Home » Eclipse Projects » Rich Client Platform (RCP) » java.lang.RuntimeException: Application "xxxxx" could not be found in the registry
java.lang.RuntimeException: Application "xxxxx" could not be found in the registry [message #1707076] Wed, 02 September 2015 02:23 Go to next message
My application can be lanuched in testing mode (i.e., with the .product file) in Eclipse environment. But when I export it (without any errors), it cannot be lanuched properly and reports the following error:
!ENTRY org.eclipse.ui.win32 2 0 2015-09-02 14:16:10.130
!MESSAGE Could not resolve module: org.eclipse.ui.win32 [103]
  Unresolved requirement: Fragment-Host: org.eclipse.ui.ide; bundle-version="[3.2.0,4.0.0)"
    -> Bundle-SymbolicName: org.eclipse.ui.ide; bundle-version="3.10.2.v20141118-1227"; singleton:="true"
       org.eclipse.ui.ide [80]
         Unresolved requirement: Require-Bundle: org.eclipse.ui; bundle-version="[3.106.0,4.0.0)"
           -> Bundle-SymbolicName: org.eclipse.ui; bundle-version="3.106.1.v20141002-1150"; singleton:="true"
              org.eclipse.ui [77]
                Unresolved requirement: Require-Bundle: org.eclipse.ui.workbench; bundle-version="[3.105.0,4.0.0)"; visibility:="reexport"
                  -> Bundle-SymbolicName: org.eclipse.ui.workbench; bundle-version="3.106.2.v20150204-1030"; singleton:="true"
                     org.eclipse.ui.workbench [85]
                       Unresolved requirement: Import-Package: org.eclipse.e4.ui.internal.workbench.renderers.swt
                         -> Export-Package: org.eclipse.e4.ui.internal.workbench.renderers.swt; bundle-symbolic-name="org.eclipse.e4.ui.workbench.renderers.swt"; bundle-version="0.12.2.v20150204-1353"; version="0.0.0"; x-friends:="org.eclipse.ui.workbench"
                            org.eclipse.e4.ui.workbench.renderers.swt [44]
                              Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.workbench.swt; bundle-version="0.9.0"
                                -> Bundle-SymbolicName: org.eclipse.e4.ui.workbench.swt; bundle-version="0.12.100.v20141126-1150"; singleton:="true"
                                   org.eclipse.e4.ui.workbench.swt [45]
                                     Unresolved requirement: Require-Bundle: org.eclipse.e4.ui.css.core; bundle-version="0.9.0"
                                       -> Bundle-SymbolicName: org.eclipse.e4.ui.css.core; bundle-version="0.10.100.v20140424-2042"; singleton:="true"
                                          org.eclipse.e4.ui.css.core [35]
                                            Unresolved requirement: Require-Bundle: org.apache.batik.css; bundle-version="1.7.0"
!ENTRY org.eclipse.e4.ui.css.swt 2 0 2015-09-02 14:16:10.131
!MESSAGE Could not resolve module: org.eclipse.e4.ui.css.swt [36]
!ENTRY org.eclipse.osgi 4 0 2015-09-02 14:16:10.132
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "com.neusoft.ipr.license.checker" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error.
	at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
	at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Any suggestions would be appreciated. I use Eclipse Luna 4.4.2 and JDK 1.8.
BTW: most of the unrosolved bundles point to the bundle org.apache.batik.css, but it is really in the plugin list.
Thanks advance.
Re: java.lang.RuntimeException: Application "xxxxx" could not be found in the registry [message #1707092 is a reply to message #1707076] Wed, 02 September 2015 04:49 Go to previous messageGo to next message
My problem is solved.
This problem occurs because of missing org.apache.batik.css. Though this bundle is really in the plugins directory, but is not listed in the config.ini (in configuration directory). So, I manually add it in the ini file, it works. I do not know why this happens.
Re: java.lang.RuntimeException: Application "xxxxx" could not be found in the registry [message #1753020 is a reply to message #1707092] Wed, 01 February 2017 03:21 Go to previous message
I have the same problem after install Birt (Eclipse Neon, Ubuntu 16.10). I removed Birt and now my project runs fine. But what can I do if I need Birt?
Previous Topic:Preferences - Properties in non UI plugin and UI plugin
Next Topic:java.lang.RuntimeException: Application could not be found in the registry
Current Time: Sat Jul 19 01:31:55 EDT 2025
Powered by FUDForum. Page generated in 0.26303 seconds
