Home » Modeling » TMF (Xtext) » [2.7.0] Guice errors when unit-testing the generator
[2.7.0] Guice errors when unit-testing the generator [message #1418850] Sun, 07 September 2014 15:06 Go to next message
Hi there,
I've just upgraded to 2.7.0 and now get a blocking error when I try and unit-test the generator. The unit tests for the parser and the validator pass with flying colours.
From the generator test:
@Test
def void testMinimalModel(){
    val source = readFile("../myDSL.dsl/models/minimalModel.dsl",Charset.defaultCharset())
    source.assertCompilesTo(readFile("../myDSL.dsl/models/minimalModel.xml",Charset.defaultCharset()))
Error:
com.google.inject.ConfigurationException: Guice configuration errors:
1) No implementation for org.eclipse.xtend.lib.macro.file.MutableFileSystemSupport was bound.
  while locating org.eclipse.xtend.lib.macro.file.MutableFileSystemSupport
    for field at org.eclipse.xtext.generator.FileSystemSupportBasedFileSystemAccess.fileSystemSupport(Unknown Source)
  while locating com.google.inject.Provider<org.eclipse.xtext.xbase.compiler.RegisteringFileSystemAccess>
    for field at org.eclipse.xtext.xbase.compiler.CompilationTestHelper$Result.fileSystemAccessProvider(Unknown Source)
  while locating com.google.inject.Provider<org.eclipse.xtext.xbase.compiler.CompilationTestHelper$Result>
    for field at org.eclipse.xtext.xbase.compiler.CompilationTestHelper.resultProvider(Unknown Source)
  while locating org.eclipse.xtext.xbase.compiler.CompilationTestHelper
    for field at roadblock.xtext.ibl.tests.IblGeneratorTests._compilationTestHelper(Unknown Source)
  while locating roadblock.xtext.ibl.tests.IblGeneratorTests
1 error
	at com.google.inject.internal.InjectorImpl.getMembersInjector(InjectorImpl.java:952)
	at com.google.inject.internal.InjectorImpl.getMembersInjector(InjectorImpl.java:957)
	at com.google.inject.internal.InjectorImpl.injectMembers(InjectorImpl.java:943)
	at org.eclipse.xtext.junit4.XtextRunner.createTest(XtextRunner.java:33)
	at org.junit.runners.BlockJUnit4ClassRunner$1.runReflectiveCall(BlockJUnit4ClassRunner.java:244)
	at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
	at org.junit.runners.BlockJUnit4ClassRunner.methodBlock(BlockJUnit4ClassRunner.java:241)
	at org.eclipse.xtext.junit4.XtextRunner.superMethodBlock(XtextRunner.java:64)
	at org.eclipse.xtext.junit4.XtextRunner.methodBlock(XtextRunner.java:44)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:70)
	at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:50)
	at org.junit.runners.ParentRunner$3.run(ParentRunner.java:238)
	at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:63)
	at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:236)
	at org.junit.runners.ParentRunner.access$000(ParentRunner.java:53)
	at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:229)
	at org.junit.runners.ParentRunner.run(ParentRunner.java:309)
	at org.eclipse.jdt.junit4.runtime.patch.JUnit4TestReference.run(JUnit4TestReference.java:42)
	at org.eclipse.jdt.internal.junit.runner.TestExecution.run(TestExecution.java:38)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:467)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
	at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
I can run the the project as an Eclipse application without this error. I'm on Juno Version: Juno Service Release 2, Build id: 20130225-0426. I've got nothing left to update.
Any ideas what could be happening here? And how to fix it?
Thank you!
Re: [2.7.0] Guice errors when unit-testing the generator [message #1419129 is a reply to message #1418850] Mon, 08 September 2014 02:14 Go to previous messageGo to next message
Did you regenerate the language? how do you use xbase? The xbase generator Fragment in your workflow should have generated in your abstractruntimemodule
Re: [2.7.0] Guice errors when unit-testing the generator [message #1419198 is a reply to message #1419129] Mon, 08 September 2014 04:36 Go to previous messageGo to next message
thank you for looking into this!
I did regenerate the language (Generate Xtext Artefacts) and still get the error, even with my generator consisting in a single println command.
I don't think I'm using xbase, or at least not knowingly.
