Home » Modeling » EMF » [XCore] Xtext-maven-plugin with xcore lead to exception
[XCore] Xtext-maven-plugin with xcore lead to exception [message #1705483] Sun, 16 August 2015 16:47 Go to next message
Hi modeling heroes!
I'm creating a tycho/xcore/xtext project, and encounters an issue when mixing xcore and xtext.
While building, I got this exception on my xcore powered project:
[INFO] --- xtext-maven-plugin:2.8.4:generate (default) @ net.osgiliath.modeler.metamodel.class ---
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore:jar:2.10.0-v20130911-20131101.184326-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore:jar:2.10.0-v20140117-20140308.162131-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore:jar:2.10.0-v20140514-20140615.074948-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.common:jar:2.10.0-v20130911-20131101.184418-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.common:jar:2.10.0-v20140117-20140308.162206-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.common:jar:2.10.0-v20140514-20140615.074938-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore.xmi:jar:2.10.0.v20130911-20131101.184401-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore.xmi:jar:2.10.0-v20140117-20140308.162157-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.ecore.xmi:jar:2.10.0-v20140514-20140615.075014-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen:jar:2.9.0-v20130930-20131101.184305-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen:jar:2.10.0-v20140127-20140308.162113-2 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen:jar:2.10.0-v20140519-20140615.074924-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen.ecore:jar:2.10.0-v20130930-20131101.184147-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen.ecore:jar:2.10.0-v20140127-20140308.162034-2 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[WARNING] The POM for org.eclipse.emf:org.eclipse.emf.codegen.ecore:jar:2.10.0-v20140519-20140615.074844-1 is invalid, transitive dependencies (if any) will not be available, enable debug logging for more details
[INFO] Encoding: UTF-8
[INFO] Compiler source level: 1.8
[INFO] Compiler target level: 1.8
[INFO] Using common types.
[INFO] Collecting source models.
[INFO] Installing type provider.
[WARNING] Only terminal rules are supported by lexer based converters but got SignedInt which is an instance of ParserRule
java.lang.IllegalArgumentException: Only terminal rules are supported by lexer based converters but got SignedInt which is an instance of ParserRule
	at org.eclipse.xtext.conversion.impl.AbstractLexerBasedConverter.setRule(AbstractLexerBasedConverter.java:128)
	at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.internalRegisterForClass(AbstractDeclarativeValueConverterService.java:128)
	at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.getConverters(AbstractDeclarativeValueConverterService.java:95)
	at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.getConverter(AbstractDeclarativeValueConverterService.java:83)
	at org.eclipse.xtext.conversion.impl.AbstractDeclarativeValueConverterService.toValue(AbstractDeclarativeValueConverterService.java:74)
	at org.eclipse.xtext.parser.DefaultEcoreElementFactory.getTokenValue(DefaultEcoreElementFactory.java:90)
	at org.eclipse.xtext.parser.DefaultEcoreElementFactory.set(DefaultEcoreElementFactory.java:69)
	at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.set(AbstractInternalAntlrParser.java:319)
	at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.set(AbstractInternalAntlrParser.java:326)
	at org.eclipse.emf.ecore.xcore.parser.antlr.internal.InternalXcoreParser.ruleXStringToStringMapEntry(InternalXcoreParser.java:871)
	at org.eclipse.emf.ecore.xcore.parser.antlr.internal.InternalXcoreParser.ruleXAnnotation(InternalXcoreParser.java:669)
	at org.eclipse.emf.ecore.xcore.parser.antlr.internal.InternalXcoreParser.ruleXPackage(InternalXcoreParser.java:286)
