Home » Eclipse Projects » RCP Testing Tool » Error Restarting AUT from Test Runner
Error Restarting AUT from Test Runner [message #1706440] Wed, 26 August 2015 16:18 Go to next message
I've attached the error message: "Missing System Property - Unable to relaunch the platform because the eclipse.vm property has not been set."
My system's JAVA_HOME is 1.7 due to many applications that require it, but our project is 1.8.
I've applied the argument:
-autVM "C:\dev\Java80\sdk\jre"
which results in the application working correctly. However, when I attempt to restart AUT in the middle of a test, I get the error.
In addition, to try to fix it, I tried:
-autVMArgs -vm [path\to\javaw.exe]
and that did not remedy the problem (I may have not been inputting it correctly). The application works fine when using normally, and fine when running it from RCPTT in the normal GUI environment. I tried to google the issue, but it hasn't helped very much.
  • Attachment: Capture.JPG
    (Size: 18.53KB, Downloaded 266 times)
[Updated on: Wed, 26 August 2015 16:20] by Moderator
Re: Error Restarting AUT from Test Runner [message #1706462 is a reply to message #1706440] Thu, 27 August 2015 02:18 Go to previous messageGo to next message
Could you please attach AUT log (how to get it) and the whole pom.xml (or the whole runner command line) for the further investigation?
Re: Error Restarting AUT from Test Runner [message #1706553 is a reply to message #1706462] Thu, 27 August 2015 11:55 Go to previous messageGo to next message
!SESSION 2015-08-27 09:11:53.003 -----------------------------------------------
eclipse.buildId=4.4.1.M20140925-0400
java.fullversion=JRE 1.8.0 IBM J9 2.8 Windows 7 amd64-64 Compressed References 20150410_243669 (JIT enabled, AOT enabled)
J9VM - R28_Java8_SR1_20150410_1531_B243669
JIT - tr.r14.java_20150402_88976.03
GC - R28_Java8_SR1_20150410_1531_B243669_CMPRSS
J9CL - 20150410_243669
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product [HIDDEN] -eclipse.keyring C:\dev\Designer_dev64\RTC workspace\qe.automation\results\runner-workspace\.metadata\.plugins\org.eclipse.pde.core\AUT_0/secure_storage
Command-line arguments: -product [HIDDEN] -data C:\dev\Designer_dev64\RTC workspace\qe.automation\qe.rcptt.designer\..\results/aut-workspace0 -dev file:C:/dev/Designer_dev64/RTC workspace/qe.automation/results/runner-workspace/.metadata/.plugins/org.eclipse.pde.core/AUT_0/dev.properties -os win32 -arch x86_64 -consoleLog -eclipse.keyring C:\dev\Designer_dev64\RTC workspace\qe.automation\results\runner-workspace\.metadata\.plugins\org.eclipse.pde.core\AUT_0/secure_storage
!ENTRY org.eclipse.rcptt.ctx.workbench.aspect 4 0 2015-08-27 09:11:56.581
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.ctx.workbench.aspect [1028]
Unresolved requirement: Require-Bundle: org.eclipse.ui.views.log
at org.eclipse.osgi.container.Module.start(Unknown Source)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(Unknown Source)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(Unknown Source)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(Unknown Source)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(Unknown Source)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(Unknown Source)
!ENTRY org.eclipse.rcptt.tesla.gmf 4 0 2015-08-27 09:11:56.582
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.gmf [1058]
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.diagram.core
!ENTRY org.eclipse.rcptt.tesla.gmf.aspects 4 0 2015-08-27 09:11:56.586
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.gmf.aspects [1059]
Unresolved requirement: Require-Bundle: org.eclipse.gmf.runtime.diagram.ui
!ENTRY org.eclipse.rcptt.tesla.nebula.ecl.impl 4 0 2015-08-27 09:11:56.589
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.nebula.ecl.impl [1073]
Unresolved requirement: Require-Bundle: org.eclipse.rcptt.tesla.nebula.impl; bundle-version="[2.0.0,3.0.0)"
