Home » Eclipse Projects » RCP Testing Tool » How can I use RCPTT?
How can I use RCPTT? [message #1705670] Tue, 18 August 2015 05:15 Go to next message
I'm creating own plugin. I tests my plugin runtime eclipse. I want to use this tool. But i coundn't use it. Because when click start record , open new runtime eclipse and my plugin doesn't exist in this eclipse. How can I use that tool?
Re: How can I use RCPTT? [message #1705685 is a reply to message #1705670] Tue, 18 August 2015 07:33 Go to previous message
It is neccessary to add your plugin into app before adding AUT to RCPTT.
The steps are: install plugin to Eclipse (usually you need to restart Eclipse after installation), add this Eclipse to RCPTT as AUT and run it. Do you do the same? If you install plugin (without RCPTT) does it work after restarting of application?
Also this article might be useful for you, part of it describes how to test AUT from sources.
Please try and let me know if you have any questions.
Previous Topic:Problem with: set-dialog-result Folder?
Next Topic:Application Under Test not Recognized
Current Time: Mon Jul 21 00:15:38 EDT 2025
Powered by FUDForum. Page generated in 0.06548 seconds