	at org.eclipse.emf.ecore.xcore.parser.antlr.internal.InternalXcoreParser.entryRuleXPackage(InternalXcoreParser.java:199)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.parse(AbstractInternalAntlrParser.java:541)
	at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.doParse(AbstractAntlrParser.java:102)
	at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.parse(AbstractAntlrParser.java:84)
	at org.eclipse.xtext.parser.antlr.AbstractAntlrParser.doParse(AbstractAntlrParser.java:62)
	at org.eclipse.xtext.parser.AbstractParser.parse(AbstractParser.java:33)
	at org.eclipse.xtext.resource.XtextResource.doLoad(XtextResource.java:170)
	at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doLoad(LazyLinkingResource.java:101)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
	at org.eclipse.xtext.resource.persistence.StorageAwareResource.load(StorageAwareResource.java:95)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
	at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:265)
	at org.eclipse.xtext.builder.standalone.StandaloneBuilder.launch(StandaloneBuilder.java:253)
	at org.eclipse.xtext.maven.XtextGenerator.internalExecute(XtextGenerator.java:164)
	at org.eclipse.xtext.maven.XtextGenerator.execute(XtextGenerator.java:140)
	at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
	at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
	at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
	at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
	at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
	at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
	at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
	at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
	at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
	at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
[INFO] Generating stubs into /Users/charliemordant/git/net.osgiliath.modeler/net.osgiliath.modeler.metamodels/net.osgiliath.modeler.metamodel.class/target/xtext-temp/stubs
[INFO] Compiling stubs located in /Users/charliemordant/git/net.osgiliath.modeler/net.osgiliath.modeler.metamodels/net.osgiliath.modeler.metamodel.class/target/xtext-temp/stubs
[INFO] Installing type provider for stubs.
[INFO] Validate and generate.
[INFO] Starting validation for input: 'class.xcore'
[INFO] Starting generator for input: 'class.xcore'
Here's my xtext-maven-plugin configuration (if it is related):
				<plugin>
					<groupId>org.eclipse.xtext</groupId>
					<artifactId>xtext-maven-plugin</artifactId>
					<version>${xtext-version}</version>
					<executions>
						<execution>
							<phase>generate-sources</phase>
							<goals>
								<goal>generate</goal>
							</goals>
						</execution>
					</executions>
					<configuration>
						<failOnValidationError>false</failOnValidationError>
						<languages>
							<language>
								<setup>org.eclipse.xtext.ecore.EcoreSupport</setup>
								<outputConfigurations>
									<outputConfiguration>
										<outputDirectory>${project.build.directory}/model-gen</outputDirectory>
									</outputConfiguration>
								</outputConfigurations>
							</language>
							<language>
								<setup>org.eclipse.emf.codegen.ecore.xtext.GenModelSupport</setup>
							</language>
							<language>
								<setup>org.eclipse.emf.ecore.xcore.XcoreStandaloneSetup</setup>
							</language>
						</languages>
						<sourceRoots>
							<root>${project.basedir}/model</root>
						</sourceRoots>
					</configuration>
					<dependencies>
						<dependency>
							<groupId>org.osgi</groupId>
							<artifactId>org.osgi.core</artifactId>
							<version>${org.osgi_org.osgi.core.version}</version>
						</dependency>
						<dependency>
							<groupId>org.eclipse.core</groupId>
							<artifactId>org.eclipse.core.resources</artifactId>
							<version>${org.eclipse.core_org.eclipse.core.resources.version}</version>
						</dependency>
						<dependency>
							<groupId>org.eclipse.text</groupId>
							<artifactId>org.eclipse.text</artifactId>
							<version>${org.eclipse.text_org.eclipse.text.version}</version>
						</dependency>
						<dependency>
							<groupId>org.eclipse.emf</groupId>
