Home » Eclipse Projects » e(fx)clipse » e(fx)clipse CSS Editor is nowhere to be found(Eclipse Luna 4.4.0, with e(fx)clipse 1.0.0. I cannot find e(fx)clipse CSS Editor (the one with the blue wave))
e(fx)clipse CSS Editor is nowhere to be found [message #1706482] Thu, 27 August 2015 04:59 Go to next message
Hi guys,
I am pretty new to e(fx)clipse and since I am using Eclipse Luna 4.4.0, I installed version 1.0.0 (including the XText).
After done with installation, I created a new JavaFX project.
I then opened the src > application and found two files: Main.java and application.css. In some of installation videos I have watched, they have their application.css with the CSS Editor icon, but mine has the Sublime Text icon (I made Sublime Text my default text editor for html and css files).
I tried right clicking the file and look at the applications available in open with option, but there is no e(fx)clipse CSS Editor option (i.e. only Text Editor, System Editor and Default Editor). I have attached two pictures in which one shows a normal working CSS Editor file opener and the other one is from my project explorer.
I would be very grateful if you could help me with this matter. Thank you very much
Re: e(fx)clipse CSS Editor is nowhere to be found [message #1706656 is a reply to message #1706482] Fri, 28 August 2015 08:59 Go to previous message
Why did you use 1.0.0 - if there's already 1.2.0 which is compatible with Luna? You can check through the host console (in your console view what state the e(fx)clipse bundles have by issueing "ss org.eclipse.fx" )
Previous Topic:JavaFX eclipse aware window builder
Next Topic:Where are my ScrollEvents going?
Current Time: Sun Aug 31 16:22:43 EDT 2025
Powered by FUDForum. Page generated in 0.07749 seconds
