Home » Modeling » EMF » EMF Forms notification in e4
EMF Forms notification in e4 [message #1704914] Mon, 10 August 2015 13:18 Go to next message
I wonder how we can subscribe to notification in EMF Forms (or just EMF) - do we need to write adapters and add them to everey EObject like this: eObj.eAdapters().add(myLsitener)?
How to use e4 eventing system, so the handler execution will be triggered? Or what is the recommended way to be notified of model changes coming from EMF Froms part in my custom part?
is it to much for EMF Forms community to provide working CRUD sample? Always I only find snippets and have no idea o the big picture... How can I get this? All the books all outdated, the frameworks docs are incomplete - do I need to join some confidential alliance to get this?
Thanks in advance
Re: EMF Forms notification in e4 [message #1704938 is a reply to message #1704914] Mon, 10 August 2015 20:32 Go to previous messageGo to next message
I answer my own question which was way unrelaxed...
No EMF does not propagate events to e4 brokers.
Probably it is not to complex to setup on top of EMF if you want.
CRUD sample is provided, just search for org.eclipse.example.bowling.tutorial in web
Re: EMF Forms notification in e4 [message #1705003 is a reply to message #1704938] Tue, 11 August 2015 07:39 Go to previous messageGo to next message
I would rather not publish domain model changes using the default event
bus. The EMF Client Platform provides a EMF specific change broker,
which allows to get notified about changes in a more comfortable way
than implementing Adapters.
Best regards
Jonas
Am 11.08.2015 um 02:32 schrieb Alexander Zavodnikov:
Jonas Helming
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
Re: EMF Forms notification in e4 [message #1705015 is a reply to message #1705003] Tue, 11 August 2015 08:43 Go to previous messageGo to next message
Many thanks for pointing, Jonas!
Are you talking about ECPObservers?
I downloaded the latest Eclipse Modeling Package. It includes EMF Forms which is based on ECP (or it is not?) and there are no ECPObserver classes. So I tought it is deprecated stuff...
What bundle does provide the classes?
Or do you mean something different?
Anyway, please provide a line of code demonstrating how to subscribe for those events.
Best regards
Alexander
[Updated on: Tue, 11 August 2015 08:46] by Moderator
Re: EMF Forms notification in e4 [message #1705027 is a reply to message #1705015] Tue, 11 August 2015 09:55 Go to previous messageGo to next message
I found the bundle and added following code at the bottom of ModelEditor.init(IEditorSite, IEditorInput):
ECPUtil.getECPObserverBus().register(new ECPProjectContentChangedObserver() {
public Collection<Object> objectsChanged(ECPProject project, Collection<Object> objects) {
return null;
The registering works, the observer goes into the map of ECPObserverBus.
But the callback method gets never called if I change the model .
No errors or warnings... do I miss something?
[Updated on: Tue, 11 August 2015 12:19] by Moderator
Re: EMF Forms notification in e4 [message #1705106 is a reply to message #1705015] Wed, 12 August 2015 03:34 Go to previous messageGo to next message
the component is not yet part of our SDK and therefore not part of the
Mars release. It is hosted at our target update site
(http://www.eclipse.org/ecp/emfforms/download.html)
The name of the bus itself is ChangeBroker, it is registered as an OSGi
service.
To make the broker work, it needs a running instance of an
NotificationProvider, which pushes all notfications to the broker. See
the existing implementations for examples. I will probably blog about
this component, soon.
Best regards
Jonas
Am 11.08.2015 um 14:43 schrieb Alexander Zavodnikov:
> Or do yout mean something different?
> Anyway, please provide a line of code demonstrating how to subscribe to
> those events.
> Best regards
> Alexander
Jonas Helming
Re: EMF Forms notification in e4 [message #1705152 is a reply to message #1705106] Wed, 12 August 2015 09:23 Go to previous messageGo to next message
Hi Jonas
do you mean this blog? http://eclipsesource.com/blogs/author/jhelming/
please post here a short once you are done
Is org.eclipse.emf.ecp.changebroker plugin the only thing needed to provide functionality without EMFStore?
