Home » Eclipse Projects » e(fx)clipse » DIApplication doesn't start on Mac
DIApplication doesn't start on Mac [message #1706207] Mon, 24 August 2015 17:28 Go to next message
I was setting up a development environment on a Mac this weekend (for the first time) and imported a DIApplication project I had already created on Windows. The project was created using the JavaFX/OSGI/OSGi Application Project wizard with the option of using Eclipse DI.
On windows the application starts up fine showing the initial stage. On Mac I can see Equinox starting up logging debug info. If I enable the console I can use it, i.e. "ss" lists the bundles. The Stage is never shown. It seems to me as if @PostConstruct on MainApplication is never called.
The plugin.xml looks like it should:
<plugin>
<extension id="application" point="org.eclipse.core.runtime.applications">
	<application thread="any" cardinality="*" visible="true" >
		<run class="org.eclipse.fx.ui.di.DIApplication" >
			<parameter name="mainClass" value="de.kware.app.loginDisplay.MainApplication" />
		</run>
	</application>
</extension>
<extension id="product" point="org.eclipse.core.runtime.products">
	<product application="de.kware.app.loginDisplay.application" name="LoginDisplay" >
		<property name="appName" value="LoginDisplay" />
	</product>
</extension>
</plugin>
And the product is configured to start this application. The launching vom arguments are on the Mac (on Windows only the first argument is used).
-Dorg.osgi.framework.bundle.parent=ext
-XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts
Could this be an issue with javax.annotation? I do not import javax.annotation in the MANIFEST.MF. The product has javax.annotation.jre as a dependency.
Or is this a configuration issue?
Thanks for your help!
Christoph
Re: DIApplication doesn't start on Mac [message #1706208 is a reply to message #1706207] Mon, 24 August 2015 17:55 Go to previous messageGo to next message
On 24.08.15 23:28, Christoph Keimel wrote:
> Hi
> called.
> <plugin>
> </run>
> </application>
> </extension>
> </product>
> </extension>
> </plugin>
> -XstartOnFirstThread -Dorg.eclipse.swt.internal.carbon.smallFonts
You need to remove "-XstartOnFirstThread
-Dorg.eclipse.swt.internal.carbon.smallFonts" - they'll block the event
queue.
Tom
Re: DIApplication doesn't start on Mac [message #1706239 is a reply to message #1706208] Tue, 25 August 2015 04:31 Go to previous messageGo to next message
Thanks!
Re: DIApplication doesn't start on Mac [message #1706241 is a reply to message #1706239] Tue, 25 August 2015 04:43 Go to previous messageGo to next message
I thought we generate a .launch which is already holding the correct
values? If we don't we definately should fix this in 2.2.0
Tom
On 25.08.15 10:31, Christoph Keimel wrote:
> Thanks!
Re: DIApplication doesn't start on Mac [message #1706243 is a reply to message #1706241] Tue, 25 August 2015 05:02 Go to previous message
I just checked it and the product is created without these arguments.
The project I was using was created some time ago.
[Updated on: Tue, 25 August 2015 05:03] by Moderator
Previous Topic:EMF Databinding adapter leak with javafx
Next Topic:Is there a WindowBuilder in the works for e(fx)clipse?
Current Time: Sun Jul 20 20:20:10 EDT 2025
Powered by FUDForum. Page generated in 0.29889 seconds
