Home » Eclipse Projects » Oomph » Oomph triggers first Build before applying the correct compiler compliance level preference
Oomph triggers first Build before applying the correct compiler compliance level preference [message #1705948] Thu, 20 August 2015 07:02 Go to next message
I have an Oomph setup model in which I've recorded the java compiler compliance level, to 1.7:
<setup:PreferenceTask
    xmi:version="2.0"
    xmlns:setup="http://www.eclipse.org/oomph/setup/1.0"
    key="/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.compiler.compliance"
    value="1.7"/>
However, the first build is full of compiler errors, and I think the reason is that it only applies this preference setting after the initial build has been started.
I've also set the 'Build workspace automatically' preference to false, but is still triggers the initial build, though I cannot find any task for this in the model.
If I then clean the workspace and trigger a new build, everything is fine.
Is there a place where I can force the preferences to be applied before the first build? Or the opposite, if I can set the first build to be last thing to be done?
[Updated on: Thu, 20 August 2015 07:03] by Moderator
Re: Oomph trigger Build before applying the correct compiler compliance level preference [message #1705960 is a reply to message #1705948] Thu, 20 August 2015 08:35 Go to previous messageGo to next message
Silvestre,
Comments below.
> xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI"
> value="1.7"/>
No, that should not be the case, the build runs after the tasks have
performed, so all preferences should be in their final state.
In
org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(IProgressMonitor)
we only trigger a build is auto build is enabled. But we test for that
initially, so if a preference task sets it to false while we've already
set it to false, we won't notice that.
> fine.
Of course we've never seen such a problem for the several dozen project
setups, so something else must be going on here...
The assumption that the preferences are set later is not correct.
> done?
A build is definitely scheduled only after all tasks are performed.
Re: Oomph trigger Build before applying the correct compiler compliance level preference [message #1706037 is a reply to message #1705960] Fri, 21 August 2015 05:37 Go to previous message
Hi Ed,
you're right. The problem had nothing to do with the preferences, it was related with some wrong target platform setup.
Thanks.
Previous Topic:How to use jars from bundle pool in the PDE headless build?
Next Topic:How to configure ResourceCopy task to run only after GitClone task?
Current Time: Thu Sep 18 14:58:01 EDT 2025
Powered by FUDForum. Page generated in 0.03966 seconds