Re: [2.7.0] Guice errors when unit-testing the generator [message #1419206 is a reply to message #1419198] Mon, 08 September 2014 04:52 Go to previous messageGo to next message
CompilationTestHelper is from xbase so it asumes you use an xbase language
Re: [2.7.0] Guice errors when unit-testing the generator [message #1419255 is a reply to message #1419206] Mon, 08 September 2014 06:29 Go to previous messageGo to next message
I see that xbase is used during the language generation:
243  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel '######www.eclipse.org/Xtext/Xbase/XAnnotations' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
247  [main] INFO  clipse.emf.mwe.utils.GenModelHelper  - Registered GenModel '######www.eclipse.org/xtext/xbase/Xtype' from 'platform:/resource/org.eclipse.xtext.xbase/model/Xbase.genmodel'
(###### is for http etc. I can't post urls yet)
The code for the generator unit-test is:
package roadblock.xtext.ibl.tests
import com.google.inject.Inject
import org.eclipse.xtext.junit4.InjectWith
import org.eclipse.xtext.junit4.XtextRunner
import org.eclipse.xtext.xbase.compiler.CompilationTestHelper
import roadblock.xtext.ibl.IblInjectorProvider
import org.junit.Test
import org.junit.runner.RunWith
import java.io.IOException
import java.nio.charset.Charset
import java.nio.file.Files
import java.nio.file.Paths
import java.nio.ByteBuffer
@RunWith(typeof(XtextRunner))
@InjectWith(typeof(IblInjectorProvider))
class IblGeneratorTests {
	@Inject extension CompilationTestHelper
		// read file into a string
	// from ######stackoverflow.com/questions/326390/how-to-create-a-java-string-from-the-contents-of-a-file
	def static String readFile(String path, Charset encoding)  throws IOException
		var byte[] encoded = Files.readAllBytes(Paths.get(path))
	 	return encoding.decode(ByteBuffer.wrap(encoded)).toString
	@Test
		val source = readFile("../roadblock.xtext.ibl/models/minimalModel.ibl",Charset.defaultCharset())
		source.assertCompilesTo(readFile("../roadblock.xtext.ibl/models/minimalModel.xml",Charset.defaultCharset()))
It was working fine before the upgrade to 2.7.0. I tried on Kepler as well, to the same effect.
Edit:
I just tried this:
@Test
	def testiftrue(){
		assertTrue(true)
And got the same error. So it's not due to assertCompilesTo.
[Updated on: Mon, 08 September 2014 06:34] by Moderator
Re: [2.7.0] Guice errors when unit-testing the generator [message #1419332 is a reply to message #1419255] Mon, 08 September 2014 08:50 Go to previous messageGo to next message
did you have a look at the generated code in the abstractyourdslruntimemodule.
i did not have a look at the fragment if it only generates the stuff depending on if xbase is really used.
in my xbase project i can find
	// contributed by org.eclipse.xtext.generator.xbase.XbaseGeneratorFragment
	public Class<? extends org.eclipse.xtend.lib.macro.file.MutableFileSystemSupport> bindMutableFileSystemSupport() {
		return org.eclipse.xtext.xbase.file.JavaIOFileSystemSupport.class;
Re: [2.7.0] Guice errors when unit-testing the generator [message #1419417 is a reply to message #1419332] Mon, 08 September 2014 11:34 Go to previous messageGo to next message
Ah that's interesting: there is no trace of xbase in abstractyourdslruntimemodule. Should it be there?
Re: [2.7.0] Guice errors when unit-testing the generator [message #1419454 is a reply to message #1419417] Mon, 08 September 2014 12:36 Go to previous messageGo to next message
it depends if you use xbase in your grammar. if not why do you use xbase test classes? just cause existing compilationtesthelper was convenient?
Re: [2.7.0] Guice errors when unit-testing the generator [message #1419847 is a reply to message #1419454] Tue, 09 September 2014 03:03 Go to previous messageGo to next message
I had exactly the same issue, testing a language with
CompilationTestHelper, without using Xbase... as for me, I find
CompilationTestHelper quite convenient to test that the generated code
is as expected :)
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: [2.7.0] Guice errors when unit-testing the generator [message #1420216 is a reply to message #1419847] Tue, 09 September 2014 13:31 Go to previous messageGo to next message
ah! I used CompilationTestHelper precisely because I'm following your (very helpful) book!
Did you find a workaround for this issue? What is an alternative for testing the generator?
