Re: OCLinEclipse Discarding Tuple Type Information on Operations [message #1707024 is a reply to message #1707014] |
Tue, 01 September 2015 10:50   |
It should work, but rather more simply than you have suggested. OCL has
no mutation, so no constructors. The prototyped behavior is just direct
initialization with explicit/default values.
class TupleIntInt
property m : Integer;
property n : Integer;
let aTII = TupleIntInt{m = 1, n = 2} in aTII.m * aTII.n
The current prototype is inaccurate wrt to the shadow semantics that
requires shared copies, so
TupleIntInt{m = 1, n = 2} = TupleIntInt{m = 1, n = 2}
should be unequivocably true. It is false when executed using the OCL
interpreter. It is perhaps true if the code generator is given an
opportunity to do common subexpression elimination. Fixed on a WIP branch.
Ed Willink
On 01/09/2015 14:51, Keith Ó Dúlaigh wrote:
> Related to this question. Suppose I have created a class TupleIntInt
> similar to the following code. Then can I use OCL to construct a new
> instance of TupleIntInt?
> class TupleIntInt
> operation create() : TupleIntInt[1]
> body: TupleIntInt{m = 1, n = 2};
> Constructing a new object always returns "invalid" when I attempt to
> construct a new object.
> I note in an earlier post there is a link to a bug report that says
> "...pivot now has a prototype of type constructors."
> Keith
> Earlier related post:
> https://www.eclipse.org/forums/index.php/t/543504/
Re: OCLinEclipse Discarding Tuple Type Information on Operations [message #1707035 is a reply to message #1707024] |
Tue, 01 September 2015 11:48   |
Thanks Ed, maybe my Java code is the problem because I still have "invalid" being returned.
My full OCL looks like this...
package example : web = 'URL REMOVED BECAUSE I'VE < 5 POSTS'
class TupleIntInt
operation test() : Integer
body: let ai = TupleIntInt{m= 5, n = 1}
in ai.m * ai.n;
operation test2() : Integer
body: 5;
operation test3() : TupleIntInt[1]
body: TupleIntInt{m= 5, n = 1};
attribute m : Integer[?];
attribute n : Integer[?];
...and my Java like this:
package main;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EClassifier;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EParameter;
import org.eclipse.ocl.OCL;
import org.eclipse.ocl.ParserException;
import org.eclipse.ocl.Query;
import org.eclipse.ocl.ecore.Constraint;
import org.eclipse.ocl.ecore.EcoreEnvironmentFactory;
import org.eclipse.ocl.expressions.OCLExpression;
import org.eclipse.ocl.helper.OCLHelper;
import example.ExampleFactory;
public class Application {
public static void main(String... args) {
ExampleFactory.eINSTANCE.eClass();
Object o = runOcl("test2()");
System.out.println(o);
o = runOcl("test()");
o = runOcl("test3()");
private static Object runOcl(String queryText) {
OCL<?, EClassifier, ?, ?, ?, EParameter, ?, ?, ?, Constraint, EClass, EObject> ocl = OCL
.newInstance(EcoreEnvironmentFactory.INSTANCE);
OCLHelper<EClassifier, ?, ?, Constraint> helper = ocl.createOCLHelper();
helper.setContext(ExampleFactory.eINSTANCE.createTupleIntInt().eClass());
Query<EClassifier, EClass, EObject> query = null;
try {
OCLExpression<EClassifier> expression = helper.createQuery(queryText);
query = ocl.createQuery(expression);
} catch (ParserException error) {
throw new RuntimeException(error);
return query.evaluate(ExampleFactory.eINSTANCE);
Running the Java code yields:
[Updated on: Tue, 01 September 2015 11:49] by Moderator
Re: OCLinEclipse Discarding Tuple Type Information on Operations [message #1707097 is a reply to message #1707040] |
Wed, 02 September 2015 06:12  |
Okay thanks again Ed. It works now.
The updated Java code is:
package main;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.impl.EPackageRegistryImpl;
import org.eclipse.ocl.pivot.ExpressionInOCL;
import org.eclipse.ocl.pivot.utilities.OCL;
import org.eclipse.ocl.pivot.utilities.OCLHelper;
import org.eclipse.ocl.pivot.utilities.ParserException;
import org.eclipse.ocl.xtext.essentialocl.EssentialOCLStandaloneSetup;
import example.ExamplePackage;
import example.TupleIntInt;
public static void main(String... args) throws ParserException {
Object o;
private static Object runOcl(String queryText) throws ParserException {
EPackage.Registry registry = new EPackageRegistryImpl();
registry.put(ExamplePackage.eNS_URI, ExamplePackage.eINSTANCE);
EssentialOCLStandaloneSetup.doSetup();
OCL ocl = OCL.newInstance(registry);
TupleIntInt example = ExampleFactory.eINSTANCE.createTupleIntInt();
OCLHelper helper = ocl.createOCLHelper(ExamplePackage.Literals.TUPLE_INT_INT);
ExpressionInOCL expression = helper.createQuery(queryText);
Object result = ocl.evaluate(example, expression);
return result;
The OCL code remaines the same as above and the dependencies required are:
1. org.eclipse.core.runtime
2. org.eclipse.emf.ecore
3. org.eclipse.emf
4. org.eclipse.ocl.pivot
5. org.apache.log4j
6. com.google.guava
7. com.google.inject
8. org.eclipse.ocl.xtext.essentialocl
FUDForum. Page generated in 0.09161 seconds
