Home » Eclipse Projects » BPMN 2.0 Modeler » Cannot add Called Element containing a hyphen(Getting error message 'The Activity ID is not valid.')
Cannot add Called Element containing a hyphen [message #1706705] Fri, 28 August 2015 16:56 Go to next message
I've imported a BPMN2 project from JBoss BPM Suite usiing git over ssh. Some of my processes call sub-processes which are also part of the same project. However the sub-process IDs contain hyphens and this is causing me to get an error message that says. 'The Activity ID is not valid.', Is there a workaround to this issue??? I've attached a couple of screenshots to illustrate my issue
Using version 1.0.5.Final of the Modeler
Enda
Re: Cannot add Called Element containing a hyphen [message #1706870 is a reply to message #1706705] Mon, 31 August 2015 10:29 Go to previous messageGo to next message
Hi Enda,
This is a known issue and has already been reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=1253594
Should be fixed in a future release of the Modeler.
Bob
Re: Cannot add Called Element containing a hyphen [message #1706927 is a reply to message #1706870] Mon, 31 August 2015 18:15 Go to previous message
Bob,
many thanks for the reply and apologies for posting on an issue that had already been reported. I'll keep an eye on future releases for a fix.
regards,
Enda
Previous Topic:Warnings and error badges not being displayed
Next Topic:BIRT Publishing
Current Time: Wed Nov 05 13:23:45 EST 2025
Powered by FUDForum. Page generated in 0.03189 seconds