							<artifactId>org.eclipse.emf.ecore</artifactId>
							<version>${org.eclipse.emf_org.eclipse.emf.ecore.version}</version>
						</dependency>
						<dependency>
							<artifactId>org.eclipse.emf.codegen.ecore</artifactId>
							<version>${org.eclipse.emf_org.eclipse.emf.codegen.ecore.version}</version>
						</dependency>
						<dependency>
							<artifactId>org.eclipse.emf.codegen.ecore.xtext</artifactId>
							<version>${org.eclipse.emf_org.eclipse.emf.codegen.ecore.xtext.version}</version>
						</dependency>
						<dependency>
							<artifactId>org.eclipse.emf.ecore.xcore.lib</artifactId>
							<version>${org.eclipse.emf_org.eclipse.emf.ecore.xcore.lib.version}</version>
						</dependency>
						<dependency>
							<artifactId>org.eclipse.emf.ecore.xcore</artifactId>
							<version>${org.eclipse.emf_org.eclipse.emf.ecore.xcore.version}</version>
						</dependency>
						<dependency>
							<artifactId>org.eclipse.xtext.common.types</artifactId>
							<version>${org.eclipse.xtext_org.eclipse.xtext.common.types.version}</version>
						</dependency>
						<dependency>
							<artifactId>org.eclipse.xtext.xbase</artifactId>
							<version>${org.eclipse.xtext_org.eclipse.xtext.xbase.version}</version>
						</dependency>
						<dependency>
							<artifactId>org.eclipse.xtext.xbase.lib</artifactId>
						</dependency>
					</dependencies>
				</plugin>
<properties>
		<tycho-version>0.23.1</tycho-version>
		<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
		<org.eclipse.emf_org.eclipse.emf.codegen.ecore.xtext.version>1.1.1</org.eclipse.emf_org.eclipse.emf.codegen.ecore.xtext.version>
		<org.eclipse.emf_org.eclipse.emf.ecore.xcore.lib.version>1.1.0</org.eclipse.emf_org.eclipse.emf.ecore.xcore.lib.version>
		<org.eclipse.emf_org.eclipse.emf.ecore.xcore.version>1.2.2</org.eclipse.emf_org.eclipse.emf.ecore.xcore.version>
		<xtext-version>2.8.4</xtext-version>
		<org.osgi_org.osgi.core.version>6.0.0</org.osgi_org.osgi.core.version>
		<org.eclipse.core_org.eclipse.core.resources.version>3.7.100</org.eclipse.core_org.eclipse.core.resources.version>
		<org.eclipse.text_org.eclipse.text.version>3.5.101</org.eclipse.text_org.eclipse.text.version>
		<org.eclipse.emf_org.eclipse.emf.ecore.version>2.10.1</org.eclipse.emf_org.eclipse.emf.ecore.version>
		<org.eclipse.emf_org.eclipse.emf.codegen.ecore.version>2.10.1</org.eclipse.emf_org.eclipse.emf.codegen.ecore.version>
		<org.eclipse.equinox_org.eclipse.equinox.common.version>3.6.0</org.eclipse.equinox_org.eclipse.equinox.common.version>
		<org.eclipse.xtext_org.eclipse.xtext.common.types.version>2.8.4</org.eclipse.xtext_org.eclipse.xtext.common.types.version>
		<org.eclipse.xtext_org.eclipse.xtext.xbase.version>2.8.4</org.eclipse.xtext_org.eclipse.xtext.xbase.version>
		<parentPropertiesFile>root.properties</parentPropertiesFile>
	</properties>
And finally the grammar (fairly simple):
@GenModel(childCreationExtenders="true", copyrightText="Osgiliath All rights reserved", extensibleProviderFactory="true", modelDirectory="/net.osgiliath.modeler.metamodel.class/target/model-gen", editDirectory="/net.osgiliath.modeler.metamodel.class.edit/src/main/java-gen", editorDirectory="/net.osgiliath.modeler.metamodel.class.editor/src/main/java-gen", creationSubmenus="true")
@Ecore(nsURI="http://www.osgiliath.net/metamodels/classes/0.0.1")
package net.osgiliath.modeler.metamodel.classes
class ONamedElement {
	String name
class OElements extends ONamedElement {
	contains OPackage[] packages
	contains OParametrizedClassifier[] parametrizedClassifiers
class OPackage extends ONamedElement {
	contains OPackage[] subPackages opposite superPackage
	container OPackage superPackage opposite subPackages
	contains OClassifier[] classifiers opposite ownerPackage
	derived String FQN get
		 var FQN = name
		 var OPackage current = superPackage
		 while (null != current) {
		 	FQN=current.name + "." + FQN
		 	current = current.superPackage
		 return FQN
class OType extends ONamedElement{
enum VISIBILITY {
	public as '+' = 0
