How to redirect git clone to use https instead of git: protocol? [message #1705144] |
Wed, 12 August 2015 08:42  |
Hallo,
I'm behind a corporate firewall which blocks e.g. git clone git@github.com:eclipse/xtext.git and so we would have to use git clone https://github.com/eclipse/xtext.git.
Oomph's Xtext setup model however uses git@github.com:eclipse/xtext.git and so fails for us with the error who's full detalis are shown below.
Is it possible to teach Oomph to always use https instead of git protocol with jgit? If this is not supported yet, would a new Bugzilla about this be welcome? Is there any short-term workaround for this?
Would a new Bugzilla to have Oomph do this automatically whenever a proxy is detected be useful? à la what they're doing e.g. in https://github.com/bower/bower/issues/731.
Thank you!
Performing Git Clone git@github.com:eclipse/xtext.git (master)
Cloning Git repo git@github.com:eclipse/xtext.git to /home/mvorburger/dev/Xtext/git/xtext
java.lang.Exception: org.eclipse.jgit.api.errors.TransportException: git@github.com:eclipse/xtext.git: timeout: socket is not established
at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:756)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:2952)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.access$1(SetupTaskPerformer.java:2911)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil$1.run(SetupTaskPerformer.java:3996)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2241)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.performNeededSetupTasks(SetupTaskPerformer.java:3990)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer$WorkspaceUtil.access$0(SetupTaskPerformer.java:3988)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2902)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2877)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2771)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:542)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:627)
Caused by: org.eclipse.jgit.api.errors.TransportException: git@github.com:eclipse/xtext.git: timeout: socket is not established
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:139)
at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:193)
at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:133)
at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.cloneRepository(GitCloneTaskImpl.java:812)
at org.eclipse.oomph.setup.git.impl.GitCloneTaskImpl.perform(GitCloneTaskImpl.java:681)
... 1 more
Caused by: org.eclipse.jgit.errors.TransportException: git@github.com:eclipse/xtext.git: timeout: socket is not established
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:159)
at org.eclipse.jgit.transport.SshTransport.getSession(SshTransport.java:136)
at org.eclipse.jgit.transport.TransportGitSsh$SshFetchConnection.<init>(TransportGitSsh.java:262)
at org.eclipse.jgit.transport.TransportGitSsh.openFetch(TransportGitSsh.java:161)
at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:136)
at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:122)
at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1138)
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:130)
... 2 more
Caused by: com.jcraft.jsch.JSchException: timeout: socket is not established
at com.jcraft.jsch.Util.createSocket(Util.java:394)
at com.jcraft.jsch.Session.connect(Session.java:215)
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:116)
... 3 more
FUDForum. Page generated in 0.22044 seconds
