Home » Eclipse Projects » Sirius » Custom Style Bordernodes not allowing connections
Custom Style Bordernodes not allowing connections [message #1705992] Thu, 20 August 2015 14:41 Go to next message
I am working with Bordernodes with a custom style so I can define their shape.
I have a connection tool that connects the bordernodes.
If I specify the nodes as one of the default styles(Lozenge) the connection works fine. However, if I use my custom style the connection doesn't work at all.
The Mouse decorations say you can't connect and no connections can be made.
I am not sure if I am missing some interface or extension point.
Any help would be appreciated.
Bailey
Re: Custom Style Bordernodes not allowing connections [message #1706067 is a reply to message #1705992] Fri, 21 August 2015 11:41 Go to previous messageGo to next message
On 08/20/2015 08:41 PM, Bailey Trenton wrote:
> Hello,
> their shape.
> I have a connection tool that connects the bordernodes. If I specify the
The node style should not have any impact on the connection ability. Is
the custom style applied from an import mapping ?
> Bailey
Florian - Obeo
Re: Custom Style Bordernodes not allowing connections [message #1706068 is a reply to message #1706067] Fri, 21 August 2015 12:09 Go to previous messageGo to next message
I currently have an imported Node defined in another diagram. I defined Bordered Nodes inside a diagram extension representing my ports inside that imported node. I define a custom style that uses an EditPart Provider that supplies my new edit part shapes. As soon as I select the custom style for the border nodes, the connection features don't work.
Re: Custom Style Bordernodes not allowing connections [message #1706234 is a reply to message #1706068] Tue, 25 August 2015 03:53 Go to previous messageGo to next message
Which release of Sirius do you use and can you provide a minimal example
of your not working case?
Best Regards.
> Thanks
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: Custom Style Bordernodes not allowing connections [message #1706317 is a reply to message #1706234] Tue, 25 August 2015 11:40 Go to previous messageGo to next message
We are using Sirius 2.0.5. Upgrading to 3 in the near future.
Here is what we are trying to do with custom shaped border nodes.
We need custom shapes for our border nodes. These represent different types of ports for us. We define custom Editparts and EditpartProviders that provides these custom shapes. We register the provider with editPartProvider extension point.
It draws the new shapes just fine on our Sirius diagram. We have a connection tool that connects two of these custom shaped Bordernodes together. However the connection tool does not work when we use these custom Editparts as our bordernode. If we change the shapes to one of the Sirius provided shapes(Ellipse, Square, Lozenge) the connections work fine, without changing any of the connection logic.
The feedback icons that decorates the cursor says that the connection is not allowed even from the start if we hover it over the custom border node.
I followed the directions from the "Sirus how to provide a custom style" document to create my editpart and provider. Do I have to do something else to get my editPart to work with connections?
Re: Custom Style Bordernodes not allowing connections [message #1706365 is a reply to message #1706317] Wed, 26 August 2015 05:51 Go to previous messageGo to next message
You can take a look at UML Designer sample [1] which use custom style.
Perhaps you have discovered a bug about connection tool on custom border
nodes, in this case you can raise a bugzilla with a reproduction case.
[1] https://github.com/ObeoNetwork/UML-Designer
Best Regards.
> node.
> Thanks
Re: Custom Style Bordernodes not allowing connections [message #1707011 is a reply to message #1706365] Tue, 01 September 2015 09:39 Go to previous messageGo to next message
Hi Bailey,
I put an answer on the bugzilla you have created
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=476114)
You have to overrides your syle edit part createDefaultEditPolicies() to
do nothing as the behavior is not controlled by the style edit part but
by its parent node edit part.
Maxime
Le 26/08/2015 11:51, Esteban Dugueperoux a écrit :
> Best Regards.
>> node.
>> Thanks
Maxime - Obeo
Re: Custom Style Bordernodes not allowing connections [message #1707013 is a reply to message #1707011] Tue, 01 September 2015 09:45 Go to previous message
Hi Bailey,
Note that in the emtpy createDefaultPolicies() methods is shown in the
sample style edit part of the custom style documentation [1] but we
should add some comments about this before the sample class.
Le 01/09/2015 15:39, Maxime Porhel a écrit :
> Hi Bailey,
> Regards,
> Maxime
>> Hi,
>> Best Regards.
>>> node.
>>> Thanks
Maxime - Obeo
[1]
https://www.eclipse.org/sirius/doc/developer/extensions-provide_custom_style.html
Previous Topic:Table representation
Next Topic:Problem of Edge in Container
Current Time: Sun Jul 20 20:19:33 EDT 2025
Powered by FUDForum. Page generated in 0.05415 seconds