	protected as '#' = 1
	private as '-' = 2
class OVisibilityAble extends OType {
	VISIBILITY visibility
class OStaticable extends OType {
	boolean isStatic = "false"
class OFinalizable extends OType {
	Boolean isFinal = "false"
class OAbstractable {
	Boolean isAbstract = "false"
class OClassifier extends OType {
	container OPackage ownerPackage opposite classifiers
	derived String fQN get
		 return ownerPackage.FQN + "." + name
	op String toString() {
		return FQN
class OParameter extends ONamedElement, OFinalizable {
	refers OType oType
class OMethod extends ONamedElement, OVisibilityAble, OStaticable, OFinalizable, OAbstractable {
	refers OType returnType
	contains OParameter[] parameters
class OMethodable extends OClassifier {
	contains OMethod[] methods
class OInterface extends OVisibilityAble,OMethodable {
	refers OInterface[] extensions
class OAttribute extends OParameter, OVisibilityAble, OStaticable {
class OClass extends OVisibilityAble, OMethodable, OFinalizable, OAbstractable {
	refers OInterface[] implements
	refers OClass extensions
	contains OAttribute[] attributes
class OParametrizedClassifier extends OClassifier {
	refers OClassifier classifier
	refers OClassifier[] parametrizedClassifiers
I also have a grammar using this xcore model, that throws the same exception when I reference this xcore. But when I export the genmodel then reference it for the grammar, it passes without any issue.
Any idea on this? I looked at eclipse bugs or any other source, but didn't find any similar issue.
Charlie
Re: [XCore] Xtext-maven-plugin with xcore lead to exception [message #1705487 is a reply to message #1705483] Mon, 17 August 2015 00:41 Go to previous messageGo to next message
Charlie,
This should be fixed in the maintenance stream
http://download.eclipse.org/modeling/emf/emf/updates/2.11.x
On 16/08/2015 10:47 PM, Charlie Mordant wrote:
> Hi modeling heroes!
> ParserRule
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> <plugin>
> <executions>
> <execution>
> <goals>
> </goals>
> </execution>
> </executions>
> <configuration>
> <languages>
> <language>
> </language>
> <language>
> </language>
> <language>
> </language>
> </languages>
> <sourceRoots>
> </sourceRoots>
> </configuration>
> <dependencies>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> <dependency>
> </dependency>
> </dependencies>
> </plugin>
> <properties>
> </properties>
> String name
> var FQN = name
> } return FQN
> enum VISIBILITY {
> public as '+' = 0
> private as '-' = 2
> return FQN
> refers OType oType
> OAbstractable {
> refers OClass extensions contains OAttribute[] attributes
> Best regards,
> Charlie
Re: [XCore] Xtext-maven-plugin with xcore lead to exception [message #1705598 is a reply to message #1705487] Mon, 17 August 2015 13:19 Go to previous messageGo to next message
Hi Ed,
Thank you for the answer, I will try. Unfortunately, these deps must be referenced as Maven dependencies (not as p2 one) because they're necessary for the m-xtext-pg.
Can you ping this thread while available?
Charlie
[Updated on: Mon, 17 August 2015 13:20] by Moderator
Re: [XCore] Xtext-maven-plugin with xcore lead to exception [message #1705648 is a reply to message #1705598] Tue, 18 August 2015 03:00 Go to previous messageGo to next message
Charlie,
They won't end up there because I do something. In fact I have no idea
how they'd ever end up there. Maybe Dennis knows...
On 17/08/2015 7:19 PM, Charlie Mordant wrote:
> Hi Ed,
> be referenced as Maven dependencies (not on a p2 one) because they're
> Best regards,
> Charlie
Re: [XCore] Xtext-maven-plugin with xcore lead to exception [message #1705840 is a reply to message #1705648] Wed, 19 August 2015 08:22 Go to previous message
Hello Charlie,
I've just released xcore 1.3.1 maven artifacts, where the issue you had is fixed.
It will be available in maven central soon.
Dennis.
Previous Topic:What should I use for UI and user actions?
Next Topic:Resolving generic types
Current Time: Mon Jul 21 05:02:12 EDT 2025
Powered by FUDForum. Page generated in 0.06028 seconds