-> Bundle-SymbolicName: org.eclipse.rcptt.tesla.nebula.impl; bundle-version="2.0.0.201506110605"; singleton:="true"
org.eclipse.rcptt.tesla.nebula.impl [1074]
Unresolved requirement: Require-Bundle: org.eclipse.nebula.widgets.grid
!ENTRY org.eclipse.rcptt.tesla.nebula.impl 4 0 2015-08-27 09:11:56.592
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.nebula.impl [1074]
!ENTRY org.eclipse.rcptt.tesla.recording.aspects.gmf 4 0 2015-08-27 09:11:56.596
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.recording.aspects.gmf [1079]
!ENTRY org.eclipse.rcptt.tesla.recording.gmf 4 0 2015-08-27 09:11:56.599
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.recording.gmf [1090]
Unresolved requirement: Require-Bundle: org.eclipse.rcptt.tesla.recording.aspects.gmf; bundle-version="[2.0.0,3.0.0)"
-> Bundle-SymbolicName: org.eclipse.rcptt.tesla.recording.aspects.gmf; bundle-version="2.0.0.201506110605"; singleton:="true"
!ENTRY org.eclipse.rcptt.tesla.recording.nebula 4 0 2015-08-27 09:11:56.601
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.recording.nebula [1092]
!ENTRY org.eclipse.rcptt.tesla.swt.aspects 1 0 2015-08-27 09:12:00.651
!MESSAGE DebugDisplayAspect activated
!STACK 0
java.lang.RuntimeException: DebugDisplayAspect activated
at org.eclipse.rcptt.tesla.swt.aspects.DebugDisplayAspect.logStackTrace(Unknown Source)
at org.eclipse.rcptt.tesla.swt.aspects.DebugDisplayAspect.<init>(Unknown Source)
at org.eclipse.rcptt.tesla.swt.aspects.DebugDisplayAspect.ajc$postClinit(Unknown Source)
at org.eclipse.rcptt.tesla.swt.aspects.DebugDisplayAspect.<clinit>(Unknown Source)
at org.eclipse.swt.widgets.Display.register(Unknown Source)
at org.eclipse.swt.widgets.Display.create(Unknown Source)
at org.eclipse.swt.graphics.Device.<init>(Unknown Source)
at org.eclipse.swt.widgets.Display.<init>(Unknown Source)
at org.eclipse.ui.internal.Workbench.createDisplay(Unknown Source)
at org.eclipse.ui.PlatformUI.createDisplay(Unknown Source)
at org.eclipse.ui.internal.ide.application.IDEApplication.createDisplay(Unknown Source)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Unknown Source)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Unknown Source)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Unknown Source)
at org.eclipse.equinox.launcher.Main.basicRun(Unknown Source)
at org.eclipse.equinox.launcher.Main.run(Unknown Source)
at org.eclipse.equinox.launcher.Main.main(Unknown Source)
!ENTRY org.eclipse.rcptt.tesla.swt.aspects 1 0 2015-08-27 09:12:00.652
!MESSAGE Display register called. This is not an error.
!STACK 0
java.lang.RuntimeException: Display register called. This is not an error.
at org.eclipse.rcptt.tesla.swt.aspects.DebugDisplayAspect.ajc$before$org_eclipse_rcptt_tesla_swt_aspects_DebugDisplayAspect$1$bba6cb74(Unknown Source)
!ENTRY org.eclipse.rcptt.ecl.client.tcp 1 0 2015-08-27 09:12:06.839
!MESSAGE sun.net.client.defaultConnectTimeout is not set. Setting to 60000
!ENTRY org.eclipse.rcptt.ecl.client.tcp 1 0 2015-08-27 09:12:06.845
!MESSAGE sun.net.client.defaultReadTimeout is not set. Setting to 120000
!ENTRY org.eclipse.rcptt.runtime.ui 1 0 2015-08-27 09:12:07.159
!MESSAGE Trying to start ECL server on port 7001
!ENTRY org.eclipse.rcptt.runtime.ui 1 0 2015-08-27 09:12:07.212
!MESSAGE ECL server started on port 7001
!ENTRY org.eclipse.rcptt.runtime.ui 1 0 2015-08-27 09:12:07.214
!MESSAGE Verified that local ECL server is working
!ENTRY org.eclipse.rcptt.runtime.ui 1 0 2015-08-27 09:12:07.215
!MESSAGE Trying to start Tesla server on port 7001
!ENTRY org.eclipse.rcptt.runtime.ui 1 0 2015-08-27 09:12:07.217
!MESSAGE Trying to start Tesla server on port 7002
!ENTRY org.eclipse.rcptt.runtime.ui 1 0 2015-08-27 09:12:07.268
!MESSAGE Tesla server started on port 7002
REM !!! Replace the value below with the path to the directory there
REM application under test (AUT) is located.
