deltas, IResourceDescription candidate, IResourceDescriptions context) always return a false, which prevent the builder to reparse the affected resource. And eventually causes the problem that we have here.
So, for the default hasChanges() method; instead checking whether the file in-edit is changed using hasChanges(delta, candidate), might it be more correct to check whether the file in edit is reparsed and its eResource is recreated? Since hasChanges() eventually calls DefaultResourceDescriptionDelta.haveEObjectDescriptionsChanged(), and it only compares the changes of EObjectDescriptions of the old/new versoin of an eResource, but not the reparse and re-creation of the EObjects for the resource in edit?
Any comments or suggestions?
Yu-Jiu
FUDForum. Page generated in 0.10121 seconds
