| Re: create containment association at a superclass level [message #170520 is a reply to message #170488] |
Tue, 29 January 2008 10:01   |
Hi Julien,
A "phantom" reference-based link is a link mapping where these two
fields are not blank and the target feature is a containment feature.
Boris
Julien DeAntoni wrote:
> Thank you Boris,
> just to be sure; A "phantom" reference-based link is just a link mapping
> where the only non-blank fields are "target Features" and "diagram
> Link" ?
> Regards,
> Julien
> Boris Blajer wrote:
>> Hi Julien,
>> You should declare a separate node in the mapping model for each of
>> the non-abstract subclasses and a single "phantom" reference-based
>> link for the containment reference. I believe it should work; if it
>> doesn't, you should probably file a bug report.
>> Best regards,
>> Boris
>>> Hello all,
>>> sorry for this question but I'm really out of idea :-/
>>> I have a class that has an containment relation with an abstract
>>> superclass. Two classes inherit from the abstract class.
>>> I'd like to represent the containment on my diagram but the regular
>>> way to do for containment relation (see here :
>>> http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg08564.html)
>>> does not work :-(
>>> Please, how can I do ?
>>> thanks
>>> julien
| Re: create containment association at a superclass level [message #170536 is a reply to message #170520] |
Tue, 29 January 2008 10:35  |
OK,
so finally there is a bug...
thanks !
Best regards
Julien
Boris Blajer wrote:
> Hi Julien,
> Best regards,
> Boris
>> Thank you Boris,
>> mapping where the only non-blank fields are "target Features" and
>> "diagram Link" ?
>> Regards,
>> Julien
>> Boris Blajer wrote:
>>> Hi Julien,
>>> Best regards,
>>> Boris
>>>> Hello all,
>>>> does not work :-(
>>>> thanks
>>>> julien
FUDForum. Page generated in 0.04934 seconds
