Home » Archived » Sapphire » @possiblevalues annotation for ImpliedElementProperty
@possiblevalues annotation for ImpliedElementProperty [message #1707188] Wed, 02 September 2015 19:14 Go to next message
Is there any way to use
@possiblevalues( property = "/path/to/a/ImpliedElementProperty")
on a ImpliedElementProperty. For example I have
@Type(base = Name.class)
ImpliedElementProperty PROP_AUTHOR_NAME = new ImpliedElementProperty(TYPE, "AuthorName");
where name.class has 3 Value<String> - firstName, middleName, and lastName. I want to create a CONTACT_NAME property which is also of the same base type Name.class and make it refer to author names. But I am not able to use @possiblevalues to say that the CONTACT_NAME should be a valid AUTHOR_NAME
Chandrika
Re: @possiblevalues annotation for ImpliedElementProperty [message #1707192 is a reply to message #1707188] Wed, 02 September 2015 22:29 Go to previous messageGo to next message
You can't use @PossibleValues to populate multiple value properties at once. It can only be associated with a single value property.
Best you can do is something similar to the way city/state/zip is handled in the contacts sample with three separate inter-dependent PossibleValueService implementations. So if the user types in "John" as first name, they can browse last names of authors with that first name.
[Updated on: Wed, 02 September 2015 22:35] by Moderator
Re: @possiblevalues annotation for ImpliedElementProperty [message #1707331 is a reply to message #1707192] Thu, 03 September 2015 14:54 Go to previous message
Thank you for the quick response. I will check the possibleValueService implementations of city/state/zip in sapphire samples.
Previous Topic:Sapphire repositories now include .pack.gz files
Next Topic:Outline view gets minimized with no node selection and hence a empty form
Current Time: Tue Oct 28 06:01:08 EDT 2025
Powered by FUDForum. Page generated in 0.03425 seconds