SET APP="C:\Program Files\[HIDDEN]\platform\eclipse"
SET AUT=%APP%\eclipse.exe
SET RUNNER="C:\Users\[HIDDEN]\Desktop\rcptt.runner-2.0.0\eclipse"
SET PROJECT="C:\dev\Designer_dev64\RTC workspace\qe.automation\qe.rcptt.designer"
SET VM=%APP%\jre
REM Path to directory with test results
SET RESULTS=%PROJECT%\..\results
REM Remove results dir if present
IF NOT EXIST %RESULTS% GOTO NORESULTS
RMDIR /S /Q %RESULTS%
:NORESULTS
md %RESULTS%
java -jar %RUNNER%/plugins/org.eclipse.equinox.launcher_1.3.100.v20150511-1540.jar ^
-application org.eclipse.rcptt.runner.headless ^
-data %RESULTS%/runner-workspace/ ^
-aut %AUT% ^
-autWsPrefix %RESULTS%/aut-workspace ^
-autConsolePrefix %RESULTS%/aut-output ^
-htmlReport %RESULTS%/report.html ^
-junitReport %RESULTS%/report.xml ^
-import %PROJECT% ^
-autVM %VM% ^
-testOptions "passedTestDetails=true" ^
-suites RunDevTestSuites
[Updated on: Thu, 27 August 2015 12:14] by Moderator
Re: Error Restarting AUT from Test Runner [message #1706936 is a reply to message #1706553] Tue, 01 September 2015 01:18 Go to previous messageGo to next message
Hi Lucas,
There should be
SET VM=%APP%\jre\bin\java instead of %APP%\jre.
Could you please fix and try again?
Why don't you use maven to start your tests headless? RCPTT has it's own maven plugin, please see the details here: https://www.eclipse.org/rcptt/documentation/userguide/maven/
Kind regards,
Ulyana.
Re: Error Restarting AUT from Test Runner [message #1707037 is a reply to message #1706936] Tue, 01 September 2015 12:38 Go to previous messageGo to next message
It didn't help. I think the root cause is from the switch workspaces in the test. I've done more searching on that and it seems like it can be an issue when executing eclipse in certain ways. I'll try to find ways around this in our tests because it looks like it will be a pain.
Re: Error Restarting AUT from Test Runner [message #1811313 is a reply to message #1706440] Fri, 30 August 2019 09:40 Go to previous message
Strange thing...
I have an AUT buildt on Eclipse 4.4 / 4.6 which is working fine in RCPTT IDE 2.4.2, but is not starting in RCPTT Test Runner. Any reason why?