[Updated on: Wed, 12 August 2015 13:03] by Moderator
Re: EMF Forms notification in e4 [message #1705242 is a reply to message #1705152] Thu, 13 August 2015 04:38 Go to previous messageGo to next message
are you sure, you are using the "target platform" update site?
Should be under "EMF Client Platform Features"
Best regards
Jonas
Am 12.08.2015 um 15:23 schrieb Alexander Zavodnikov:
> Hi Jonas
> thank you, please post URL of your blog here when you are done with
> this article.
> I can't find org.eclipse.emf.ecp.changebroker feature in 1.6.1 downloads.
> Are you sure it is there, maybe it is planned for 1.7 release?
> Best regards
> Alexander
Jonas Helming
Re: EMF Forms notification in e4 [message #1708931 is a reply to message #1705242] Tue, 22 September 2015 10:29 Go to previous messageGo to next message
You suggest to use some undocumented things (maybe they're experimental and disappear in next minor release). I don't think developers having to deliver reliable solutions go this way.
...anyway, setting adapter on each and every object is sappy for large object graphs, which are not uncommon for industry-level applications.
Anybody another suggestion?
[Updated on: Tue, 22 September 2015 14:58] by Moderator
Re: EMF Forms notification in e4 [message #1709015 is a reply to message #1708931] Wed, 23 September 2015 06:14 Go to previous messageGo to next message
Hi Alexander,
You had a question about EMF notifications initially and about a good
way of dealing with them. So if you want to listen to all changes in a
model instance, you can use a EContentAdapter (provided by EMF). An
alternative would be the ChangeBroker I mentioned. The broker uses the
EContentAdapter to retrieve notifications internally anyways, so it is
basically just another more comfortable API to do the same thing. As an
example, it allows for filtering the event you want to be notified about
already during the registration.
As I also mentioned, the Changebroker is not yet part of the EMF Client
Platform SDK, so we do not consider this to be a core feature yet. That
is why we did not blog about it yet. As I also mentioned, I will
probably blog about it soon as part of introducing the 1.7.0 release,
but I do not have a defined date for that blog post, yet.
You answer sounds pretty angry. Insulting people, who work on a
framework that you might use completely for free and being angry at
people who try to help you in a support forum without charging for that
does usually not help you getting better support. Sorry to say that so
clear.
If you need guaranteed support with defined response times, you need to
get professional support. If you need a new feature to be available in a
certain release, you should consider sponsored development. We and most
other companies active in this forum offer this as a service.
As you might have noticed, you also get help, if you do not pay for
that, as for example all questions in this forum are usually answered
within a single day. Also most committer teams fix critical bugs without
charging for that and even develop new features. However, that is really
on a voluntary basis.
I hope I could help.
Best regards
Jonas
Am 22.09.2015 um 16:29 schrieb Alexander Zavodnikov:
> ..nothing - no blog and no other docs.. are you dammin serious?
> What is your hope regarding user acceptance for EMF Forms? You suggest
> to use some undocumented, maybe experimental things, which may
> disappear in next minor release...
> Do you really think that developers, which have do deliver reliable
> solutions go this way? ...laughable
Jonas Helming
Re: EMF Forms notification in e4 [message #1709020 is a reply to message #1709015] Wed, 23 September 2015 07:16 Go to previous message
...thanks for answering
I noticed well, that it's all for free... but there are other frameworks for free, too. And somehow they do most things better. Again, it's only my opinion. Please don't take my negativity into account, It's my own problem... and for the record: up to now i donated 30€ to Eclipse, so I am not that kind of people...
...the solution is simple:
       private AdapterImpl changeListener = new AdapterImpl() {
		public void notifyChanged(final Notification msg) {
			// react on changes
	private void addChangeListener(EObject eObj) {
		eObj.eAdapters().add(changeListener);
		for (EObject e : eObj.eContents()) {
			addChangeListener(e);
then you can do:
addChangeListener(root);
[Updated on: Sat, 26 September 2015 12:06] by Moderator
Previous Topic:EMF Import project/child from an XML file
Next Topic:[CDO/Net4j] OutOfMemoryError: Direct buffer memory
Current Time: Wed Jul 23 12:39:05 EDT 2025
Powered by FUDForum. Page generated in 0.05159 seconds
