org.eclipse.swt.SWTException: Widget is disposed [message #1565115] |
Thu, 15 January 2015 00:14  |
!MESSAGE Exception while dispatching event org.osgi.service.event.Event [topic=checkListInfo/asyncEvent] to handler ~~.CheckListInfo$2@1722429d
!STACK 0
at org.eclipse.swt.SWT.error(SWT.java:4397)
at org.eclipse.swt.SWT.error(SWT.java:4312)
at org.eclipse.swt.SWT.error(SWT.java:4283)
at org.eclipse.swt.widgets.Widget.error(Widget.java:472)
at org.eclipse.swt.widgets.Widget.getDisplay(Widget.java:586)
at ~~.CheckListInfo$2.handleEvent(CheckListInfo.java:98)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
A view
BundleContext ctx = FrameworkUtil.getBundle(A.class).getBundleContext();
EventHandler handler = new EventHandler() {
public void handleEvent(final Event event) {
if(parent.getDisplay().getThread() == Thread.currentThread() ) {
}else {
parent.getDisplay().syncExec(new Runnable() {
public void run() {
title_txt.setText(event.getProperty("name").toString());
command_txt.setText(event.getProperty("addr").toString());
Dictionary<String,String> properties = new Hashtable<String, String>();
properties.put(EventConstants.EVENT_TOPIC, "checkListInfo/*");
ctx.registerService(EventHandler.class, handler, properties);
B view
BundleContext ctx = FrameworkUtil.getBundle(B.class).getBundleContext();
ServiceReference<EventAdmin> ref = ctx.getServiceReference(EventAdmin.class);
EventAdmin eventAdmin = ctx.getService(ref);
Event event = new Event("checkListInfo/a", map);
eventAdmin.postEvent(event);
Re: org.eclipse.swt.SWTException: Widget is disposed [message #1707199 is a reply to message #1567858] |
Thu, 03 September 2015 01:43   |
Hello there!
I just found this old thread and it seems I have the same problem.
What I want to do:
Pass information from one viewpart to another viewpart.
How I do this:
Using osgi evethandler services.
In the sender viewpart I post an event with an attached object like this:
BundleContext ctx = FrameworkUtil.getBundle(ViewLogging.class).getBundleContext();
Map<String,Object> properties = new HashMap<String, Object>();
properties.put("ENTRY", msg);
Event event = new Event(ViewTasks.EVENT_TOPIC_JUMP_TO_FNC_IN_TASK_TREE, properties);
In the receiver viepart I create an event handler and subscribe to this event. I'm doing this in the receiver viewpart's createPartControl method.
BundleContext ctx = FrameworkUtil.getBundle(ViewTasks.class).getBundleContext();
public void run() {
Message msg = (Message)event.getProperty("ENTRY");
selectTaskFromTree(msg);
properties.put(EventConstants.EVENT_TOPIC, EVENT_TOPIC_JUMP_TO_FNC_IN_TASK_TREE);
Problem:
The problem occurs when the receiver viewpart is not visible. In this case just before I post the event, I call the following:
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().showView(ViewTasks.ID);
It opens the viewpart and it seems everything is working fine, but I still get the following exception in this case:
at castle.testenv.ViewTasks$4.handleEvent(ViewTasks.java:281)
The exception is raised by the parent.getDisplay() call in the eventHandler.
Can anyone tell me how to to this right? How to avoid this SWTException?
FUDForum. Page generated in 0.08286 seconds
