Home » Eclipse Projects » Sirius » Using a Java Service in a TreeItemStyleDescription
Using a Java Service in a TreeItemStyleDescription [message #1549644] Tue, 06 January 2015 12:01 Go to next message
It's me again Smile
Still using Sirius 1.0.1, I would like to display the elements of my tree-based editor using an unified format: eClass name <space> object id (the same format as in EMF's generated editor).
So I defined a Java Service, which is a public class with an empty public zero-argument constructor. Inside this Java Service I implemented the following method:
public String getDisplayName(EObject eObject) {
    EAttribute eAttribute = eObject.eClass().getEIDAttribute();
    if (eAttribute == null) {
        return eObject.eClass().getName();
    } else {
        return eObject.eClass().getName() + ' ' + eObject.eGet(eAttribute);
I then added a <JavaExtension> as a child of my <Viewpoint> element, using the FQN of my Java Service.
But when I use expression [self.getDisplayName() /] or [getDisplayName() /] as a <TreeItemStyleDescription> label, I get the following error in the console:
org.eclipse.acceleo.engine.AcceleoEvaluationException: Argument types mismatch for module element dynamicModuleQuery80.
	at org.eclipse.acceleo.engine.generation.AcceleoEngine.doEvaluate(AcceleoEngine.java:401)
	at org.eclipse.acceleo.engine.generation.AcceleoEngine.evaluate(AcceleoEngine.java:203)
	at org.eclipse.acceleo.engine.service.AcceleoEvaluationTask.evaluateQuery(AcceleoEvaluationTask.java:122)
	at org.eclipse.acceleo.engine.service.AcceleoEvaluationTask.call(AcceleoEvaluationTask.java:291)
	at org.eclipse.sirius.common.acceleo.mtl.business.internal.interpreter.DynamicAcceleoModule.evaluate(DynamicAcceleoModule.java:531)
The name of the Java Service method seems to be correctly resolved, because when I change the label expression with a non-existing method name, I get the following error in the console:
!MESSAGE Compilation error for expression [getDisplayNamez() /] : Cannot find operation (getDisplayNamez()) for the type (ConfigurationDataFile)
(ConfigurationDataFile is the EMF class corresponding to the root object displayed in my tree)
What did I do wrong ?
Re: Using a Java Service in a TreeItemStyleDescription [message #1550783 is a reply to message #1549644] Wed, 07 January 2015 03:07 Go to previous messageGo to next message
Hi Frédéric,
To use Acceleo 3 expression in your odesign, you must reference the
metamodels on which your representations works. You can add these
references on Viewpoint through the properties view in the Metamodels
tab. These references must be of the form
"platform:/plugin/ProjectName/..." then you must have your metamodels
plugins deployed before. Finally when testing your odesign, it must also
be deployed to avoid kind of errors like you have. Then when using
Acceleo 3 you must works with 3 instances :
- one for your metamodels plugins
- one for your odesign plugin
- and a last one for your model on which you test your odesign.
Is it the case?
Best Regards.
> the console:
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Re: Using a Java Service in a TreeItemStyleDescription [message #1551417 is a reply to message #1550783] Wed, 07 January 2015 11:10 Go to previous messageGo to next message
Hi and thank you for your support,
I am not able to make the 3-instance solution work. To sum up, I have :
    One main Eclipse instance with the 3 plugins generated by EMF:
      com.mycompany.siriustest.model
      com.mycompany.siriustest.model.edit
      com.mycompany.siriustest.model.editor
    One second Eclipse instance (launched by the first one) with the following plugin:
      com.mycompany.siriustest.design containing my .odesign file and the Java Service
    One third Eclipse instance (launched by the second one) with the following plugin:
      com.mycompany.siriustest.sample
I referenced the meta-model in my Viewpoint, as you told me. But:
- when I edit the .odesign file, the methods of the Java Service never appear when I try to use completion in an expression (using the service:method syntax or the [ method() /] syntax)
- when I test my .odesign with an EMF model, no label appears. With the second syntax, I get the following error message in the console:
Cannot find operation (method()) for the type (ConfigurationDataFile)
With the first syntax, no error message is displayed.
BUT
If I keep my 2-instance initial setup with:
    The main Eclipse instance
      com.mycompany.siriustest.design.service
      : contains a Java Service
    A second Eclipse instance launched from the first one
      com.mycompany.siriustest.design: contains an empty Java Service extending the one in com.mycompany.siriustest.design.service
THEN I can use Java Service in labels, with syntax service: (the second one does not work). And the completion works fine too. I just have to restart the second instance once I modify the implementation of my Java Service, which seems normal.
The only remaining problem with this setup is the following: Java Services do not seem to work in pre-conditions, for example in a <TreeItemCreationTool>. My method (whose return type is a boolean), is never invoked and the corresponding creation tool appears in the context menu whatever the case. Nevertheless the method, with the right signature, appears as a suggestion completion in the "precondition" field of the Sirius editor.
Is there a limitation with preconditions, or did I do something wrong with my precondition method ?
Its signature is:
public boolean canCreateSiblingInContainer(EObject self, EClass container);
and the syntax of my precondition is:
service:canCreateSiblingInContainer(container)
Re: Using a Java Service in a TreeItemStyleDescription [message #1552996 is a reply to message #1551417] Thu, 08 January 2015 07:43 Go to previous messageGo to next message
Hi Frédéric,
I think that your second solution with only 2 Eclipse instances work
because you have your java service in the first one while it was not the
case with the first proposed solution.
After about your issue on precondition evaluation with java service
call, I'm not aware of this kind of issue and this should works. Could
you raise a bugzilla about this issue with a test case and a scenario?
Best Regards.