!SESSION 2019-08-30 14:10:49.152 -----------------------------------------------
eclipse.buildId=unknown
java.fullversion=8.0.5.25 - pwa6480sr5fp25-20181030_01(SR5 FP25)
JRE 1.8.0 Windows 7 amd64-64-Bit Compressed References 20181029_400846 (JIT enabled, AOT enabled)
OpenJ9 - c5c78da
OMR - 3d5ac33
IBM - 8c1bdc2
Framework arguments: -product com.ibm.team.concert.product -eclipse.keyring X:\\runner-workspace\.metadata\.plugins\org.eclipse.pde.core\AUT_0/secure_storage
Command-line arguments: -product com.ibm.team.concert.product -data X://aut-workspace0 -dev file:X://runner-workspace/.metadata/.plugins/org.eclipse.pde.core/AUT_0/dev.properties -os win32 -arch x86_64 -consoleLog -eclipse.keyring X:\\runner-workspace\.metadata\.plugins\org.eclipse.pde.core\AUT_0/secure_storage
!ENTRY org.eclipse.rcptt.tesla.gmf 4 0 2019-08-30 14:10:54.876
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.gmf [2183]
at org.eclipse.osgi.container.Module.start(Module.java:444)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.rcptt.tesla.gmf.aspects 4 0 2019-08-30 14:10:54.878
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.gmf.aspects [2184]
!ENTRY org.eclipse.rcptt.tesla.nebula.ecl.impl 4 0 2019-08-30 14:10:54.881
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.nebula.ecl.impl [2198]
Unresolved requirement: Require-Bundle: org.eclipse.rcptt.tesla.nebula.impl; bundle-version="[2.4.2,3.0.0)"
-> Bundle-SymbolicName: org.eclipse.rcptt.tesla.nebula.impl; bundle-version="2.4.2.201903220647"; singleton:="true"
org.eclipse.rcptt.tesla.nebula.impl [2199]
!ENTRY org.eclipse.rcptt.tesla.nebula.impl 4 0 2019-08-30 14:10:54.888
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.nebula.impl [2199]
!ENTRY org.eclipse.rcptt.tesla.recording.aspects.gmf 4 0 2019-08-30 14:10:54.894
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.recording.aspects.gmf [2204]
!ENTRY org.eclipse.rcptt.tesla.recording.gmf 4 0 2019-08-30 14:10:54.898
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.recording.gmf [2215]
Unresolved requirement: Require-Bundle: org.eclipse.rcptt.tesla.recording.aspects.gmf; bundle-version="[2.4.2,3.0.0)"
-> Bundle-SymbolicName: org.eclipse.rcptt.tesla.recording.aspects.gmf; bundle-version="2.4.2.201903220647"; singleton:="true"
!ENTRY org.eclipse.rcptt.tesla.recording.nebula 4 0 2019-08-30 14:10:54.903
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.rcptt.tesla.recording.nebula [2217]
!ENTRY org.eclipse.osgi 4 0 2019-08-30 14:10:58.109
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.jobs (1405).
!STACK 0
org.osgi.framework.BundleException: Error starting module.
at org.eclipse.osgi.container.Module.doStart(Module.java:590)
at org.eclipse.osgi.container.Module.start(Module.java:449)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:470)
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:107)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:529)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.findLocalClass(ModuleClassLoader.java:325)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:345)
at org.eclipse.osgi.internal.loader.sources.SingleSourcePackage.loadClass(SingleSourcePackage.java:36)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:419)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:853)
at org.eclipse.core.internal.runtime.InternalPlatform.start(InternalPlatform.java:719)
at org.eclipse.core.internal.runtime.PlatformActivator.start(PlatformActivator.java:32)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:774)
at org.eclipse.osgi.internal.framework.BundleContextImpl$3.run(BundleContextImpl.java:1)
at java.security.AccessController.doPrivileged(AccessController.java:703)
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:767)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:724)
at org.eclipse.osgi.internal.framework.EquinoxBundle.startWorker0(EquinoxBundle.java:932)
at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.startWorker(EquinoxBundle.java:309)
at org.eclipse.osgi.container.Module.doStart(Module.java:581)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
at org.eclipse.osgi.internal.framework.BundleContextImpl.loadBundleActivator(BundleContextImpl.java:757)
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:711)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
at org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance(ServiceComponent.java:493)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.createInstance(ServiceComponentProp.java:270)
at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(ServiceComponentProp.java:331)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(InstanceProcess.java:620)
