Home » Archived » Eclipse Process Manager (Stardust) » How to access transitions programmatically
How to access transitions programmatically [message #1705285] Thu, 13 August 2015 09:35 Go to next message
Hi all,
I would like to access the outgoing transitions for each activity in my workflows. I see that the IActivity interface and its implementation, the ActivityBean class provide the getOutTransitions() method but the QueryService, WorkflowService etc use the Activity interface (and interfaces without the "I" at the beginning in general).
How can I acquire an instance of the IActivity interface or could someone please explain the proper way to access transitions?
Thanks.
[Updated on: Thu, 13 August 2015 09:37] by Moderator
Re: How to access transitions programmatically [message #1705490 is a reply to message #1705285] Mon, 17 August 2015 03:04 Go to previous messageGo to next message
Here is another approach see if below code helps you
ServiceFactory sf=ServiceFactoryLocator.get("motu", "motu");
QueryService qs=sf.getQueryService();
ProcessDefinition processDefinition = qs.getProcessDefinition(
            "ProcessDefinition1");
List<Activity> activityList=processDefinition.getAllActivities();
System.out.println("Iterating for all Activities for OutGoing transitions");
for (Activity activity : activityList) {
	System.out.println("Displaying Outgoing Transition for Activity"+activityList.indexOf(activity)+"="+activity.getName());
	List<Transition> transitionList = processDefinition.getOutgoingTransitions(activity);
	for (Transition transition : transitionList) {
		System.out.println(" *******Trans details*********" +
			"\n transitionId = "+transition.getId()+
			"\n transitionCondition = "+transition.getCondition()+
			"\n transitionSourceActivity = "+transition.getSourceActivityId()+
			"\n transitionTargetActivity = "+transition.getTargetActivityId()+
			"\n transitionConditionType = "+transition.getConditionType());
Ashish
Re: How to access transitions programmatically [message #1705536 is a reply to message #1705490] Mon, 17 August 2015 08:26 Go to previous messageGo to next message
Hi Ashish,
Thank you for your answer! This is exactly what I need, but as I see, the ProcessDefinition interface contains this method only in Stardust 3.0.0 and I'm currently using 2.1.1. If I upgrade my Stardust artifacts to 3.0.0., does that mean I have to upgrade the modeller to 3.0.0., thus upgrade my Eclipse to Mars as well? What are the implications in terms of the AuditTrail database, do I have to upgrade the 2.1.1. schema?
Tamás
Re: How to access transitions programmatically [message #1705565 is a reply to message #1705536] Mon, 17 August 2015 10:11 Go to previous message
I've checked and the database schema hasn't changed, this is the most important, so I'm good to go. Thank you once more!
Previous Topic:Deployed models are cached during unit tests
Next Topic:upgrade maven project 2 to 3
Current Time: Mon Jul 21 12:33:59 EDT 2025
Powered by FUDForum. Page generated in 0.03567 seconds