> following plugin:
> Service
> following plugin:
> BUT
> com.mycompany.siriustest.design.service: contains a Java Service
> Its signature is:
Re: Using a Java Service in a TreeItemStyleDescription [message #1553346 is a reply to message #1552996] Thu, 08 January 2015 11:53 Go to previous messageGo to next message
Sorry, I made a mistake in my precondition by using a literal, which is not supported as explained in your documentation. There is no bug there.
Nevertheless, I don't understand why the service:operation / service:operation() syntax works, but not the [self.operation() /] one. My modeling .sample project is opened in an Eclipse instance where my Java Service has been deployed (in the .design project).
Re: Using a Java Service in a TreeItemStyleDescription [message #1565343 is a reply to message #1553346] Thu, 15 January 2015 03:11 Go to previous messageGo to next message
Hi Frédéric,
[self.operation() /] should work as service:operation /
service:operation() , do you have added
"org.eclipse.sirius.common.acceleo.mtl" plugin as dependency of you
plugin where you have you odesign and java service?
Best Regards.
Re: Using a Java Service in a TreeItemStyleDescription [message #1706160 is a reply to message #1565343] Mon, 24 August 2015 05:46 Go to previous messageGo to next message
Hi!
I can't understand the purpose of the second Eclipse instance.
It seems that everithing except Acceleo interpreter works in the one Eclipse instance.
The only thing that doesn't work is Acceleo interpreter:
https://www.eclipse.org/forums/index.php/t/1066702/
https://www.eclipse.org/forums/index.php/t/781784/
But I don't understand why it needs a second intstance.
I've deployed the sample metamodel as Eclipse plugin:
  • org.eclipse.sirius.sample.basicfamily_1.0.0.201508241127.jar
  • org.eclipse.sirius.sample.basicfamily.edit_1.0.0.201508241127.jar
  • org.eclipse.sirius.sample.basicfamily.editor_1.0.0.201508241127.jar
After that I run the first Eclipse instance with two projects
  • org.eclipse.sirius.sample.basicfamily.design
  • basicfamily.sample
Acceleo interpreter doesn't work.
But! When I run first Eclipse instance with empty workspace, and after that I run second Eclipse instance from the first one with the same projects, Acceleo interpreter works!!! What is the purpose of that intermediate Eclipse instance with empty workspace?
Re: Using a Java Service in a TreeItemStyleDescription [message #1706190 is a reply to message #1706160] Mon, 24 August 2015 10:55 Go to previous messageGo to next message
Hi Denis,
Can you try using the latest release of Sirius, i.e. 3.0 [1] and using
service interpreter instead of Acceleo 3 ?
[1] https://wiki.eclipse.org/Sirius
Best Regards.
Le 24/08/2015 11:46, Denis Nikiforov a écrit :
> Hi!
> Eclipse instance.
> basicfamily.sample
Re: Using a Java Service in a TreeItemStyleDescription [message #1706216 is a reply to message #1706190] Tue, 25 August 2015 01:57 Go to previous messageGo to next message
It works in both scenarios: with single Eclipse instance and with two instances!
1) I started single Eclipse instance.
2) After that I've added two projects into workspace "org.eclipse.sirius.sample.basicfamily.design" and "basicfamily.sample".
3) I've added Java Extension into basicfamily.odesign with class "org.eclipse.sirius.sample.basicfamily.services.FamilyServices".
4) And set label of the ManNode to "service:getMembersWithoutMother".
And it works! It shows list of persons.
Re: Using a Java Service in a TreeItemStyleDescription [message #1706255 is a reply to message #1706216] Tue, 25 August 2015 07:34 Go to previous messageGo to next message
Is it possible to let Acceleo interpreter work in a single Eclipse instance? I think it will simplify a development process.
UPDATE: Sorry for flood. Acceleo interpreter works now in a single Eclipse instance too. I don't understand what was changed in my Eclipse settings or projects, but it works.
[Updated on: Tue, 25 August 2015 09:12] by Moderator
Re: Using a Java Service in a TreeItemStyleDescription [message #1706282 is a reply to message #1706255] Tue, 25 August 2015 09:10 Go to previous messageGo to next message
Re: Using a Java Service in a TreeItemStyleDescription [message #1706283 is a reply to message #1706255] Tue, 25 August 2015 09:11 Go to previous messageGo to next message
Re: Using a Java Service in a TreeItemStyleDescription [message #1706284 is a reply to message #1706255] Tue, 25 August 2015 09:12 Go to previous messageGo to next message
Re: Using a Java Service in a TreeItemStyleDescription [message #1706289 is a reply to message #1706255] Tue, 25 August 2015 09:21 Go to previous messageGo to next message
From Sirius 3.0, there is the new AQL interpreter [1] and the existing
service interpreter [2] has been improved. With this 3.0 release, with
your metamodel plugins deployed you can have java service in workspace
called from the VSM in this same workspace. Then only 2 Eclipse
instances are needed, a first one for your metamodel plugins and a
second one for your viewpoint specification project and your modeling
projet to test your modeler.
[1] http://cedric.brun.io/eclipse/introducing-aql/
[2]
https://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html#specialized
Best Regards.
Re: Using a Java Service in a TreeItemStyleDescription [message #1706364 is a reply to message #1706289] Wed, 26 August 2015 05:40 Go to previous message
Thanks! That's really cool! I think in most cases ocl will be enough for me.
PS: Oops, I didn't want to send so many messages
Previous Topic:What should I use for UI and user actions?
Next Topic:Compilation error for expression XYZ, headless mode
Current Time: Mon Jul 21 11:31:07 EDT 2025
Powered by FUDForum. Page generated in 0.12887 seconds
