Home » Eclipse Projects » Nebula » Nebula grid widget - change header height(Nebula grid widget - change header height)
Nebula grid widget - change header height [message #1706040] Fri, 21 August 2015 06:39 Go to next message
I am working with nebula grid widget. My requirement is to set the header font to a higher value. This is possible by callin the setHeaderFont method on the gridViewer. However the header text is only partially visible because of the font size. In short the header height is not auto adjusted. the Gridcolumn header cell is not auto adjusting its height based on the font size
Am I missing something?
Re: Nebula grid widget - change header height [message #1706325 is a reply to message #1706040] Tue, 25 August 2015 14:43 Go to previous message
Did you take a look at the source. I see evidence of header row height etc [1]
[1] https://git.eclipse.org/c/nebula/org.eclipse.nebula.git/tree/widgets/grid/org.eclipse.nebula.widgets.grid/src/org/eclipse/nebula/widgets/grid/Grid.java
Previous Topic:Column Name Can be Rename In NatTable
Next Topic:Nebula PShelf Extension for Jubula
Current Time: Sat Nov 22 17:09:51 EST 2025
Powered by FUDForum. Page generated in 0.03727 seconds
