Home » Modeling » TMF (Xtext) » Xtext Generator no NEW LINE
Xtext Generator no NEW LINE [message #1706104] Sun, 23 August 2015 04:09 Go to next message
Hello!
I have a big problem. If I code in the Xtext Generator a for loop like:
«FOR param: sig.eAllContents.toIterable.filter(typeof(parameter))»
«param.compile»
«ENDFOR»
and then I code the function param.compile and then the next for loop ist:
«FOR numeric_value:sig.eAllContents.toIterable.filter(typeof(numeric_value))»
«numeric_value.compile»
«ENDFOR»
I get as result:
parameter
numeric_value
My problem is that I don't neet the NEW LINE. I need a result like:
parameter numeric_value
How can I get rid of this NEW LINE?
Re: Xtext Generator no NEW LINE [message #1706193 is a reply to message #1706104] Mon, 24 August 2015 11:32 Go to previous messageGo to next message
Hi Hansi,
you can avoid the newline by putting the expression in one line:
«FOR numeric_value:sig.eAllContents.toIterable.filter(typeof(numeric_value))»«numeric_value.compile»«ENDFOR»
Stefan
Re: Xtext Generator no NEW LINE [message #1706226 is a reply to message #1706193] Tue, 25 August 2015 03:04 Go to previous messageGo to next message
to get a more readable code,
create a def which returns the result for each FOR loop
and just call these in your code:
«loop_parameter() loop_numeric()»
def loop_parameter '''
«param.compile»
«ENDFOR»'''
def loop_numeric '''
«ENDFOR»'''
Greetings from Frankfurt/Germany,
Uli
Re: Xtext Generator no NEW LINE [message #1706288 is a reply to message #1706226] Tue, 25 August 2015 09:25 Go to previous messageGo to next message
Both versions does not work!
Version 1 does not work because I have a function an in this function the for loop gets invoket so I have still new lines.
Version 2 does not work because in the new function I can't get access to sig.
[Updated on: Tue, 25 August 2015 09:25] by Moderator
Re: Xtext Generator no NEW LINE [message #1706299 is a reply to message #1706288] Tue, 25 August 2015 10:02 Go to previous messageGo to next message
We are giving you the best suggestions we can based on the limited information. If you want a definitive answer, you'll have to share the full code.
Re: Xtext Generator no NEW LINE [message #1706353 is a reply to message #1706299] Wed, 26 August 2015 04:25 Go to previous messageGo to next message
so add in the def line your sig as a parameter to the function:
def loop_parameter (Signature sig) ''' ...
and if you have a look at the Greetings Generator, you see a way to create a comma separated list out of a collection using map() and join()
Re: Xtext Generator no NEW LINE [message #1706740 is a reply to message #1706353] Sat, 29 August 2015 09:10 Go to previous messageGo to next message
I discovered that when I look in to xtend-gen folder and than the generator file that the generator does not generate a newLine but in my gernerated file there is a newLine.
What can I do?
Re: Xtext Generator no NEW LINE [message #1706743 is a reply to message #1706740] Sat, 29 August 2015 10:25 Go to previous messageGo to next message
can you provide a sample grammar, model and generator?
Re: Xtext Generator no NEW LINE [message #1707079 is a reply to message #1706743] Wed, 02 September 2015 03:03 Go to previous message
Another more universal suggestion:
what about creating a routine noNewlines which replaces the newlines with an empty string (or a space).
You can use them in the generator coding wherever you feel that a section of text should not contain newlines
Previous Topic:formatter2 - problem with nested objects
Next Topic:New formatter API
Current Time: Mon Jul 21 10:14:30 EDT 2025
Powered by FUDForum. Page generated in 0.05564 seconds
