Home » Newcomers » Newcomers » Eclipse won't start anymore after Windows 7 self-update
icon9.gif  Eclipse won't start anymore after Windows 7 self-update [message #1705426] Sat, 15 August 2015 05:38 Go to next message
Hello ,
I just started to work with eclipse a month ago to do some SAPUI5 Development
I use the Luna Java EE VErsion with the necessary PlugIns
Everything worked fine until yesterday.
Windows7 Updated itself (you know this bugfixing updates, which start itself if you are not fast enough to stop it)
After reboot I can't restart Eclipse. Message " An Error has occured. See the log file in workspace"
in the logfile i found this:
ERROR workbench:84 - org.eclipse.e4.ui.workbench - 0 - Error disposing widget for : org.eclipse.e4.ui.model.application.ui.menu.impl.MenuImpl null
java.lang.IllegalArgumentException: Argument not valid
Is there a chance to reanimate Eclipse?
I tried to run it with -clean, but same Problem....
I hope you can help me
Re: Eclipse won't start anymore after Windows 7 self-update [message #1705455 is a reply to message #1705426] Sat, 15 August 2015 17:19 Go to previous messageGo to next message
On 08/15/2015 03:12 PM, J. B. wrote:
> Hello ,
> Development
> Everything worked fine until yesterday. Windows7 Updated itself (you
> enough to stop it)
It's hard to say from the information you give (and I'm not a Windows
guy), but I would say that the best way to avoid this sort of disaster
is to divorce Eclipse from what's going on on your computer.
In particular, I never let Eclipse run on whatever JRE my computer is
using. Instead, I set it up to run off a private copy. That way, I know
when it changes because I have to change it by hand.
Here are some notes if you find them useful.
http://www.javahotchocolate.com/notes/eclipse-jdk-tomcat.html
Re: Eclipse won't start anymore after Windows 7 self-update [message #1705469 is a reply to message #1705455] Sun, 16 August 2015 07:25 Go to previous messageGo to next message
I'm normally no windows user, too. But in this case I had to prepare some things on a windows laptop.
I have to present them at the end of next week and now Eclipse stopped working ,
it's kind of frustrating.
I don't know what to do best now. Is it possible to fix or do I have to do a reinstall and then rework the
30 projekts that habve been in the workspace?. I hope there is a simple solution to fix it, so I won't loose so much time.
Which more Information would help?
Re: Eclipse won't start anymore after Windows 7 self-update [message #1705478 is a reply to message #1705469] Sun, 16 August 2015 10:38 Go to previous message
> working , it's kind of frustrating. I don't know what to do best now. Is
> it possible to fix or do I have to do a reinstall and then rework the 30
My take is that you should download Luna again, this doesn't take long,
then set it up again. Depending on how much customization you've done,
plug-ins you need to install, etc. This is where the time will burn.
Next, make sure you're launching your new installation (and not the old,
presumably broken one). Open the workspace(s) where your projects should
still be good.
That failing, then create a new workspace and open it in the workbench.
Import your projects (File -> Import... -> General -> Existing Projects
into Workspace). Unless your projects were corrupted, and that's not
very likely based on what you've recounted, you should then be back up
and going.
When I was a Windows 7 user, and my attitude is generally the same for
Linux updates, I just allowed the updating to go on automatically. I
also allowed Java to be updated that way. What I did to protect myself
from surprise changes, however, was to install my own private JDK and
peg Eclipse on it (via both eclipse.ini and the Preferences -> Java ->
Installed JREs configuration).
Hope this helps and I hope you get back up quickly.
Previous Topic:C++: Symbol 'cout' could not be resolved
Next Topic:eclipse gets deleted after start
Current Time: Sun Jul 27 11:53:17 EDT 2025
Powered by FUDForum. Page generated in 0.09260 seconds