Re: [2.7.0] Guice errors when unit-testing the generator [message #1420233 is a reply to message #1420216] Tue, 09 September 2014 14:09 Go to previous messageGo to next message
simply add the binding ?!? or copy and paste and stip down the compilationtesthelper
Re: [2.7.0] Guice errors when unit-testing the generator [message #1421449 is a reply to message #1420216] Thu, 11 September 2014 07:34 Go to previous messageGo to next message
As Christian suggested, you should add the explicit binding... I'd be
tempted to add it as a custom InjectorProvider only in the tests project
(see the domain model example tests to see how to create and use a
custom injector provider with specific bindings).
I'll try to update the example of the book and also submit an errata :)
cheers
Lorenzo
Xtext Book:
Re: [2.7.0] Guice errors when unit-testing the generator [message #1425557 is a reply to message #1420216] Wed, 17 September 2014 09:28 Go to previous messageGo to next message
I've updated the sources of examples of the book:
https://github.com/LorenzoBettini/packtpub-xtext-book-examples
on the main page you also find all the ERRATA (in the README.md), in
particular, two ways of specifying the bindings to avoid this error in
languages that use CompilationTestHelper but are not based on Xbase :)
Hope this helps
Lorenzo
Xtext Book:
Re: [2.7.0] Guice errors when unit-testing the generator [message #1425561 is a reply to message #1425557] Wed, 17 September 2014 09:34 Go to previous messageGo to next message
That looks great, I look forward to trying this out!
Thank you!
Re: [2.7.0] Guice errors when unit-testing the generator [message #1706057 is a reply to message #1425557] Fri, 21 August 2015 08:56 Go to previous messageGo to next message
Hi Lorenzo,
I implemented the solution given by you for using CompilationTestHelper for my DSL (inheriting from Xtype).
However, I am getting NullPointerException in CompilationTestHelper.doIndex().
I found this entry on your site; but I am unable to figure out on how to fix this NullPointerException.
Could you please help me here?
[EDIT]:
I am using Xtext 2.8.3
[Updated on: Fri, 21 August 2015 09:26] by Moderator
Re: [2.7.0] Guice errors when unit-testing the generator [message #1706095 is a reply to message #1706057] Sat, 22 August 2015 08:32 Go to previous messageGo to next message
On 21/08/2015 14:56, Manisha Ghule wrote:
> Hi Lorenzo,
> I found https://github.com/LorenzoBettini/xsemantics/issues/29 entry on
if I remember correctly, you should first parse all the inputs using the
CompilationTestHelper method that takes many inputs.
Does that solve your problem?
cheers
Lorenzo
Xtext Book:
Re: [2.7.0] Guice errors when unit-testing the generator [message #1706136 is a reply to message #1706095] Mon, 24 August 2015 02:51 Go to previous messageGo to next message
I cannot use that method because I have two different DSLs (One DSL uses another DSL element as JvmTypeReference).
So I create and load resources for them in a single resourceSet and then pass this resourceSet to CompilationTestHelper method.
I followed this post and corresponding thread in eclipse forum, but I was getting "Couldn't resolve reference to JvmType" error with using ParseHelper.
Hence I am trying to use CompilationTestHelper.
Note: I am not directly using cross reference to another DSL, but using JvmTypeReference instead.
Any pointers to solve this?
Re: [2.7.0] Guice errors when unit-testing the generator [message #1706796 is a reply to message #1706136] Mon, 31 August 2015 04:29 Go to previous messageGo to next message
Hi Lorenzo,
Fixed NullPointerException.
The key was to call CompilationTestHelper method resourceSet( List<Pair<fileName, contents>> ).
I think you were talking about the same; but earlier I assumed you were suggesting CompilationTestHelper.compile(Iterable<CharSeq>) Smile
Thank you for your inputs. Smile
[Updated on: Mon, 31 August 2015 08:36] by Moderator
Re: [2.7.0] Guice errors when unit-testing the generator [message #1708070 is a reply to message #1706796] Sat, 12 September 2015 03:44 Go to previous message
On 31/08/2015 10:29, Manisha Ghule wrote:
> Hi Lorenzo,
> Solved the problem.
> List<Pair<fileName, contents>> ) because this method also copies
> resources to workspace.
> suggesting CompilationTestHelper.compile(Iterable<CharSeq>) :)
> Thank you for your inputs. :)
Sorry for the delay; but you seem to have already fixed the problem
yourself :)
Xtext Book:
Previous Topic:new formatting API and Xbase inherited grammar
Next Topic:Howto xtext rcp4?
Current Time: Sat Jul 26 21:26:39 EDT 2025
Powered by FUDForum. Page generated in 0.07567 seconds
