Home » Eclipse Projects » RCP Testing Tool » Application Under Test not Recognized(I am trying to use RCPTT for GUI testing (Record and playback) where the application is not being recognised by RCPTT when i add the application path )
Application Under Test not Recognized [message #1705687] Tue, 18 August 2015 07:49 Go to next message
The Eclipse application i am using has a different folder structure than the regular applications.May be it is the reason for RCPTT to not recognize the application as input.
Is there any way to make RCPTT identify the Application i am trying to pass it as input to application under test?
Re: Application Under Test not Recognized [message #1705772 is a reply to message #1705687] Wed, 19 August 2015 02:02 Go to previous message
Try to set Location=<path to the directory which contains directory "plugins"> in "New Application Under Test" window when you try to add application to RCPTT.
Please let me know if it helps.
Previous Topic:How can I use RCPTT?
Next Topic:How to add a 64 bit eclipse AUT to RCPTT
Current Time: Mon Jul 21 15:08:27 EDT 2025
Powered by FUDForum. Page generated in 0.03620 seconds