at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponents(InstanceProcess.java:197)
at org.eclipse.equinox.internal.ds.Resolver.buildNewlySatisfied(Resolver.java:473)
at org.eclipse.equinox.internal.ds.Resolver.enableComponents(Resolver.java:217)
at org.eclipse.equinox.internal.ds.SCRManager.performWork(SCRManager.java:816)
at org.eclipse.equinox.internal.ds.SCRManager$QueuedJob.dispatch(SCRManager.java:783)
at org.eclipse.equinox.internal.ds.WorkThread.run(WorkThread.java:89)
at java.lang.Thread.run(Thread.java:812)
Caused by: org.aspectj.apache.bcel.classfile.ClassFormatException: org.eclipse.core.internal.jobs.JobActivator is not a Java .class file
at org.aspectj.apache.bcel.classfile.ClassParser.readID(ClassParser.java:215)
at org.aspectj.apache.bcel.classfile.ClassParser.parse(ClassParser.java:124)
at org.aspectj.weaver.bcel.Utility.makeJavaClass(Utility.java:467)
at org.aspectj.weaver.bcel.BcelWorld.addSourceObjectType(BcelWorld.java:515)
at org.aspectj.weaver.tools.WeavingAdaptor.ensureDelegateInitialized(WeavingAdaptor.java:513)
at org.aspectj.weaver.tools.WeavingAdaptor$WeavingClassFileProvider.<init>(WeavingAdaptor.java:843)
at org.aspectj.weaver.tools.WeavingAdaptor.getWovenBytes(WeavingAdaptor.java:526)
at org.aspectj.weaver.tools.WeavingAdaptor.weaveClass(WeavingAdaptor.java:363)
at org.eclipse.equinox.weaving.aspectj.loadtime.OSGiWeavingAdaptor.weaveClass(Unknown Source)
at org.eclipse.equinox.weaving.aspectj.AspectJWeavingService.preProcess(Unknown Source)
at org.eclipse.equinox.weaving.adaptors.WeavingAdaptor.weaveClass(Unknown Source)
at org.eclipse.equinox.weaving.hooks.WeavingHook.processClass(Unknown Source)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.defineClass(ClasspathManager.java:616)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findClassImpl(ClasspathManager.java:586)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClassImpl(ClasspathManager.java:538)
at org.eclipse.osgi.internal.loader.classpath.ClasspathManager.findLocalClass(ClasspathManager.java:525)
... 59 more
Root exception:
!ENTRY org.eclipse.osgi 4 0 2019-08-30 14:10:58.114
!MESSAGE An error occurred while automatically activating bundle org.eclipse.core.runtime (1422).
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.runtime.PlatformActivator.start() of bundle org.eclipse.core.runtime.
at org.eclipse.osgi.internal.framework.BundleContextImpl.startActivator(BundleContextImpl.java:795)
Caused by: java.lang.NoClassDefFoundError: org.eclipse.core.runtime.jobs.Job
... 41 more
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.jobs (1405).
at org.eclipse.osgi.internal.hooks.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:116)
... 47 more
Caused by: org.osgi.framework.BundleException: Error starting module.
... 56 more
... 59 more
Root exception:
... 47 more
... 56 more
... 59 more
!ENTRY org.eclipse.osgi 4 0 2019-08-30 14:10:58.117
!MESSAGE An error occurred while automatically activating bundle org.eclipse.ui.trace (2355).
!STACK 0
org.osgi.framework.BundleException: Error loading bundle activator.
at org.eclipse.osgi.internal.framework.BundleContextImpl.start(BundleContextImpl.java:716)
Caused by: java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.core.runtime (1422).
... 26 more
Caused by: org.osgi.framework.BundleException: Exception in org.eclipse.core.internal.runtime.PlatformActivator.start() of bundle org.eclipse.core.runtime.
... 34 more
... 41 more
... 47 more
... 56 more
... 59 more
Root exception:
... 34 more
... 41 more
... 47 more
... 56 more
... 59 more
!ENTRY org.eclipse.equinox.ds 4 0 2019-08-30 14:10:58.121
!MESSAGE Exception occurred while creating new instance of component Component[
name = org.eclipse.ui.trace.TracingInitializer
activate = activate
deactivate = deactivate
modified =
configuration-policy = optional
factory = null
autoenable = true
immediate = true
implementation = org.eclipse.ui.trace.internal.utils.TracingInitializer
state = Disposed
properties =
serviceFactory = false
serviceInterface = null
references = {
Reference[name = DebugOptionsListener, interface = org.eclipse.osgi.service.debug.DebugOptionsListener, policy = static, cardinality = 1..n, target = null, bind = null, unbind = null]
located in bundle = org.eclipse.ui.trace_1.0.400.v20160509-1055 [2355]
!STACK 0
java.lang.ClassNotFoundException: An error occurred while automatically activating bundle org.eclipse.ui.trace (2355).
at org.ec
Previous Topic:Error when trying to create a new AUT in the application window of the RCPTT plugin
Next Topic: AUT does not have focus during test execution
Current Time: Sun Jul 20 20:28:23 EDT 2025
Powered by FUDForum. Page generated in 0.04344 seconds
