Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMF stand-alone SWT problems(Problems with creating a stand-alone EMF/SWT application)  () 1 Vote
EMF stand-alone SWT problems [message #1705367] Fri, 14 August 2015 04:05 Go to next message
I´m trying to create a stand-alone EMF application, that also uses the SWT library.
My problem is that SWT needs the EMF-Activator class to render my GUI.
I thought of copying the Activator class in my package and cusomize them so that there are no final bindings anymore.
My question: Is there a better way to implement such a stand-alone application?
Best regards
Stefan
(EMF 1.6, Eclipse MARS, SWT 4.4.2)
Re: EMF stand-alone SWT problems [message #1705404 is a reply to message #1705367] Fri, 14 August 2015 13:16 Go to previous messageGo to next message
Stefan,
Comments below.
On 14/08/2015 1:42 PM, Stefan Bader wrote:
> SWT library.
SWT does not need EMF. So I have no idea what specifically you mean by
this.
Bindings? Final?
> application?
It's totally unclear what you think is a problem.
> Best regards
> Stefan
Re: EMF stand-alone SWT problems [message #1705492 is a reply to message #1705404] Mon, 17 August 2015 03:25 Go to previous messageGo to next message
I mean customize it in so far that all classes (for example the EMFFormsRendererService) can be created within the class Activator.
I can´t use the default implementation because everything makes usage of the plugin class and the bundle class, which is not possible in a stand alone application
Re: EMF stand-alone SWT problems [message #1705501 is a reply to message #1705492] Mon, 17 August 2015 04:30 Go to previous messageGo to next message
Stefan,
So your question is specifically about EMF Forms. Best you use [EMF
Forms] as the prefix to your subject and mention specific details, as
you've done in this second post, to make the context clear.
Re: EMF stand-alone SWT problems [message #1705645 is a reply to message #1705492] Tue, 18 August 2015 02:31 Go to previous messageGo to next message
Hi Stefan,
what do you mean by a stand-alone application?
Have you had a look at the "make it happen" code examples, we provide?
They all run as a standa-lone application.
Best regards
Jonas
Am 17.08.2015 um 09:25 schrieb Stefan Bader:
> alone application
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: EMF stand-alone SWT problems [message #1706014 is a reply to message #1705645] Fri, 21 August 2015 02:39 Go to previous messageGo to next message
Sorry that i used the wrong forum :/
I want to create a gui that i can open without opening the eclipse.
I want the main window to be a SWT shell, which is defided into 2 segments. The first segment is a SWT tree structure. I want the second part to render a given EMF Model.
The problem is that almost all methods depend on the plugin object or the bundle object, which i can´t use.
I´m now trying to render my model by manually creating all needed classes and copying some methods, but this isn´t working out either.
Sorry I´m a newby at EMF implementation
EDIT: and yes i looked at it, but i can´t get it to work the way i want it. In fact the EMF model i want to render was such a make-it-happen-applicaition
[Updated on: Fri, 21 August 2015 02:43] by Moderator
Re: EMF stand-alone SWT problems [message #1706021 is a reply to message #1706014] Fri, 21 August 2015 03:42 Go to previous messageGo to next message
we are happy to help you, but you need to provide more details:
Why can you not use the "bundle object"?
What exactly is that?
Which methods depend on it?
Best regards
Jonas
Am 21.08.2015 um 08:39 schrieb Stefan Bader:
Jonas Helming
Re: EMF stand-alone SWT problems [message #1706032 is a reply to message #1706014] Fri, 21 August 2015 04:50 Go to previous messageGo to next message
Hi Jonas,
I can´t use anything that uses the Plugin. class (org.eclipse.core.runtime.plugin) or the bundle class (org.osgi.framework.bundle).
These classes get called mostly by the Activator.class (org.eclipse.emf.ecp.view.internal.swt.Activator.class).
For example:
public ReportService getReportService() {
final BundleContext bundleContext = getBundle().getBundleContext();
final ServiceReference<ReportService> serviceReference =
bundleContext.getServiceReference(ReportService.class);
return bundleContext.getService(serviceReference);
I only get NullPointerExceptions when i use them, because i want it to be a pure SWT application without any links to eclipse.
I implemented it like i said. But it failes to initialize the correct renderer.
Thank you for your help
Stefan
[Updated on: Fri, 21 August 2015 04:51] by Moderator
Re: EMF stand-alone SWT problems [message #1706143 is a reply to message #1706032] Mon, 24 August 2015 03:20 Go to previous messageGo to next message
the mentioned bundle class is provided by OSGi, which has no reference
to Eclipse. Eclipse is based on OSGI, though. Do you want to build an
application without OSGi? Is there a specific reason for this requirement?
Best regards
Jonas
Am 21.08.2015 um 10:50 schrieb Stefan Bader:
> Hi Jonas,
> For eg.
> renderer.
> Thank you fort your help
> Stefan
Jonas Helming
Re: EMF stand-alone SWT problems [message #1706606 is a reply to message #1706143] Fri, 28 August 2015 02:47 Go to previous messageGo to next message
HI Jonas,
That´s a really good question. I haven´t thought about using OSGI.
My enitial though was to create a RCP application because of it´s faster start up.
I have to look into using OSGI stand alone,. Never have done this....
Thank you for your help, but maybe i´ll have to come back here if i can´t figure it out.
Stefan
Re: EMF stand-alone SWT problems [message #1706664 is a reply to message #1706606] Fri, 28 August 2015 09:58 Go to previous message
RCP applications are typically based on OSGi anyways...
Am 28.08.2015 um 08:47 schrieb Stefan Bader:
> HI Jonas,
> start up.
> Regards
> Stefan
Jonas Helming
Previous Topic:[Texo] Annotations Model directly in ECore
Next Topic:[Teneo] MappingException on embedded object after save/refresh/save cycle on parent object
Current Time: Mon Jul 21 05:13:20 EDT 2025
Powered by FUDForum. Page generated in 0.05475 seconds
